Starting FS9
Old September 22nd 03, 10:45 AM
Hector Relva
Default Starting FS9
Hi all,
I believe there is a "new" cfg file for FS9 that makes possible to start the
program without using the CD # 4.
Can somebody help me to find where this magic cfg file is please.
Thanks, HR
Old September 22nd 03, 02:21 PM
Randy L.
Hector,
The FS9.cfg file is no longer in the same directory as the program
executable, as it has been in previous versions. I run Windows Me, so for my
computer the FS9.cfg file is in C:\Windows\Application Data\Microsoft\FS9.
It will be in a different directory if you are running Windows XP. Having
said that, there is nothing that you can do to the FS9.cfg file that will
allow this program to run without Disc #4 in the drive. You CAN get FS9 to
run without a CD in the drive, but you must replace the FS9.exe program
executable file with a patched version that allows you to run the program
without the CD. I found a no-CD patch at:
http://spacetarget.com/games/pc_flig...tor_2004.shtml. If that one
doesn't work you can try a Google search for "Flight Simulator 2004 No CD
Patch".
Randy L.
"Hector Relva" wrote in message
Hi all,
Thanks, HR
Small airport cold-weather starting - Tanis good enough? Mitchel Gossman Piloting 8 December 2nd 04 05:07 AM
Starting Engine Question (O-320, Warrior) Lisa Piloting 13 April 1st 04 06:45 AM
Starting a club Casey Wilson Piloting 9 February 2nd 04 08:56 PM
Starting new info site need info from the pros MRQB Piloting 7 January 5th 04 03:20 AM
Boeing 307 Starting Up! Jay Honeck Piloting 5 August 8th 03 06:53 PM
