![]() Most of the problems with the one I have are due to age. A lot of the aluminum parts have surface oxidation that must be hand removed and polished. I am planning on having all the aluminum parts hard anodized so that they don't do that again. The tail rotor slider mechanism was rusted and I had to work it pretty hard to get it going again. I am planning on having the TR shaft hard chrome plated so that it will wear better. The steel frame is actually in remarkable shape. I'm not sure what they used to paint it, but I hope to get something that good to repaint it. The only components that I am really worried about are the blades. They only have about 25 hours on them, but also have age cracks in the composite. I haven't contacted BJ about the Scorpion One. I don't think he would have time to talk to me since he is very busy with his helicycle project. I have the blueprints for the Scorpion 2 and was considering getting those for the One, but the One is almost identical to the 2 so I'm not sure if I should bother. The bent cable is for the collective. Its a nutty way of doing things, but it does work. Its just not as good as a regular system. The only real problem with the bent cable rotor head is that it does not use elastomeric bearings. It uses unsealed thrust bearings instead. However, because of the way the cable head works, they only move when you actually move the collective. I'll probably have to spend a bit of time every few hours of operation greasing them, but a friend showed me a trick where I can grease them easily with a hypodermic needle. Hopefully that will make operating it more manageable. I'm still not sure what to do about the license. Dennis H. "Stu Fields" wrote: I had two Scorpion ones and sold them to a guy who had an A&P try to get them going. They still have not been in the air. He had a lot of trouble with slipping tail rotor belts. There are some problems with the old rotor head. B.J Schramm, the designer should be contacted about those problems. I believe I heard him tell one person not to fly the version with the looped cable in the head. I used to fly a Benson gyro with a McCullough engine. It was a quiet sewing machine compared to the sound of the Evinrude engine in the Scorpion. Be very careful. Stu Fields wrote in message ... "Gig Giacona" wrote: You will have to be signed off by and instructor for that aircraft. Do you already own a flyable Scorpion? You will most likely have to get back in the R22 for your check ride. My scorpion is a single seater and is not completely restored yet. I checked with Rotorway, but it does not seem that there is any way to get instruction in a scorpion one. I wonder if a scorpion 2 is close enough. The scopion 2 and scorpion one are basically the same helicopter with the 2 being bigger and wider. It is starting to look like I'm going to have to get my certificate by soloing in the R22 and then just switch to the scorpion afterwards. It seems like thats a waste of money though since I will have to relearn everything in the scorpion. I have all the parts to the scorpion one, but I am not sure what to do with the rotor blades. It looks like there are fine cracks in the composite. I wonder if simply recoating them with new resin will be good enough or if I have to rewrap them. They only have about 25 hours on them. I will also say that the scorpion 1 was definitely not designed for people with normal length legs. Its a real pain getting in and out of it. Dennis H. Dennis Hawkins n4mwd AT amsat DOT org (humans know what to do) "A RECESSION is when you know somebody who is out of work. A DEPRESSION is when YOU are out of work. A RECOVERY is when all the H-1B's are out of work." To find out what an H-1B is and how they are putting Americans out of work, visit the following web site and click on the "Exporting America" CNN news video: http://zazona.com/ShameH1B/MediaClips.htm Dennis Hawkins n4mwd AT amsat DOT org (humans know what to do) "A RECESSION is when you know somebody who is out of work. A DEPRESSION is when YOU are out of work. A RECOVERY is when all the H-1B's are out of work." To find out what an H-1B is and how they are putting Americans out of work, visit the following web site and click on the "Exporting America" CNN news video: http://zazona.com/ShameH1B/MediaClips.htm |
![]() wrote in message ... Most of the problems with the one I have are due to age. A lot of the aluminum parts have surface oxidation that must be hand removed and polished. I am planning on having all the aluminum parts hard anodized so that they don't do that again. The tail rotor slider mechanism was rusted and I had to work it pretty hard to get it going again. I am planning on having the TR shaft hard chrome plated so that it will wear better. The steel frame is actually in remarkable shape. I'm not sure what they used to paint it, but I hope to get something that good to repaint it. The only components that I am really worried about are the blades. They only have about 25 hours on them, but also have age cracks in the composite. I haven't contacted BJ about the Scorpion One. I don't think