USB CH Products Flight Yoke issue
Old September 13th 03, 02:41 AM
Dan Moos
Default USB CH Products Flight Yoke issue
Hey gang, my USB flight yoke (CH Products Flight Sim Yoke LE) has a strange
problem.
When I boot up, it is fine, but if I don't use it for something like 5
minutes, it stops working completely. I have to unplug it, and plug it back
in to get windows to re-discover it. Then all is fine. My CH Products USB
rudder pedals have no such issue.
Old September 13th 03, 12:12 PM
Don Parker
strange problem.
it back in to get windows to re-discover it. Then all is fine. My CH
Products USB rudder pedals have no such issue.
Have you tried switching ports, plug the yoke where the pedals are, then you
can see if the problem follows the yoke?
Cheers'n Beers [_])
Don
Old September 13th 03, 06:43 PM
Dan Moos
you
Yes. In fact, this is even a different motherboard than I had when the
problem started. Both boards have quite a few USB ports, and none gave
different results.
I figure its a software issue, or my yoke has something physicaly wrong with
it
Old September 13th 03, 08:20 PM
Don Parker
wrong with it
Be nice to find someone with a USB yoke you could borrow. I think I'd lean
more towards the yoke than software, but I also have ample scar tissue from
being bit in the butt on wrong assumptions... Good luck!
Cheers'n Beers [_])
Don
Old September 15th 03, 11:20 PM
Woody
"Dan Moos" wrote in message
news
strange
problem.
back
Hi,
Could it be that your system is dropping out the USB port to save power?
If you have Windows XP, it could be a possibility because of XP's power
management features.
What you could try is going to the Hardware Device Manager in Control Panel,
fine the entries called "USB Root Hub" in the Universal Serial Bus section.
Right click on each, go to properties, then power management tab. Remove the
tick from the option called "Allow the computer to turn off this device to
save power"
With that option turned off, the system cannot turn off your USB ports.
It might not be the answer, but it is worth a try.
Also, yokes often have problems when run through an ecternal hub. If you are
running it via a hub, try hooking it directly the the USB ports on the back
of the case. (i.e. the motherboard USB ports)
Regards,
Dean Bielanowski, RN. BNurs. QUT, PGCert(CCU)
Editor, Computer Pilot Magazine.
The Monthly Magazine for Desktop Pilots & Flight Simulation Enthusiasts
http://www.computerpilot.com
PC Aviator - The Flight Simulation Company
Providing Flight Simulation Hardware & Software for Over 12 Years!
http://www.pcaviator.com.au (Australasian Customers)
http://www.pcaviator.com (U.S., Canadian and International Customers)
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 12:14 PM
MS Flight Sim 2004.........what yoke is best? TripFarmer Products 0 September 29th 03 02:59 PM
IFR flight in MSFS '98 questions Sydney Hoeltzli Simulators 9 July 31st 03 12:05 AM
