Also, look into the cost of haivng the inside of the hangar foamed... You
get an air tight result, with superior R values... They may do the inside of the door also, depending on your installation... Foam is a few more bucks, but in ten years you won't miss the money and you have a superior product... Denny "G.R. Patterson III" wrote in message ... "B. Jensen" wrote: I have a 48x60' hangar that I want to insulate for the upcoming MN winter. What are my options, and what works the best? Options tend to be fiberglass batts and foam panels. Fiberglass is cheaper and doesn't burn as well. It can be held in place with spring wire placed between joists or by stapling chicken wire to structures to hold it in (among other techniques). One disadvantage is that rodents like to make nests in it. Many types of foam are flammable, some highly so, but the panels can be glued in place with construction adhesive. I will also be adding some much needed overhead lighting. Any recommendations here? The most cost-effective lighting is fluorescent. Standard ballasts don't work well below about 60 degrees, however, so you need commercial fixtures. Home Depot in this area sells Simkar commercial units with ballasts that work down to below freezing, but even that isn't going to be good enough for deep winter where you are. Halogens work in about any temperature, but they put out lots of heat. That's great in winter, but lousy the rest of the year. Possibly the best choice would be some of those "yard security" lights that look and work like streetlights. George Patterson A man who carries a cat by the tail learns something that cannot be learned any other way. Samuel Clemens |
The Auction Hangar - Completely free aviation auction site. | The Auction Hangar | General Aviation | 1 | April 6th 04 07:17 AM |
The Auction Hangar - Completely free aviation auction site. | The Auction Hangar | Naval Aviation | 0 | April 6th 04 12:58 AM |
The Auction Hangar - Completely free aviation auction site. | The Auction Hangar | Military Aviation | 0 | April 6th 04 12:58 AM |
The Auction Hangar - Completely free aviation auction site. | The Auction Hangar | Home Built | 0 | April 6th 04 12:57 AM |
Hangar Insulation & Lighting? | B. Jensen | Owning | 5 | September 15th 03 07:10 PM |