he would have time to talk to me since he is very busy with his helicycle project. I have the blueprints for the Scorpion 2 and was considering getting those for the One, but the One is almost identical to the 2 so I'm not sure if I should bother. The bent cable is for the collective. Its a nutty way of doing things, but it does work. Its just not as good as a regular system. The only real problem with the bent cable rotor head is that it does not use elastomeric bearings. It uses unsealed thrust bearings instead. However, because of the way the cable head works, they only move when you actually move the collective. I'll probably have to spend a bit of time every few hours of operation greasing them, but a friend showed me a trick where I can grease them easily with a hypodermic needle. Hopefully that will make operating it more manageable. I'm still not sure what to do about the license. Dennis H. "Stu Fields" wrote: I had two Scorpion ones and sold them to a guy who had an A&P try to get them going. They still have not been in the air. He had a lot of trouble with slipping tail rotor belts. There are some problems with the old rotor head. B.J Schramm, the designer should be contacted about those problems. I believe I heard him tell one person not to fly the version with the looped cable in the head. I used to fly a Benson gyro with a McCullough engine. It was a quiet sewing machine compared to the sound of the Evinrude engine in the Scorpion. Be very careful. Stu Fields wrote in message ... "Gig Giacona" wrote: You will have to be signed off by and instructor for that aircraft. Do you already own a flyable Scorpion? You will most likely have to get back in the R22 for your check ride. My scorpion is a single seater and is not completely restored yet. I checked with Rotorway, but it does not seem that there is any way to get instruction in a scorpion one. I wonder if a scorpion 2 is close enough. The scopion 2 and scorpion one are basically the same helicopter with the 2 being bigger and wider. It is starting to look like I'm going to have to get my certificate by soloing in the R22 and then just switch to the scorpion afterwards. It seems like thats a waste of money though since I will have to relearn everything in the scorpion. I have all the parts to the scorpion one, but I am not sure what to do with the rotor blades. It looks like there are fine cracks in the composite. I wonder if simply recoating them with new resin will be good enough or if I have to rewrap them. They only have about 25 hours on them. I will also say that the scorpion 1 was definitely not designed for people with normal length legs. Its a real pain getting in and out of it. Dennis H. Dennis Hawkins n4mwd AT amsat DOT org (humans know what to do) "A RECESSION is when you know somebody who is out of work. A DEPRESSION is when YOU are out of work. A RECOVERY is when all the H-1B's are out of work." To find out what an H-1B is and how they are putting Americans out of work, visit the following web site and click on the "Exporting America" CNN news video: http://zazona.com/ShameH1B/MediaClips.htm Dennis Hawkins n4mwd AT amsat DOT org (humans know what to do) "A RECESSION is when you know somebody who is out of work. A DEPRESSION is when YOU are out of work. A RECOVERY is when all the H-1B's are out of work." To find out what an H-1B is and how they are putting Americans out of work, visit the following web site and click on the "Exporting America" CNN news video: http://zazona.com/ShameH1B/MediaClips.htm Dennis, Do you have a PPL? If so, except for safety, you don't need anything for the rotorcraft. Phil |
"PW" wrote:
Dennis, Do you have a PPL? If so, except for safety, you don't need anything for the rotorcraft. Phil I assume that you mean a private pilot license for helicopters. No. I haven't gotten that far. I'm still learning in the R22. I have had some people tell me that the scorpions were much harder to fly than the R22 and others tell me that they were easier. I'm totally confused. Dennis H. Dennis Hawkins n4mwd AT amsat DOT org (humans know what to do) "A RECESSION is when you know somebody who is out of work. A DEPRESSION is when YOU are out of work. A RECOVERY is when all the H-1B's are out of work." To find out what an H-1B is and how they are putting Americans out of work, visit the following web site and click on the "Exporting America" CNN news video: http://zazona.com/ShameH1B/MediaClips.htm |
Dennis, I think he was trying to tell you you don't have to have a catagory
license to fly a single seat helicopter. Only a rating with that of a power plant included is required and a SEL will suffice. You can not fly a two seat though even if solo with out the Rotorcraft-Helicopter rating. Jim wrote in message ... "PW" wrote: Dennis, Do you have a PPL? If so, except for safety, you don't need anything for the rotorcraft. Phil I assume that you mean a private pilot license for helicopters. No. I haven't gotten that far. I'm still learning in the R22. I have had some people tell me that the scorpions were much harder to fly than the R22 and others tell me that they were easier. I'm totally confused. Dennis H. Dennis Hawkins n4mwd AT amsat DOT org (humans know what to do) "A RECESSION is when you know somebody who is out of work. A DEPRESSION is when YOU are out of work. A RECOVERY is when all the H-1B's are out of work." To find out what an H-1B is and how they are putting Americans out of work, visit the following web site and click on the "Exporting America" CNN news video: http://zazona.com/ShameH1B/MediaClips.htm |
