Atmospheric stability and lapse rate
Old February 7th 05, 03:48 AM
Mike Rapoport
"Andrew Sarangan" wrote in message
1...
Instability produces cumulus clouds and stability produces stratus clouds.
We know that. However, since the saturated and unsaturated lapse rates are
significantly different (1C/1000' compared to 3C/1000'), it seems quite
possible to get cumulus clouds even when the atmosphere below is stable.
For instance, if the environmental lapse rate is 2C/1000', the unsaturated
air is stable. Once clouds form (how they form without vertical currents
is
a different matter), the air inside the clouds will become unstable. Does
this seem reasonable?
Yes are often a combination of clouds at various levels
On a related question, where does the concept of 'average' lapse rate
(2C/1000') come from? I always took this to mean 50% RH air, but it took
me
a long time to learn that that was not the case. The air is saturated or
it
is unsaturated. How can there be an average between saturated and
unsaturated? The standard lapse rate and standard temperature at
different elevations are all based on this 2C/1000' concept. What's the
deal with this?
The 2C/1000 was arbitrarily chosen as the "standard" for things like
calibrating altimeters. As you note, it has nothing to do with the real
world.
Mike
MU-2
How high is that cloud? Tim Hogard Instrument Flight Rules 26 November 29th 04 01:40 AM
