FS2004 ATI/Radeon Driver Problem
Old August 9th 03, 07:39 AM
tfp ntl
Default FS2004 ATI/Radeon Driver Problem
I have got a bad dose of the Radeon problems mentioned in a lot of posts,
the "bleeding" text, which although a pain is not the end of the world, but
the"swimming" scenery on my machine (High end Dell, 512mb, Radeon 9700 pro
128mb) makes FS2004 almost unusable.
Some folks on Radeon drivers have posted that they just have the text
problem, otherwise everything else is fine.
Would be really useful if those that have a reasonably stable FS2004
experience, on Radeon drivers, posted their graphics settings, so others
could try them, trial and error hasn't helped me.
fyi, Like may others I have posted the problem on ATI support pages, but no
response other than a system acknowledgment, makes for excellent Customer
Service on their part.
TIA... Tim
Old August 9th 03, 01:22 PM
Flying Scotsman
I have an AMD XP2500, XP Professional, 556RAM, ATI Radeon 9600 Pro.......
and my experience with 2004 is totally dismal.
About every 4 four seconds my frame rate drops from 19fps to 1fps, with the
result that the sim lurches horribly from forward progress to dead stop.
Additionally, MS seems to lose my MS Force Feedback 2 joystick from time to
time, leaving me without the ability to control my already stuttering plane.
When it hasn't lost the FF2 it often seems to lose its FF centering tension
ability . Since I upgraded to the latest Radeon driver (6.14.10.6360 is what
the Device Manager shows it as) I also get smeared graphics when I drag a
panel such as the GPS across the screen from one position to another - the
entire screeen dissolves into horizontal color bands that then restore to a
normal screen after a few seconds.
All of the above happens whether the sliders are maxed out to the right or
all the way to the left.
This thing is a nightmare. Any suggestions welcomed as to how to set the
sliders or how my Bios should be adjusted.
Mike
P.S. Katy, I'm sure you are reading these posts, even if MS might not be
....... is anyone consolidating symptoms such as mine and forwarding them to
MS?
Old August 9th 03, 03:46 PM
Gavin
I have a Radeon 9000 Pro. The MAXIMUM frame rates I get is 9fps - even with
all settings at LOW!!!!
This is on a P4 1.7 with 1GB ram!
I'm very ****ed about this. : (
"tfp ntl" wrote in message
but
no
TIA... Tim
Old August 9th 03, 07:06 PM
Katy
To help with the shimmering of texture (especially bad with ATI cards)
try those settings: mipmap to 4 in FS, no anti-aliasing, autogen
scenery to medium. In the drivers properties push anisotropic
filtering to the maximum available, set anti-aliasing to a medium
setting...
Best
Katy Pluta
FS2004 FAQ at http://www.simflight.com/news5/modules.php?name=FAQ
Old August 9th 03, 07:08 PM
Katy
MS?
I do :-) For you problem did you try disabling the FF? ATI has new
drivers in the works (finally) from what I read...
Best
Katy Pluta
Old August 9th 03, 07:31 PM
Flying Scotsman
Katy -
I did NOT try disabling the FF2 - should I? The problem seems sporadic and
FF2 will always work after a reboot.
Thanks
Mike
Old August 9th 03, 08:49 PM
Bill
"Katy" wrote in message
but
pro
no
setting...
Best
Katy Pluta
Posted by ATI FYI
http://www.ati.com/support/infobase/4256.html
Dont know if this will ease the pain, only MSoft can do that :-)
Bill
Old August 10th 03, 01:16 AM
Kevin Reilly
I can vouch for the mip-mapping thing being critical to solving texture
problems with the ATI cards. At 1024x768 some textures, particularly
night textures, looked terrible on my 9700Pro. The after-dark NYC
skyline was almost unrecognisable beneath a mess of flickering light
textures. Dropping the mip-mapping to 4 all but cured it. Personal
preferences will dictate how many of the other features are turned on or
off but this one is a must-do.
On a related note, if anyone's really ****ed off with the 'mode change'
flicker that FS2004 does every time you re-start a flight or choose a
menu option on a Radeon card, try changing the full-screen depth to
16bit instead of 32bit. It doesn't cure it but it reduces the number of
flickers, and they seem to cycle slightly faster. Not the best solution,
but it reduces the frustration a bit while we wait for new drivers
and/or a patch.
Kev
__________________________________________________ ________________________
"Caution: remove infant before folding for storage."
Warning on portable baby stroller
Old August 10th 03, 04:33 AM
ccsuwxman
Katy:
Can you tell me why my 2D panels disappear when I turn antialiasing on? I'm
running win98SE with an AMD 1.2ghz processor, 512 mb ram, and a radeon 9000
64mb card.
Thanks for any help.
Steve
but
pro
no
setting...
Best
Katy Pluta
Old August 10th 03, 04:37 AM
Chris Ehlbeck
There is something else going on. I have a Radeon 9000 and usually get
17fps and most of my settings are in the medium range, but I do have some
high textures for the aircraft. The system is an Athlon 1.2 with 256 meg of
RAM
Chris
I'm learning to fly! See what's going on.
www.home.bellsouth.net/p/pwp-cehlbeck
"Gavin" wrote in message
with
posts,
but
pro
no
Customer
TIA... Tim
WinXP / SkyBound USB problem Ted Products 2 October 3rd 04 08:47 AM
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) Snowbird Home Built 78 December 3rd 03 09:10 PM
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) Snowbird Owning 77 December 3rd 03 09:10 PM
Real World Specs for FS 2004 Paul H. Simulators 16 August 18th 03 09:25 AM
Ahhhhh! FS2004 I'm impressed! Dr. Anthony J. Lomenzo Simulators 1 August 9th 03 04:20 AM
