![]() "Erik Beauchesne" wrote in message .. . John, the instructor tells you to check for other airplanes to your left and right. If you don't check both ways before doing the steep turn, your checkride will end. To do so press the 4 and 6 keys on the numeric keypad before you start to turn. Erik Thanks Erik, Tried that but still same result - swift exit. John |
John,
the steep turn is a 45 degree bank turn, if you don't turn exactly on a 45 degree bank the checkride will end as well. I did this checkride in FS2002 and FS2004 and succeded. There are also the speed that must remain at 100 Knots and altitude that must be stable as well. Hope this will help you to complete this checkride. Erik "John Storey" a écrit dans le message de ... "Erik Beauchesne" wrote in message .. . John, the instructor tells you to check for other airplanes to your left and right. If you don't check both ways before doing the steep turn, your checkride will end. To do so press the 4 and 6 keys on the numeric keypad before you start to turn. Erik Thanks Erik, Tried that but still same result - swift exit. John --- Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.752 / Virus Database: 503 - Release Date: 2004-09-03 |
![]() "Erik Beauchesne" wrote in message ... John, the steep turn is a 45 degree bank turn, if you don't turn exactly on a 45 degree bank the checkride will end as well. I did this checkride in FS2002 and FS2004 and succeded. There are also the speed that must remain at 100 Knots and altitude that must be stable as well. Hope this will help you to complete this checkride. Erik "John Storey" a écrit dans le message de ... "Erik Beauchesne" wrote in message .. . John, the instructor tells you to check for other airplanes to your left and right. If you don't check both ways before doing the steep turn, your checkride will end. To do so press the 4 and 6 keys on the numeric keypad before you start to turn. Erik Thanks Erik, Tried that but still same result - swift exit. John --- Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.752 / Virus Database: 503 - Release Date: 2004-09-03 Thanks again, Erik I obviously need to go back and practice my steep turns. John |
Check ride | aluckyguess | Piloting | 14 | December 24th 04 02:47 AM |
Check ride today | smf | Instrument Flight Rules | 3 | September 12th 04 01:40 AM |
Use of hand-held GPS on FAA check ride | Barry | Rotorcraft | 1 | August 30th 03 01:24 AM |
Use of hand-held GPS on FAA check ride | Barry | Piloting | 3 | August 9th 03 10:14 PM |
Use of hand-held GPS on FAA check ride | Barry | Instrument Flight Rules | 1 | August 9th 03 09:25 PM |
