If I make it stronger
Old August 29th 04, 09:48 PM
Jerry J. Wass
Yep, the good old Forest Products Laboratory--book---Now, if Mr. Mitchell
could tell us where to find the B.S.V.36 (is the B British?) I would be
greatly appreciative.--Jerry
Stan Premo wrote:
Someone was kind enough to share this source some time back. It's a wealth
of knowledge...but a little knowledge can be a dangerous thing! Be careful
with substitutions!
http://www.fpl.fs.fed.us/documnts/FP.../fplgtr113.htm
"Sean Trost" wrote in message
Dear Mr. Mitchell,
I was wondering if the group or myself be able to read and use your
grading method for D. Fir. I am in the process of rebuilding a wooden
aircraft and would like to compile as much knowledge as possible to
fully understand the substitutions I am making.
I am not increasing performance or loads in any way.
I am using fir to rebuild certain components that I feel do not move
loads around to any detriment.
thanks for your time.
Sean Trost
mj-5 sirroco project
Old August 29th 04, 11:15 AM
smjmitchell
B.S. standards for British Standard.
My copies are old and faded and a copy of a copy.
I am sure you could get a copy through IHS or a similar standards supply
company.
"Jerry J. Wass" wrote in message
wealth
careful
with substitutions!
Dear Mr. Mitchell,
Sean Trost
Old August 29th 04, 05:10 PM
Ryan Young
"Jerry J. Wass" wrote in message ...
Try this link to what appears to be a renamed standard:
http://www.techstreet.com/cgi-bin/de...uct_id=1108781
But then again, maybe it's this one:
http://www.techstreet.com/cgi-bin/de...uct_id=1113167
Notice that the first document refers to spruce and fir. I suspect if
you use the usual standards for spruce on fir, regarding grain
orientation, etc. you'll be fine, without spending big bucks on a
British Standard that may not meet your objective.
So, to repeat links already shared, methinks these two will do you:
http://www.fpl.fs.fed.us/documnts/FP.../fplgtr113.htm FPL
manual
http://www.moneypit.net/~pratt/ac43/ac43chp1.zip AC 43.13, or the FAA
link:
http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/99c827db9baac81b86256b4500596c4e/$FILE/Chapter%2001.pdf
Rather than Douglas Fir, if you live in the Western part of North
America, consider "Western White Wood", which is a catch-all for
various hemlocks, firs, and larches. The strength properties are
acceptable, and the grain is far easier to deal with than Douglas Fir.
Available at Home Depots everywhere, just select with extreme care,
and start by looking in the shelving and trim wood section.
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 June 2nd 04 07:17 AM
