![]() Rod Buck wrote: In message , lid writes You lost me there. ![]() fixed pitch) on a helicopter. Other than losing auto-rotation, what is the downside? I know losing auto-rotation IS a big deal. I saw a coaxial kit that uses a tiltrotor (no swashplate, no collective...no auto-rotation) But they have two engines. Seems like dropping all the extra hardware for pitch control (they use engine speed to control lift) would be a good thing. Look, you can alter the lift force of a rotor by two methods. Either you keep the same rotor rpm, and alter the pitch angle of the blades, OR you keep the blade angle the same, and alter the rotor RPM. Or, of course, a combination of the two. The problem is that, without collective pitch control, you can only vary the lift force by increasing or decreasing rotor rpm, ie by altering engine power. This is very slow to act, due to rotor inertia (flywheel effect) and means that control is extremely sluggish and imprecise compared to collective pitch control, where the rotor speed is constant, but the attack angle of the blades is changed instantly. You do NOT need a collective-pitch control to change from powered flight to autorotation - you could just set the blades to autorotation angle to start with, and then vary power to increase lift - then, if the engine quit, the freewheel device in the drive chain would let the blades outspeed the engine, and you'd enter autorotation automatically. The confusion you are having is, I think, because you (and several others) think that the blades have to be at positive pitch for powered flight, and altered to negative pitch (nose-down to the plane of the rotor disk) for autos. THIS IS INCORRECT. Blades autorotate perfectly well with a small positive pitch angle - normally about 1-3 degrees (depends on the airfoil used) -- Rod Buck Well... You also change the flight path. The blades need to see an updraught to absorb power to spin, to generate lift somehow. The change in direction of the airflow between a nose down attitude under power in a helo and a nose up, direction slightly down for autorotation makes the mechanical aoa at the hub different from the aoa of the airflow on the rotor. I cannot claim any authority for this beyond personal experimentation, and my conjecture, apparantly widely debated if not misunderstood, seems in at least a common sense way to be true. A small toy illustrates a point which becomes intuitive. A stick twirled between the palms with rotor blades attached ascends until the energy stored on the rotor is consumed. The toy begins to descend rapidly. The rotor reverses and spins up. The descent slows dramatically. The apparent wind on the blades must be at a + aoa to autorotate, even if the aoa at the reversed hub wrt the shaft may be -, and the airflow presents a greater + to the reversed blade with as much - mechanical aoa as it was + rotating in the ascending phase, spinning it up by energising it, and with increase in apparent airspeed of the rotor the aoa becomes less + in regard to the flightpath of the blade arounds the hub, while being - to the airflow around the craft. Autorotation is a delicate balance, yes? One must fly the collective carefully to do autos. It is a skill I cannot claim. The airflow changes from downward to upward on the rotor blades of the toy. If the hub rotation does not reverse, the + mechanical aoa of a powered nose up gyro becomes - wrt the airflow in the retreating blade, the flight path becomes downward, wrt apparent airflow to the craft now nose down wrt horizon, but still + in one sense, and - in another. In autorotation, part of the rotor's flightpath must be - aoa wrt the aparrent airflow on the blade. Watch the toy fly again. Meditate some more. Grok the universe. Be one with gravity. Is it possible to explain this in some other way? I can't seem to express it well. Perhaps a cartoon video is available somewhere? This is possibly a flawed intuit, and I cannot yet grasp it all. I am not a rotorhead, but have watched many autorotations from the tower at a helo flight school, complete with commentary from those "3 dimensional thinkers" that direct the traffic. As a control tower radio tech, I have had some "unofficial" flight training, er, perhaps I should say unofficial experience in fixed wing and rotor, and understand aerodynamics to an extent in model design and flight. If I claim to be a little perlexed, at least you must respect my honesty. In autorotation flight, part of the rotor disk must be in - air aoa, yes or no? -- Terry K - My email address is MY PROPERTY, and is protected by copyright legislation. Permission to reproduce it is specifically denied for mass mailing and unrequested solicitations. Reproduction or conveyance for any unauthorised purpose is THEFT and PLAGIARISM. Abuse is Invasion of privacy and harassment. Abusers may be prosecuted. -This notice footer released to public domain. Spamspoof salad by spamchock - SofDevCo |
On Mon, 04 Aug 2003 02:36:31 GMT, Terry Spragg
wrote: If I claim to be a little perlexed, at least you must respect my honesty. In autorotation flight, part of the rotor disk must be in - air aoa, yes or no? G'day Terry, I am going to read your post in full again offline, but let me answer this bit quickly. There is no need for any part of the aerofoil to be in -ve AoA. It is not blown around like a toy fan. Have a look at this page http://www.copters.com/aero/autorotation.html See in figure 2-89 that because of the upward inflow the lift vector is tilted forward? The portion of lift in the forward direction acts to pull the blade forward (or around). Hope this helps. I'll reread your post and send some more later, if required. Cheers, Phil -- Pfft...english! Who needs that? I'm never going to England. Homer J. Simpson |
not blown around like a toy fan. Have a look at this page http://www.copters.com/aero/autorotation.html Hi Phil, Great link! Turns out I understood this stuff better than I thought I did. I've read plenty about the physics, just never seen it laid out this well in pictures. Thanks for posting it. Fly Safe, Steve R. |
