Why did this helicopter crash ?
Old September 8th 04, 10:04 PM
Beav
"helicopterandy" wrote in message
om...
SEAN,
I DIDN'T MEAN HE ROLLED OFF THE POWER, ONLY THAT HE LOWERED COLLECTIVE
TO FULL DOWN TO COUNTER THE LOSS OF TAIL ROTOR.
Loweriing collective wouldn't do anything for the tail rotor action. If the
tail rotor DID fail, then the pilot would need to remove the TORQUE whivh
the tail rotor now can't counter, and that's when the rollong power off
would come in handy.
BUT HE MAY HAVE ROLLED
OFF POWER (WHO KNOWS) BUT THEN HE HAD TO ROLL POWER BACK ON BEFORE HE
PULLED IN POWER(COLLECTIVE) AGAIN TO ARREST HIS DESCENT AS HE NEARED
THE ROOFTOPS.
This is a turbine heli. Rolling power on and off "that" quickly isn't going
to happen. I suspect the pilot knows that though.
THEN HE GOT THE SEVERE YAW AGAIN. IF HE DIDN'T HAVE THE
POWER BACK ON WHEN HE PULLED COLLECTIVE THE BOTTOM WOULD HAVE FELL OUT
OF THE SHIP VERY QUICKLY
If he had a tail rotor problem, the LAST thing he'd do is add power.Well
maybe if he liked flying a Waltzer he'd add power, but if he's already cut
power, he woudn't be in a hurry to re-apply it (even if he could)
AND HE WOULD HAVE PUT THAT SHIP THROUGH THOSE
ROOFS INSTEAD OF ON TOP OF THEM.
I think he was simply lucky. I don't think a lot of what followed the
initial departure was down to skill at all, but we all need a bit of luck
now and again.
Beav
Please note my E-mail address is "beavis dot original at ntlworld dot com"
(with the obvious changes)
Beavisland now lives at
www.beavisoriginal.co.uk
Old September 9th 04, 10:12 AM
helicopterandy
"Beav" wrote in message ...
om...
SEAN,
Beavis(boy, does your name fit!!),
How long have you been studying helicopters? Five minutes? Saying as
you did above that "lowering the collective wouldn't do anything for
the tail rotor action" speaks volumes of your obvious lack of even the
basics of flying helis.
But then you do a 180 and say that "that's when rolling off the
throttle would come in handy"... Let me assure you of one thing above
all else, YOU NEVER roll off the throttle unless the collective is in
a full down position. EVER.
If I have to explain this to you then you really shouldn't try to get
involved in a discussion you know ZERO about.
Sorry, I guess you cannot learn that with your remote control can you?
Do us all a favor and go buy a Rotorcraft Flying Handbook and READ IT.
Your stupidity is exactly why this site is so poor. Please don't come
to our Yahoo group.
Regards,
Mark
THE ROOFTOPS.
now and again.
Beav
Old September 9th 04, 03:41 PM
Mark
So why is it that you never reduce throttle without lowering collective?
Loss off main rotor momentum?
Old September 9th 04, 05:33 PM
Jim Carriere
Hmmm! I have my H-57 (Bell Jetranger) NATOPS manual in front of me.
Emergency procedures, Complete loss of tail rotor thrust, step 1:
"Twist grip - Close"
Never say never. Ever.
Old September 9th 04, 06:48 PM
Shiver Me Timbers
Sounds like handy Randy should take his own advice
and stay out of "OUR" Yahoo group himself.
Old September 9th 04, 08:05 PM
Steve R.
"Jim Carriere" wrote in message
Emergency procedures, Complete loss of tail rotor thrust, step 1: "Twist
grip - Close"
Well, I agree he may have come across a little sharp on the "never" part and
you make a good point on the "never say never" point. I try to live by that
one but sometimes I slip a little. ;-)
Having said that, what does your H-57 manual say you'd better be doing very
shortly "after" closing the twist grip? If it doesn't say something about
lowering the collective, I'm not sure I'd trust much else it says. :-o :-D
Fly Safe,
Steve R.
Old September 9th 04, 08:03 PM
Beav
om...
om...
SEAN,
whivh
Oooh, never heard THAT before.
Oh yeah? Well explain to me how lowering the collective without reducing
power would affect the effect (action) of the tail and improve matters in
the scenrio. If anything, lowering collective would result in a reduced load
on the rotor system and an INCREASE in rotor speed and a corresponding
increase in tail rotor speed, which as you'll recal is no longer
controllable, so the net result would be in increase in yaw rate. Lowering
collective alone would NOT do anything for the uncontrolled yaw which our
intrepid pilot was encountering.
And that's exactly when it WILL come in handy. If the tail rotor failure
resulted in the heli still turning against torque, (and it did) there are
only two ways to help control the yaw. One is to use the anti-torque pedlas
(not going to happen if they're not doing their job) and the other is to
reduce power/torque. that usually happens when you remove some power.