![]() "Treetopper" wrote in message ... Dennis, I think he was trying to tell you you don't have to have a catagory license to fly a single seat helicopter. Only a rating with that of a power plant included is required and a SEL will suffice. You can not fly a two seat though even if solo with out the Rotorcraft-Helicopter rating. Jim wrote in message ... "PW" wrote: Dennis, Do you have a PPL? If so, except for safety, you don't need anything for the rotorcraft. Phil I assume that you mean a private pilot license for helicopters. No. I haven't gotten that far. I'm still learning in the R22. I have had some people tell me that the scorpions were much harder to fly than the R22 and others tell me that they were easier. I'm totally confused. Dennis H. Dennis Hawkins n4mwd AT amsat DOT org (humans know what to do) "A RECESSION is when you know somebody who is out of work. A DEPRESSION is when YOU are out of work. A RECOVERY is when all the H-1B's are out of work." To find out what an H-1B is and how they are putting Americans out of work, visit the following web site and click on the "Exporting America" CNN news video: http://zazona.com/ShameH1B/MediaClips.htm What Jim said. ![]() |
![]() "Treetopper" wrote: Dennis, I think he was trying to tell you you don't have to have a catagory license to fly a single seat helicopter. Only a rating with that of a power plant included is required and a SEL will suffice. You can not fly a two seat though even if solo with out the Rotorcraft-Helicopter rating. So now you have me curious. Hypothetically speaking. If a guy, for whatever reason, is a really good helicopter pilot but does not have a license, who then subsequently gets a US fixed wing private pilot license, can he legally fly a helicopter? Dennis Hawkins n4mwd AT amsat DOT org (humans know what to do) "A RECESSION is when you know somebody who is out of work. A DEPRESSION is when YOU are out of work. A RECOVERY is when all the H-1B's are out of work." To find out what an H-1B is and how they are putting Americans out of work, visit the following web site and click on the "Exporting America" CNN news video: http://zazona.com/ShameH1B/MediaClips.htm |
I flew solo with a sign off from the CFI It requires renewing every 90
days. In fact the first time he signed me off he forgot to put the 90 day thing in and I flew for awhile longer than 90 days. I would sure be careful and keep the Scorpion at a hover until you get at least 40hrs. successful. The inital hover time on a completed Safari is 20hrs. before it is flown in the pattern and the Safari doesn't have some of the funny drive package you have in the Scorpion. The first pattern flite involved an auto to insure that there was enough down pitch to get proper blade speed. Good luck (luck is better than skill) Stu. wrote in message ... Most of the problems with the one I have are due to age. A lot of the aluminum parts have surface oxidation that must be hand removed and polished. I am planning on having all the aluminum parts hard anodized so that they don't do that again. The tail rotor slider mechanism was rusted and I had to work it pretty hard to get it going again. I am planning on having the TR shaft hard chrome plated so that it will wear better. The steel frame is actually in remarkable shape. I'm not sure what they used to paint it, but I hope to get something that good to repaint it. The only components that I am really worried about are the blades. They only have about 25 hours on them, but also have age cracks in the composite. I haven't contacted BJ about the Scorpion One. I don't think he would have time to talk to me since he is very busy with his helicycle project. I have the blueprints for the Scorpion 2 and was considering getting those for the One, but the One is almost identical to the 2 so I'm not sure if I should bother. The bent cable is for the collective. Its a nutty way of doing things, but it does work. Its just not as good as a regular system. The only real problem with the bent cable rotor head is that it does not use elastomeric bearings. It uses unsealed thrust bearings instead. However, because of the way the cable head works, they only move when you actually move the collective. I'll probably have to spend a bit of time every few hours of operation greasing them, but a friend showed me a trick where I can grease them easily with a hypodermic needle. Hopefully that will make operating it more manageable. I'm still not sure what to do about the license. Dennis H. "Stu Fields" wrote: I had two Scorpion ones and sold them to a guy who had an A&P try to get them going. They still have not been in the air. He had a lot