Price is a factor, but so are the features. If you look at the ATD
sure it is low priced, but it also doesn't have near the features or resolution as the other devices. You get what you pay for I think. If you squawk any one of these codes, the ATD user handbook says it will get confused and bounce back and forth between the target and "image" target. http://www.airsport-corp.com/modecascii.txt I think it is worth a couple hundred bucks extra to get better resolution and accurate information, if you are going to spend that much anyway. Thomas Borchert wrote in message ... Loran, What matters is portability, accuracy of the altitude, range, and the overall size in my opinion. Uh, price? |
Loran,
If you look at the ATD sure it is low priced, but it also doesn't have near the features or resolution as the other devices. Care to explain? -- Thomas Borchert (EDDH) |
All you have to do is look at their user manuals on any of these
devices to see the ATD300 has hardly any features. I am just reading through, side by side, the features. http://perso.wanadoo.fr/proxalert/download/ProXalert%20R5%20-%20Product%20Brief%20(Nov%202003).PDF http://www.monroyaero.com/ATD300Manual.pdf http://surecheck.net/five/pdf/VRX_1-0-1_Full.pdf These are the deficiencies I noticed from comparing the different models. The ATD does have a bus voltage monitoring, but when you look at all of the other factors, I think it comes up short. The ATD does not have an altimeter, which leaves it to listen to any nearby transponder for a reference altitude. Like I showed before this could be problematic if you start squawking any of those codes. The ATD requires you to have an aircraft with a working transponder and be flying in adequate radar coverage at all times. The ATD will not show any altitude outside of a 1000' window The ATD does not take batteries The ATD has a resolution of 1.0 NM increments only. Saying an aircraft is less than 1 NM is poor resolution around an airport, where as the others go from 1.0 down to 0.1 NM The ATD does not have any volume control for in flight use The ATD does not have any way to show how many other threats are around you. The ATD has no visual indication of alerting you The ATD does not have any dataport for upgrading or interfacing The ATD does not have an independent mode selection system for range or altitude The ATD audio interface has no mixing or mono-stereo selection The ATD has no altitude drift alarm The ATD has no selection of flight status, like ground, or flight Check them out, they all have manuals online. Thomas Borchert wrote in message ... Loran, If you look at the ATD sure it is low priced, but it also doesn't have near the features or resolution as the other devices. Care to explain? |
Loran,
ok, first, in the interest of full disclosure, I am involved in a pilot shop selling the ATD-300 in Germany. But I am seriously interested in this. What features exactly are we talking about? Altitude display? It's there. Multiple targets? It's there, albeit in alternating display mode. But here's my main point: If you get an alert, what will you do? Will you keep your head inside the cockpit and start evaluating all the stuff that some of the display show, or will you do the smart thing and LOOK OUTSIDE? So, which feature do you find missing that doesn't just look good on a spec sheet but that you actually need in practice? Again, I am seriously interested in your opinion. -- Thomas Borchert (EDDH) |
Here is my question in a scenario basis that I can think of.
Since the ATD relies solely on your transponder for altitude, If you took off out of an airport and you didn't reach adequate radar coverage for 1000 feet or more, how is the ATD unit going to know what altitude you are? If another aircraft is in the pattern, how could the ATD possibly tell you how high above it is? another scenario, If you where flying in radar coverage at say 5,000 feet, and another aircraft is say 5,700 feet headed towards you. The ATD would say you are 5,000 feet correct? but what happens if you fly out of radar coverage, and climb or descend? So if you started climbing, 5,100......5,200.....etc the ATD would still say you are at 5,000 feet since that was the last altitude it got from your transponder correct? So you could end up at the same altitude of the other aircraft, while the ATD still says +700 another scenario, Suppose you are flying with the ATD at 2,000 feet and ATC gives you a squawk code that equals 1,400 feet. Another aircraft close by is at an altitude of 2,900 feet The atd will be confused and bounce between showing traffic +900......-600.......+900.......-600 let me ask you this. If you flying in the pattern of a busy airport, how often are other aircraft within 1 NM of you? another scenario, If two equal threats come into the scene, what will the ATD show? a flipping back and forth picture? At what rate? Is it not possible for 2 or more aircraft to be flying around you near any airport? See the problem here? They admit these errors on page 9 of their manual, and talk about going through steps to try and stop this problem. All of which are instantly avoided by the competitive units having a backup altimeter. A device telling you to look outside is great, but not if it is constantly telling you to look outside because someone is flying 1 mile away from you, or gives you false altitude readings because you don't stay straight and level, in radar coverage, and