Did you adjust the null zone, too? I have the CH Pro pedals and they work
fine with the various a/c including the DC-3. Did you try moving the sensitivity to the right instead of the left? Don "K" wrote in message ... anyone? This is annoying me in the extreme, despite having the sensitivity all the way down the slightest movement on the rudder almost spins you off the taxiway especially with the Cessnas. Trying to stick to the runway centreline is almost impossible with the slightest crosswind. FS2002, which i still have installed, is perfectly weighted. Anyone have a fix or is it solemthing that needs patching? K -- Brett I. Holcomb Microsoft MVP AKA Grunt Remove R777 to email |
Brett,
I've adjusted every slider every way it can be adjusted. What's perplexing is the fact that the primary joystick, yoke in this case, has the simple & advanced menues and remains in the advanced mode when you exit and return; however, the secondary, pedals in this case, lets you make your choices in advanced, but reverts back to simple after you leave the menu - but, 'apparently' takes the average of the r/s brakes & rudder to reset the simple setting - so I have no idea of what is actually getting programmed to the contols. If this sounds stupid, it IS! I updated the CH controller mgr to 2.1, after finding there even was a controller on the cd with the pedals (but wasn't needed unless you couldn't 'calibrate' (?) the pedals), but the CH controller can't even find it's own stuff (windows can), etc.., etc.... I finally found what appears to be a 'sweet spot' in the settings that almost kinda works (more details in alt.games.m/s, etc..) ......... "Brett Holcomb" wrote in message ... Did you adjust the null zone, too? I have the CH Pro pedals and they work fine with the various a/c including the DC-3. Did you try moving the sensitivity to the right instead of the left? Don "K" wrote in message ... anyone? This is annoying me in the extreme, despite having the sensitivity all the way down the slightest movement on the rudder almost spins you off the taxiway especially with the Cessnas. Trying to stick to the runway centreline is almost impossible with the slightest crosswind. FS2002, which i still have installed, is perfectly weighted. Anyone have a fix or is it solemthing that needs patching? K -- Brett I. Holcomb Microsoft MVP AKA Grunt Remove R777 to email |
PS - I am NOT using a CH yoke. It's a Cirrus PFC Jet with gameport
interface (couple of years old...) with a USB adapter, so that MAY be some of the problem with the CH manager not recognizing the primary controller, but it would be a stretch.............. "Don Parker" wrote in message ... Brett, I've adjusted every slider every way it can be adjusted. What's perplexing is the fact that the primary joystick, yoke in this case, has the simple & advanced menues and remains in the advanced mode when you exit and return; however, the secondary, pedals in this case, lets you make your choices in advanced, but reverts back to simple after you leave the menu - but, 'apparently' takes the average of the r/s brakes & rudder to reset the simple setting - so I have no idea of what is actually getting programmed to the contols. If this sounds stupid, it IS! I updated the CH controller mgr to 2.1, after finding there even was a controller on the cd with the pedals (but wasn't needed unless you couldn't 'calibrate' (?) the pedals), but the CH controller can't even find it's own stuff (windows can), etc.., etc.... I finally found what appears to be a 'sweet spot' in the settings that almost kinda works (more details in alt.games.m/s, etc..) ......... "Brett Holcomb" wrote in message ... Did you adjust the null zone, too? I have the CH Pro pedals and they work fine with the various a/c including the DC-3. Did you try moving the sensitivity to the right instead of the left? Don "K" wrote in message ... anyone? This is annoying me in the extreme, despite having the sensitivity all the way down the slightest movement on the rudder almost spins you off the taxiway especially with the Cessnas. Trying to stick to the runway centreline is almost impossible with the slightest crosswind. FS2002, which i still have installed, is perfectly weighted. Anyone have a fix or is it solemthing that needs patching? K -- Brett I. Holcomb Microsoft MVP AKA Grunt Remove R777 to email |
I Think the problem is with FS2004 not the controls. I have Cougar HOTAS with
elite rudder pedals and cannot keep any aircraft on the runway flying from Flagstaff, Ariz airport due to runaway nose wheel steering. There is no problem when departing Meigs or Phoenix sky Harbor. So I don't think there is anything wrong with my controls. This is one that MS needs to fix |
Air Bus 300 crash in NY now blamed on co-pilot's improper use of rudder | Corky Scott | Piloting | 30 | October 28th 04 04:10 AM |
B2 Split Rudder | Emilio | Military Aviation | 8 | April 12th 04 10:43 AM |
A lesson learned - Invisible rider with foot on right rudder | Dave Butler | Piloting | 2 | October 16th 03 09:58 PM |
Cessna 150 Price Outlook | Charles Talleyrand | Owning | 80 | October 16th 03 02:18 PM |
Bridges in FS2004 | Kevin Reilly | Simulators | 18 | October 2nd 03 11:00 PM |