of trouble with slipping tail rotor belts. There are some problems with the old rotor head. B.J Schramm, the designer should be contacted about those problems. I believe I heard him tell one person not to fly the version with the looped cable in the head. I used to fly a Benson gyro with a McCullough engine. It was a quiet sewing machine compared to the sound of the Evinrude engine in the Scorpion. Be very careful. Stu Fields wrote in message ... "Gig Giacona" wrote: You will have to be signed off by and instructor for that aircraft. Do you already own a flyable Scorpion? You will most likely have to get back in the R22 for your check ride. My scorpion is a single seater and is not completely restored yet. I checked with Rotorway, but it does not seem that there is any way to get instruction in a scorpion one. I wonder if a scorpion 2 is close enough. The scopion 2 and scorpion one are basically the same helicopter with the 2 being bigger and wider. It is starting to look like I'm going to have to get my certificate by soloing in the R22 and then just switch to the scorpion afterwards. It seems like thats a waste of money though since I will have to relearn everything in the scorpion. I have all the parts to the scorpion one, but I am not sure what to do with the rotor blades. It looks like there are fine cracks in the composite. I wonder if simply recoating them with new resin will be good enough or if I have to rewrap them. They only have about 25 hours on them. I will also say that the scorpion 1 was definitely not designed for people with normal length legs. Its a real pain getting in and out of it. Dennis H. Dennis Hawkins n4mwd AT amsat DOT org (humans know what to do) "A RECESSION is when you know somebody who is out of work. A DEPRESSION is when YOU are out of work. A RECOVERY is when all the H-1B's are out of work." To find out what an H-1B is and how they are putting Americans out of work, visit the following web site and click on the "Exporting America" CNN news video: http://zazona.com/ShameH1B/MediaClips.htm Dennis Hawkins n4mwd AT amsat DOT org (humans know what to do) "A RECESSION is when you know somebody who is out of work. A DEPRESSION is when YOU are out of work. A RECOVERY is when all the H-1B's are out of work." To find out what an H-1B is and how they are putting Americans out of work, visit the following web site and click on the "Exporting America" CNN news video: http://zazona.com/ShameH1B/MediaClips.htm |
Dennis,
Do yourself (and your family) a favor and throw away all the Scorpion junk. I'm sory, but if you want to take ridculous risks, try tightrope walking. Seriously. For some reason most here using this forumn are obviously kit chopper hobbysts and won't face the music and tell you that you're gambling with your life fooling around w/ this junk. Try Robinson. Schweitzer, Bell ect. |
![]() Well, "junk" is in the eyes of the beholder I guess. I do have plans for upgrading the Scorpion's rotor head and control systems at some time. It currently uses the old cable-in-shaft system. Upgrading the power transmission system to a transmission/shaft system will be a little longer. The first upgrade on the list is the landing gear. Scorpions have a low (and thus dangerous) landing gear. The gear needs to be more like an R22 so that the steel will cushion an impact with the ground. There are several upgrades that I will be doing before I take it more than a few feet up. The ignition system on the evinrude motor needs attention. Its a solid state electronic module made in the late 60's. I have heard rumors that this unit can fail. I want to convert to some sort of makeshift dual ignition system like the one that the R22 uses. And the list goes on. Don't worry about me and my bird. I also plan to eddy current test or magnaflux all the critical components. Speaking of which, does anybody know if x-ray is a better test than eddy current when testing aluminum parts? Dennis H. (helicopterandy) wrote: Dennis, Do yourself (and your family) a favor and throw away all the Scorpion junk. I'm sory, but if you want to take ridculous risks, try tightrope walking. Seriously. For some reason most here using this forumn are obviously kit chopper hobbysts and won't face the music and tell you that you're gambling with your life fooling around w/ this junk. Try Robinson. Schweitzer, Bell ect. Dennis Hawkins n4mwd AT amsat DOT org (humans know what to do) "A RECESSION is when you know somebody who is out of work. A DEPRESSION is when YOU are out of work. A RECOVERY is when all the H-1B's are out of work." To find out what an H-1B is and how Congress is using them to put Americans out of work, visit the following web site and click on the "Exporting America" CNN news video: http://zazona.com/ShameH1B/MediaClips.htm |
AmeriFlight Crash | C J Campbell | Piloting | 5 | December 1st 03 02:13 PM |
The cost sharing - reimbursment - flight for hire mess | Roger Long | Piloting | 18 | October 21st 03 03:12 PM |
Student Pilot Stories Wanted | Greg Burkhart | Piloting | 6 | September 18th 03 08:57 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