don't squawk one of the hundreds of confusing codes. Let me ask you this, with other units having most likely a higher profit margin, more ESSENTIAL features, why are you as a business, so eager to promote and sell a less superior product line and make less money? That makes no sense to me if I where a business. I would think you would want to sell your customers the best products for the most profit. That is how I run my business anyway. There are many competitive products I can choose from, but I wouldn't pick out the least favored and less profitable to run frontage on. Thomas Borchert wrote in message ... Loran, ok, first, in the interest of full disclosure, I am involved in a pilot shop selling the ATD-300 in Germany. But I am seriously interested in this. What features exactly are we talking about? Altitude display? It's there. Multiple targets? It's there, albeit in alternating display mode. But here's my main point: If you get an alert, what will you do? Will you keep your head inside the cockpit and start evaluating all the stuff that some of the display show, or will you do the smart thing and LOOK OUTSIDE? So, which feature do you find missing that doesn't just look good on a spec sheet but that you actually need in practice? Again, I am seriously interested in your opinion. |
Loran,
Since the ATD relies solely on your transponder for altitude, If you took off out of an airport and you didn't reach adequate radar coverage for 1000 feet or more, how is the ATD unit going to know what altitude you are? Huh? If my transponder is not interrogated, how will other traffic close by and at my altitude be interrogated? So, even if my traffic detector knows my altitude from pressure, it will still not know the target altitude. That scenario doesn't work for any traffic detector. If you where flying in radar coverage at say 5,000 feet, and another aircraft is say 5,700 feet headed towards you. The ATD would say you are 5,000 feet correct? but what happens if you fly out of radar coverage, and climb or descend? Same thing: If my transponder is not interrogated, the target transponder won't be, either. So if you started climbing, 5,100......5,200.....etc the ATD would still say you are at 5,000 feet since that was the last altitude it got from your transponder correct? No. It would show absolute altitude of the target, if the target transponder is being interrogated and giving off Mode C info, and mine isn't. Suppose you are flying with the ATD at 2,000 feet and ATC gives you a squawk code that equals 1,400 feet. Another aircraft close by is at an altitude of 2,900 feet The atd will be confused and bounce between showing traffic +900......-600.......+900.......-600 Well, time to read the manual again. To quote "In extremely rare cases..." the above may happen. A solution to the problem is given in the manual. let me ask you this. If you flying in the pattern of a busy airport, how often are other aircraft within 1 NM of you? Not sure I understand the meaning of the question. But I'll offer one thing which I have said befo If you are looking at any traffic detector while in the pattern of a busy airport, please tell me before which airport it will be so I can stay as far away as possible. If two equal threats come into the scene, what will the ATD show? a flipping back and forth picture? At what rate? Is it not possible for 2 or more aircraft to be flying around you near any airport? See the problem here? No. The ATD will give preference to the closer threat. Makes sense to me. And by that time, you should be looking outside anyway! Let me ask you this, with other units having most likely a higher profit margin, more ESSENTIAL features, why are you as a business, so eager to promote and sell a less superior product line and make less money? That makes no sense to me if I where a business. I would think you would want to sell your customers the best products for the most profit. That is how I run my business anyway. There are many competitive products I can choose from, but I wouldn't pick out the least favored and less profitable to run frontage on. Least favored by who? Do you read Aviation Consumer, for example? Their preference among the previous generation of traffic detectors was pretty clear. Also, if you assume higher profits (which I don't know anything about), are you saying you LIKE to be ripped off? Let me tell you my business model: I try not to rip off my customers on the vague assumption that "Anything good in aviation has to be expensive". And yes, that works quite well, thank you. Have you spent any time actually flying with a traffic detector? I have. That's how I arrived at my questions and conclusions. And the scenarios you offer frankly don't convince me at all to spend almost double the money. But then, I'm probably biased. g -- Thomas Borchert (EDDH), www.aeroversand.de |
"Same thing: If my transponder is not interrogated, the target