I imagine that when faced with a looming building, I'd let that particular
rule go by the wayside. I suspect the damage caused by an overspeed might be
"slightly" less than the amount of damage a building makes.
I'll try hard to remember that.
I don't need to.
If this site os so poor, what're you doing here?
Please don't come
to our Yahoo group.
I'll come where I want if it's all the same to you.
Beav
Old September 10th 04, 04:32 AM
helicopterandy
BEAVIS,
YOUR ABOVE POST IS SO WRONG AND MISGUIDED THAT I WON'T BOTHER
RESPONDING TO YOU ANY FURTHER AFTER THIS ONE. BUT DO YOURSELF ONE
FAVOR BEFORE YOU AGAIN MAKE AN IDIOT OUT OF YOURSELF HE
ASK ANY HELICOPTER PILOT WHO FLYS A SHIP THAT HAS A COUNTER-CLOCKWISE
ROTATION MAIN ROTOR WHAT HAPPENS WHEN YOU LOWER COLLECTIVE? HINT: YOU
GET A NICE YAW TO THE LEFT SINCE YOU ARE TAKING TORQUE/POWER OUT OF
THE SYSTEM AND SO YOU NEED TO APPLY RIGHT PEDAL. THAT RIGHT PEDAL
TAKES THE PITCH/THRUST OUT OF THE TAIL ROTOR.
WHEN YOU LOWER COLLECTIVE YOU ARE REDUCING POWER, MORON. STOP THINKING
THAT POWER IS ONLY REDUCED BY REDUCING ROTOR SPEED. GO STUDY JUST A
BIT.
ONE MORE THING, THE FIRST THING MOST PILOT OPERATING HANDBOOKS STATE
IS THAT IN THE EVENT OF LOSS OF TAIL ROTOR EFFECTIVENESS IN FLIGHT THE
FIRST THING THE PILOT SHOULD DO IS LOWER COLLECTIVE.
YOU ARE TRYING TO ARGUE ALGEBRA WITH A MATH PRO WHEN YOU OBVIOUSLY
DON'T KNOW WHAT 2 PLUS 2 EQUALS.
GO BACK TO YOUR TOYS.
REGARDS,
MARK
PS
HOW MANY PIC HOURS DO YOU HAVE IN HELICOPERS? I'D GUESS ZERO. NO WAIT,
I'D GUARANTEE THAT YOU HAVE ZERO. He he
Old September 10th 04, 05:30 AM
Shiver Me Timbers
REGARDS,
MARK
To the Group......... Yunno folks I've been lurking in this group for a
number of years now, posting under various names now and again.
Like most in this group I try to keep a civil tongue in my head and
since I'm only an armchair pilot I sure wouldn't try to argue
technicalities of flight, etc.
I'm basically a knife and forker, a gladhander, who does what he can to
promote a little chitchat, I pat people on the back for their
accomplishments, and achievements.... blah blah blah blah blah.
But yunno folks I just gotta say it..... In the years that I've been in
this group I don't believe I have ever seen anyone like Mark who has
just shown up in this group as a relative newcomer who has had such
a chip on their shoulders.
Mark I don't know what your problem is but Beavis has been a somewhat
regular in this group for some years and you are the first person to my
knowledge who has publicly attacked him, just like your the only person
who has attacked Kevin, who is doing nothing more than sharing his
experiences as a student, which for one, I am personally gratefull for
his efforts.
You post IN ALL CAPS and have been told at least once that doing so is
considered boorish, and bad manners (netiquette), but that doesn't seem
to sink in or make a difference to you.
So before this goes too far, why don't you come back to this group and
tell all of us specifically what it is that you personally are looking
for in this group. What do you expect to get out of it, and what are
you willing to contribute.
So far if appears that your are spoiling for a fight with whoever is
handy, and with all due respect ( in my personal opinion ) you are not
going to make friends, or gain the respect of too many people if you
continue to carry on the way you are doing.
Old September 10th 04, 07:59 AM
Kevin R
"Shiver Me Timbers" wrote in message
REGARDS,
MARK
SNIP
Before this goes to far this has been cross posted to both full size and
model helicopters and we are are areguing why we are getting slagged off "in
our group" but we are posting to "thier group as well" just bear it it mind
before all the toys are missing from your pram
and as for helicopterandy "PLONK" what a prat???
Keep up the good work Beavis and just kill file him hes not worth the typing
small prop plane vs helicopter crash statistics Gregory Lee Piloting 1 June 25th 04 10:34 PM
helicopter crash in Idaho Bill Chernoff Rotorcraft 0 April 29th 04 05:49 PM
Musings of a Commercial Helicopter Pilot Badwater Bill Home Built 6 February 27th 04 09:11 AM
Helicopter crash video James Blakely Piloting 17 December 30th 03 03:21 PM
Crew Members in Helicopter Crash Identified Jim Carriere Naval Aviation 0 July 17th 03 06:46 PM
