Key Assignment and Add On Aircraft Question for FS2K2
Old August 9th 03, 12:41 AM
Handsome
Meant to add that "Engine Autostart" will always be available so long as you
dont assign "Ctrl+E" to anything else. You can still assign individual
items over and above.
All my personalised key assignments are on "F" keys.
For example F5-F8 are assigned, by default to flaps.
Since I have all those controls on my yoke I can re-assign thes with no
danger of going into the unknown.
One tip.......
If you do have a few personalised assignments etc. it is advisable to make a
back up copy of your FS2002/04.cfg file.
It often seems to go pearshaped within the sim for no apparent reason and
saves you starting all over again. Just overwrite with a copy of the backup
file.
Martin
Martin
ink.net...
| Thanks Angus. I'm having some problems and I think it might have been
caused
| by my changing some of the key functions to other keys that the defaults.
I
| have an add on Tornado for example, that goes through an automatic start
| when a specific cockpit switch is clicked. I would assume it's tied to the
| (E) key in some way, but it also brings avionics and generators on line
| during the sequence. If I had for example, changed the avionics on/off to
| another key, I'm thinking this might foul up the sequence and cause some
| issues with avionics.
| Just a wild guess here, but I'm trying to learn how these things are
| actually done. Come to think of it, I've never seen a warning of any kind
| concerning changing key assignments from default settings...so I might be
| way off with this theory :-))
| DH
| "Angus Lepper" wrote in message
| Yes, they regularly do, by use of guages. For example, install PM2's
| (excellent by the way) Concorde, and you'll find a 'Concorde nose Up'
| entry.
| Hope that helps!
| k.net...
| I've noticed that in the assignments section for the key assignments,
| after
| I install add on aircraft, I'm seeing entries there that don't show up
| as
| default assignments for the simulator. For example, I have an avionics
| on/off, a master battery on/off, and a master battery and gen on/off
| listed.
| Here's my question.
| When you install an add on from say Lago, FSD, or Captain Sim into
| FS2K2,
| does their installation change or add assignments to the sim? I am
| having
| some issues that I think might be related to my having changed some of
| these
| assignments from whatever the default assignment was. For example, I
| changed
| avionics to simply an (A). Should you...if you are using add on
aircraft
| in
| FS2K2, leave the default key assignments alone and simply use whatever
| is
| showing, and can changing an assignment in the sim cause issues and
| conflicts?
| I'm thinking that to resolve my "issues", I might have to restore to
| default key assignments in the sim, then reinstall ALL my add on
| aircraft,
| letting the installation assign or add assignments as they go into the
| sim.
| Am I on the right track here?
| Many thanks,
| Dudley
Old August 9th 03, 01:24 AM
Dudley Henriques
Thanks very much for all your kind info.
D
"Handsome" wrote in message
you
One tip.......
a
backup
file.
Martin
Martin
ink.net...
caused
defaults.
I
to
kind
be
| DH
| entry.
| Hope that helps!
| k.net...
assignments,
| after
up
| as
avionics
| listed.
| Here's my question.
| FS2K2,
| having
of
| these
| changed
aircraft
| in
whatever
| is
| conflicts?
| aircraft,
| sim.
| Many thanks,
| Dudley
