FS2004, have you "looped the 747"?
Old March 10th 04, 05:15 PM
Randy Wentzel
Apparently, recordings are saved as "FSR" files in your My Documents
folder.
OK, I was searching for the .fsr file within the root FS9 folder. I have
gone ahead and uploaded the file to
http://www.sonic.net/randyw/fs2004/747Loop.FSR
Just save the file to your "\My Documents\Flight Simulator Files" folder
I assume. Open FS2004, start a flight anywhere, click on "options -
fligth videos" and select the 747Loop video. You can change views using
the "S" key.
Let me know how that works out.
Best,
Randy
Old March 12th 04, 03:57 AM
John Doe
folder.
the "S" key.
Worked great. Went from 4,000 to 17,000 to 400 feet during the 747 loop.
Would be even better if they allowed voice recording (I am guessing they do
not) so you could give me a clue about what, if anything of interest, is
happening.
Thanks, you dunnit.
Old March 12th 04, 04:09 AM
Randy Wentzel
happening.
Thanks, you dunnit.
Yeah, I almost hit the terra firma but managed to just make it! The only
thing that I did that you might not be able to tell in the video is that
I hit the flaps and speed brakes on the way back down to slow down as
much as possible. Before the loop I had to put the plane into a gentle
dive to build up a lot of speed (just look at the ASI).
Any other requests?
Randy
Old March 24th 04, 04:16 PM
Clive
"Randy Wentzel" wrote in message
Quilljar wrote:
I think it is true to say that it is possible to 'roll' any aircraft.
Because if done properly, there should be no more than a very slight
extra
strain on the airframe. 'Looping' a 747 is another matter entirely! You
have
to pull a lot of G in a loop... I would, perhaps, be prepared to risk it
in
a Flight Simulator though, providing I had a stiff whisky and a sandwich
by
my side, and a couple of attractive (non PC) nurses to fan my brow
afterwards :-)
Actually, even a loop can be low G when executed correctly. I've met and
spoke with on a number of occasions an ex-test pilot for the Boeing
MD-NOTAR Helicopters. The test pilots would have informal contests with
one another to see who could pull off the lowest G's while looping their
helicopters. He could keep the max + G forces below 1.5, and supposably
the other pilot could keep it below 1 G.
The key is forward momentum combined with making the loop more oval then
round. Keep your airspeed high (well above maneuvering speed), start a
shallow climb and slowing increase the angle of climb until you reach
the point at which you are nearly at the top of the loop. Since the
airspeed is nearly at the stall speed now, you can pull back on the yoke
more sharply with significantly increasing the G-load. Bring the bird
over the top and then come out of the loop slow and gradual.
As long as you keep + G-forces on an airplane, it doesn't know if it's
upside down or right side up. Think about the G force a 747 has to
endure when it hits severe turbulence at 450kts at 33,000. Those birds
can handle a lot.
A quick search on google found this dumbed down explanation of why it's
probably not a good idea to roll or loop a 747:
http://www.straightdope.com/classics/a1_262.html
Here's the great video of the 707 doing a roll as part of an impromptu
promotional scheme:
http://www.alexisparkinn.com/photoga...707%20Roll.mpg
Now why not go try looping and rolling the 747 or 777 in FS2004? Can't
hurt! Maybe start on the ground and then use the Map mode to give
yourself a lot of altitude (but not too much because you want good air
density) - Say, 18,000' and 300 kts.
Best,
Randy
Surely to do a low G loop, you would need LOT'S of power or a very high
power to weight ratio - not what airliners have??
Clive
Disappointed with FS2004 Phiber Optik Simulators 5 October 12th 03 04:13 PM
Abacus and FS2004 compat question George Lewis Simulators 2 October 3rd 03 02:22 AM
Bridges in FS2004 Kevin Reilly Simulators 18 October 2nd 03 11:00 PM
Help needed - fs2004 zaps fs2002 props Ian D Simulators 1 September 11th 03 10:20 PM
FS2004 Pauses When Real World Weather Won't Download Andrew Watson Simulators 1 September 8th 03 09:08 AM