wrote: Well... G'day Terry, Did the page I pointed you to help at all? You also change the flight path. Yeah. The blades need to see an updraught Yep. to absorb power to spin, to generate lift somehow. Not sure what this means? The change in direction of the airflow between a nose down attitude under power in a helo and a nose up, direction slightly down for autorotation makes the mechanical aoa at the hub different from the aoa of the airflow on the rotor. Not sure what you mean by mechanical AoA at the hub, but the AoA of the blades increases (more +ve), for the same pitch angle, with an upward flowing airstream. I cannot claim any authority for this beyond personal experimentation, and my conjecture, apparantly widely debated if not misunderstood, seems in at least a common sense way to be true. A small toy illustrates a point which becomes intuitive. A stick twirled between the palms with rotor blades attached ascends until the energy stored on the rotor is consumed. The toy begins to descend rapidly. The rotor reverses and spins up. The descent slows dramatically. ISTR from childhood playing with this type of device, but I don't remember them reversing direction of rotation during flight. They would descend as rpm decreased. Are you just doing a thought experiment and extending the flight? The apparent wind on the blades must be at a + aoa to autorotate, Yeah. even if the aoa at the reversed hub wrt the shaft may be -, Do you mean the *pitch* is -ve because the rotor is now turning in reverse? and the airflow presents a greater + to the reversed blade with as much - mechanical aoa as it was + rotating in the ascending phase, spinning it up by energising it, and with increase in apparent airspeed of the rotor the aoa becomes less + in regard to the flightpath of the blade arounds the hub, while being - to the airflow around the craft. No. I lost it completely there. Are you saying that although the toy, now spinning in reverse, seems to have a -ve pitch, it actually has a +ve AoA because it is descending? Autorotation is a delicate balance, yes? One must fly the collective carefully to do autos. As I understand it (and I never got that far in my (limited) experience in helicopters), it's a matter of engine failure...collective to minimum ASAP...leave it there until the correct height above the ground...pull collective to flare. It's not a matter of adjusting the collective during the auto. I stand ready to be corrected by those in the know. As for gyroplanes, they will happily autorotate all day without any means to vary the pitch collectively at all. It is a skill I cannot claim. The airflow changes from downward to upward on the rotor blades of the toy. If the hub rotation does not reverse, the + mechanical aoa of a powered nose up gyro becomes - wrt the airflow in the retreating blade, No. And this is where you are striking trouble, I suspect. The AoA on the retreating blade does not go -ve. In fact, if anything, the retreating blade has a higher angle of attack than the advancing blade (but that is another discussion). the rotor disk is tilted back, yes, but the blade is doing several hundred miles per hour. The apparent wind is several hundred miles per hour *in the direction of travel* (plus a downward component). The direction of the craft has an influence, but not as significant as I think you think. the flight path becomes downward, wrt apparent airflow to the craft now nose down wrt horizon, but still + in one sense, and - in another. In autorotation, part of the rotor's flightpath must be - aoa wrt the aparrent airflow on the blade. I don't see what you mean. Unless you are thinking that the airflow caused by craft movement is the apparent airflow. In an aeroplane this would be the case, but an aeroplane's wings are not doing several hundred miles an hour and creating their own apparent airflow. Watch the toy fly again. Meditate some more. Grok the universe. Be one with gravity. Ooom...OOooommm... Is it possible to explain this in some other way? I can't seem to express it well. Perhaps a cartoon video is available somewhere? This is possibly a flawed intuit, and I cannot yet grasp it all. I am not a rotorhead, but have watched many autorotations from the tower at a helo flight school, complete with commentary from those "3 dimensional thinkers" that direct the traffic. As a control tower radio tech, I have had some "unofficial" flight training, er, perhaps I should say unofficial experience in fixed wing and rotor, and understand aerodynamics to an extent in model design and flight. If I claim to be a little perlexed, at least you must respect my honesty. In autorotation flight, part of the rotor disk must be in - air aoa, yes or no? My vote? No. Cheers, Phil -- Definitions of a pilot - No. 1 The average pilot, despite the sometimes swaggering exterior, is very much capable of such feelings as love, affection, intimacy and caring. These feelings just don't involve anybody else. US Navy Times |
attitude under power in a helo and a nose up, direction slightly down for autorotation makes the mechanical aoa at the hub different from the aoa of the airflow on the rotor. Not sure what you mean by mechanical AoA at the hub, but the AoA of the blades increases (more +ve), for the same pitch angle, with an upward flowing airstream. I think what they're refering to when they say "mechanical AoA" is blade incidence. Fixed wing aircraft generally have their wings set a some positive incidence relative to the long axis (longitudinal) of the fuselage. The main reason for this, as I understand it, is so the fuse will fly in a level attitude at cruise while allowing the wing to fly at a positive AoA to produce the lift needed to maintain flight. This positive incidence is fixed and cannot be changed or adjusted by the pilot. Helicopters, OTOH, adjust the incidence of their rotor blades through collective and cyclic commands. In this case, the incidence is a measurement of the angle of the rotor blade cord line relative to an imaginary line running perpendicular (90 degrees to) the rotor mast. While changing the incidence of the main rotor blades (through collective and cyclic commands) will change the aerodynamic AoA, they are not the same thing. For example, if you could lower the collective to a negative "incidence" (I'm not sure if full size helicopters do this, I know that RC models do), the rotor blades would still be seeing a positive AoA while in flight due to the steep descent angle. FWIW, Fly SAfe, Steve R. |
Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 05:07 PM |
Bothersome Phillips Head Screws | Larry Smith | Home Built | 48 | January 10th 04 04:26 AM |
Aviano thanks base guardians as Puerto Rican guardsmen head home | Otis Willie | Military Aviation | 0 | September 1st 03 02:24 AM |
Child head set | Dennis O'Connor | Piloting | 7 | July 15th 03 01:55 PM |
Citabria with gyros | Bob Esser | Piloting | 6 | July 9th 03 12:03 AM |
