Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Products
New traffic warning device
  #11
Old February 1st 04, 07:07 PM
Loran
All you have to do is look at their user manuals on any of these
devices to see the ATD300 has hardly any features. I am just reading
through, side by side, the features.
http://perso.wanadoo.fr/proxalert/download/ProXalert%20R5%20-%20Product%20Brief%20(Nov%202003).PDF
http://www.monroyaero.com/ATD300Manual.pdf
http://surecheck.net/five/pdf/VRX_1-0-1_Full.pdf
These are the deficiencies I noticed from comparing the different
models. The ATD does have a bus voltage monitoring, but when you look
at all of the other factors, I think it comes up short.
The ATD does not have an altimeter, which leaves it to listen to any
nearby transponder for a reference altitude. Like I showed before
this could be problematic if you start squawking any of those codes.
The ATD requires you to have an aircraft with a working transponder
and be flying in adequate radar coverage at all times.
The ATD will not show any altitude outside of a 1000' window
The ATD does not take batteries
The ATD has a resolution of 1.0 NM increments only. Saying an aircraft
is less than 1 NM is poor resolution around an airport, where as the
others go from 1.0 down to 0.1 NM
The ATD does not have any volume control for in flight use
The ATD does not have any way to show how many other threats are
around you.
The ATD has no visual indication of alerting you
The ATD does not have any dataport for upgrading or interfacing
The ATD does not have an independent mode selection system for range
or altitude
The ATD audio interface has no mixing or mono-stereo selection
The ATD has no altitude drift alarm
The ATD has no selection of flight status, like ground, or flight
Check them out, they all have manuals online.
Thomas Borchert wrote in message ...
Loran,
If you look at the ATD
sure it is low priced, but it also doesn't have near the features or
resolution as the other devices.
Care to explain?
Plane with no stall warning device? Roy Smith General Aviation 23 February 17th 04 03:23 AM
Riddle me this, pilots Chip Jones Instrument Flight Rules 137 August 30th 03 04:02 AM
Riddle me this, pilots Chip Jones Piloting 131 August 30th 03 04:02 AM
