Vr is normally higher than V1 (but not always), it cannot be less
than V1. Isn't that a "mutually exclusive" statement. I guess V1 and Vr could be the same, I've never seen that. If Vr is the same as some other "V" speed it is usually the same as V2. Karl "Bob Moore" wrote in message 22... Jose wrote Under what circumstances are pilots required to calculate an accelerate-stop distance, and take off only on a runway that is longer than that distance? This runway was longer than the required accelerate/stop distance. Vr is normally higher than V1 (but not always), it cannot be less than V1. Once past V1, there is no guarantee that the airplane will stop on the runway, in fact, if it is exactly a balanced field, it will not stop on the runway. He was simply past V1 and probably past Vr when the problem was recognized. Bob Moore |
kage wrote:
Vr is normally higher than V1 (but not always), it cannot be less than V1. Isn't that a "mutually exclusive" statement. I guess V1 and Vr could be the same, I've never seen that. If Vr is the same as some other "V" speed it is usually the same as V2. Karl Global Express, on dry runway V1 and Vr are always the same. |
"kage" wrote
Vr is normally higher than V1 (but not always), it cannot be less than V1. Isn't that a "mutually exclusive" statement. I guess V1 and Vr could be the same, I've never seen that. B-727-200...V1 and Vr were normally the same. If Vr is the same as some other "V" speed it is usually the same as V2. I don't see how that can be considering the "speed increment" required by the following from FAR Part 25: (c) V2, in terms of calibrated airspeed, must be selected by the applicant to provide at least the gradient of climb required by §25.121(b) but may not be less than— (2) VR plus the speed increment attained (in accordance with §25.111(c)(2)) before reaching a height of 35 feet above the takeoff surface; Bob Moore ATP B-727 B-707 PanAm (retired) |
![]() "Bob Moore" wrote in message . 121... "kage" wrote Vr is normally higher than V1 (but not always), it cannot be less than V1. Isn't that a "mutually exclusive" statement. I guess V1 and Vr could be the same, I've never seen that. B-727-200...V1 and Vr were normally the same. If Vr is the same as some other "V" speed it is usually the same as V2. I don't see how that can be considering the "speed increment" required by the following from FAR Part 25: (c) V2, in terms of calibrated airspeed, must be selected by the applicant to provide at least the gradient of climb required by §25.121(b) but may not be less than- (2) VR plus the speed increment attained (in accordance with §25.111(c)(2)) before reaching a height of 35 feet above the takeoff surface; Bob Moore ATP B-727 B-707 PanAm (retired) Vr and V2 are always the same in a Falcon 50, a part 25 airplane. Go figure! I never got to fly something big. Best, Karl ATP BE-300 CE-500 LR-Jet DA-50 Helicopter |
![]() "Jose" wrote in message . com... Under what circumstances are pilots required to calculate an accelerate-stop distance, and take off only on a runway that is longer than that distance? For every takeoff for aircraft certified under Part 25. |
Challenger Crashe at TEB | Jon Kraus | Owning | 78 | February 11th 05 01:10 AM |
Need details on a Challenger 602 | Bob Moore | Piloting | 14 | December 6th 04 08:28 PM |
Challenger forum | Dico Reyers | Home Built | 0 | December 30th 03 06:48 PM |
Ignoring the Challenger? | robert arndt | Military Aviation | 0 | July 1st 03 10:24 AM |
