FS2004, fix for hypersensitive rudder?
Old August 13th 03, 02:30 AM
Don Parker
Hey K!
Glad to see I'm not alone in my misery - check my post over in
alt.games.microsoft.flight-sim and I've just posted the very same bitch! I
assume you're using a CH set of pedals, since they've got the lions share of
the market. I dumped their yoke a few years ago and paid Xtimes more for a
commercial quality, and never regretted it, but decided pedals weren't as
critical - WRONG! I'm ready to ****can these, and go ahead and bite the
bullet again... Not saying 2k4 may not need some tweeking too, but........
Cheers'n beers.
Don
"K" wrote in message
anyone?
This is annoying me in the extreme, despite having the sensitivity all the
way down the slightest movement on the rudder almost spins you off the
taxiway especially with the Cessnas. Trying to stick to the runway
centreline is almost impossible with the slightest crosswind. FS2002,
which
i still have installed, is perfectly weighted.
Anyone have a fix or is it solemthing that needs patching?
K
Old August 13th 03, 03:10 AM
Brett Holcomb
Did you adjust the null zone, too? I have the CH Pro pedals and they work
fine with the various a/c including the DC-3. Did you try moving the
sensitivity to the right instead of the left?
Don
anyone?
the way down the slightest movement on the rudder almost spins you off
the taxiway especially with the Cessnas. Trying to stick to the runway
which
K
Brett I. Holcomb
Microsoft MVP
AKA Grunt
Remove R777 to email
Old August 13th 03, 04:30 AM
Don Parker
Brett,
I've adjusted every slider every way it can be adjusted. What's perplexing
is the fact that the primary joystick, yoke in this case, has the simple &
advanced menues and remains in the advanced mode when you exit and return;
however, the secondary, pedals in this case, lets you make your choices in
advanced, but reverts back to simple after you leave the menu - but,
'apparently' takes the average of the r/s brakes & rudder to reset the
simple setting - so I have no idea of what is actually getting programmed to
the contols. If this sounds stupid, it IS! I updated the CH controller mgr
to 2.1, after finding there even was a controller on the cd with the pedals
(but wasn't needed unless you couldn't 'calibrate' (?) the pedals), but the
CH controller can't even find it's own stuff (windows can), etc.., etc....
I finally found what appears to be a 'sweet spot' in the settings that
almost kinda works (more details in alt.games.m/s, etc..) .........
"Brett Holcomb" wrote in message
Don
anyone?
which
K
Brett I. Holcomb
Microsoft MVP
AKA Grunt
Old August 13th 03, 05:29 AM
Don Parker
PS - I am NOT using a CH yoke. It's a Cirrus PFC Jet with gameport
interface (couple of years old...) with a USB adapter, so that MAY be some
of the problem with the CH manager not recognizing the primary controller,
but it would be a stretch..............
"Don Parker" wrote in message
Brett,
perplexing
to
mgr
pedals
work
Don
anyone?
all
off
runway
which
K
Brett I. Holcomb
Microsoft MVP
AKA Grunt
Old August 16th 03, 12:28 AM
Twilson
I Think the problem is with FS2004 not the controls. I have Cougar HOTAS with
elite rudder pedals and cannot keep any aircraft on the runway flying from
Flagstaff, Ariz airport due to runaway nose wheel steering. There is no
problem when departing Meigs or Phoenix sky Harbor. So I don't think there is
anything wrong with my controls. This is one that MS needs to fix
Old August 14th 03, 10:46 AM
K
Hey K!
I
of
a
but........
Cheers'n beers.
Don
I'm only using a twist joystick! Out of interest I tried it with the
keyboard, again with sensitivity turned all the way down and it was no
different. So this tells me the problem is with FS2004 and not with any
controller or controller software.
I feel a patch coming on...
K
Air Bus 300 crash in NY now blamed on co-pilot's improper use of rudder Corky Scott Piloting 30 October 28th 04 04:10 AM
B2 Split Rudder Emilio Military Aviation 8 April 12th 04 10:43 AM
A lesson learned - Invisible rider with foot on right rudder Dave Butler Piloting 2 October 16th 03 09:58 PM
Cessna 150 Price Outlook Charles Talleyrand Owning 80 October 16th 03 02:18 PM
Bridges in FS2004 Kevin Reilly Simulators 18 October 2nd 03 11:00 PM