transponder won't be, either." Nothing could be further from the truth. I would reccomend you talk to your local center, or approach control and see why because the explanation is rather lengthy. Also bear in mind the growing amount of Mode S transponders which transmit regardless of interrogations. Even so, what altitude would your ATD show if you flew out of radar at 5,000 feet and descended 1,000 feet? Without that interrogation, it would still be locked at 5,000. "Well, time to read the manual again. To quote "In extremely rare cases..." the above may happen. A solution to the problem is given in the manual." I read that, and have learned from MANY years that when a manufacturer says *extremely rare cases* you can bank on it happening often. I also went a step further and read http://www.airsport-corp.com/modecascii.txt which lists the pages and pages and more pages of squawk codes that WILL confuse it. If you fly IFR at all, the last thing you want to be doing is trying to fix the ATD while you are flying through the soup. A "solution"? Why go through all this? Why wonder if the unit is getting the right altitude? Just get one of the other two units and then you'll know for sure, whether you fly in or out of radar. "Do you read Aviation Consumer, for example? Their preference among the previous generation of traffic detectors was pretty clear." Actually I have a subscription, but you know, nowhere is there a review on the Proxalert, Trafficscope, or ATD300. I do however, see a review from 2 years ago on previously two of the three manufacturers older devices of the TPAS and ATD200. Now surely, you are not trying to imply that a consumer review on completely different models from years past are applicable to anything these manufacturers, or future manufacturers develope are you?? If that where the case Garmin must STILL be living in a "dreamworld where we navigate by satellites" and glass cockpits are still a "Fad which will soon fade" Better yet, I would be curious if Aviation Consumer is planning on reviewing all three of these devices. Thomas Borchert wrote in message ... Loran, Since the ATD relies solely on your transponder for altitude, If you took off out of an airport and you didn't reach adequate radar coverage for 1000 feet or more, how is the ATD unit going to know what altitude you are? Huh? If my transponder is not interrogated, how will other traffic close by and at my altitude be interrogated? So, even if my traffic detector knows my altitude from pressure, it will still not know the target altitude. That scenario doesn't work for any traffic detector. If you where flying in radar coverage at say 5,000 feet, and another aircraft is say 5,700 feet headed towards you. The ATD would say you are 5,000 feet correct? but what happens if you fly out of radar coverage, and climb or descend? Same thing: If my transponder is not interrogated, the target transponder won't be, either. So if you started climbing, 5,100......5,200.....etc the ATD would still say you are at 5,000 feet since that was the last altitude it got from your transponder correct? No. It would show absolute altitude of the target, if the target transponder is being interrogated and giving off Mode C info, and mine isn't. Suppose you are flying with the ATD at 2,000 feet and ATC gives you a squawk code that equals 1,400 feet. Another aircraft close by is at an altitude of 2,900 feet The atd will be confused and bounce between showing traffic +900......-600.......+900.......-600 Well, time to read the manual again. To quote "In extremely rare cases..." the above may happen. A solution to the problem is given in the manual. let me ask you this. If you flying in the pattern of a busy airport, how often are other aircraft within 1 NM of you? Not sure I understand the meaning of the question. But I'll offer one thing which I have said befo If you are looking at any traffic detector while in the pattern of a busy airport, please tell me before which airport it will be so I can stay as far away as possible. If two equal threats come into the scene, what will the ATD show? a flipping back and forth picture? At what rate? Is it not possible for 2 or more aircraft to be flying around you near any airport? See the problem here? No. The ATD will give preference to the closer threat. Makes sense to me. And by that time, you should be looking outside anyway! Let me ask you this, with other units having most likely a higher profit margin, more ESSENTIAL features, why are you as a business, so eager to promote and sell a less superior product line and make less money? That makes no sense to me if I where a business. I would think you would want to sell your customers the best products for the most profit. That is how I run my business anyway. There are many competitive products I can choose from, but I wouldn't pick out the least favored and less profitable to run frontage on. Least favored by who? Do you read Aviation Consumer, for example? Their preference among the previous generation of traffic detectors was pretty clear. Also, if you assume higher profits (which I don't know anything about), are you saying you LIKE to be ripped off? Let me tell you my business model: I try not to rip off my customers on the vague assumption that "Anything good in aviation has to be expensive". And yes, that works quite well, thank you. Have you spent any time actually flying with a traffic detector? I have. That's how I arrived at my questions and conclusions. And the scenarios you offer frankly don't convince me at all to spend almost double the money. But then, I'm probably biased. g |
Plane with no stall warning device? | Roy Smith | General Aviation | 23 | February 17th 04 03:23 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
Riddle me this, pilots | Chip Jones | Instrument Flight Rules | 137 | August 30th 03 04:02 AM |
Riddle me this, pilots | Chip Jones | Piloting | 131 | August 30th 03 04:02 AM |
