Saitek stick/throttle....rudder issue
Old November 16th 03, 10:29 PM
Dashi
"Wayne" wrote in message
I don't fly prop very often. Usually large commerical jets, (777, 747,
737-800)
So do I keep 'left rudder' on (the rudder toggle button on the underside
of
the throttle control)
Thanks.
Oops! I mean a right rudder input. The single engine prop aircraft will want
to turn to the left.
Using the rudder control on the Saitek is tedious, I use rudder pedals now.
Dashi
"Dashi" wrote in message
If you are trying to fly a single engine prop, that is the way it should
work. You need to keep a constant left rudder input during take-off and
less
of an input in straight and level flight.
I've used the Saitek stick/throttle for a couple of years.
Dashi
Hey,
This is a pretty good stick/throttle combination, but it causes a
quirky
behavior in that the aircraft rudder becomes very unstable on takeoff
roll.
It slips from side to side, making takeoff a real challange. I'm
pretty
new
with this stick and would appreciate if anyone else having this
problem
could give some feedback on it.
Thanks,
Air Bus 300 crash in NY now blamed on co-pilot's improper use of rudder Corky Scott Piloting 30 October 28th 04 04:10 AM
B2 Split Rudder Emilio Military Aviation 8 April 12th 04 10:43 AM
A lesson learned - Invisible rider with foot on right rudder Dave Butler Piloting 2 October 16th 03 09:58 PM
Aviation Conspiracy: Bush Backs Down On Tower Privatization Issue!!! Bill Mulcahy General Aviation 3 October 1st 03 05:39 AM
