![]() "Dave Martin" wrote in message ... The danger here is that we are talking theory where we may start to confuse pilots. It is harder to stall with 60 degrees of bank. Gliders like the K13, by design run out of elevator in straight and level flight. They are difficult when flown with heavy pilots to develop more than a mushing stall in sraight and level flight. Put light -- bottom weigh pilots in and they become a different glider. The Puchacz on the other hand has plenty of rear elevator even when banked, quite steeply. There can be some dangerous assumptions that gliders will not spin. The pilot must know the limitations and characteristics of the glider he/she is flying. This can only be achieved by carefully experimenting with different configurations and different flight situations. Gliders with reputations that they will not spin, can catch pilots out who load them wrongly, fly them badly or worse combine both. Dave Martin You make a good point. Some gliders are very resistant to stalls and others will stall readily - especially with light pilots. It seems that trainers made in Eastern Europe come equipped with large, effective elevators that can stall the wing in any attitude. On the other hand, many German single place glass gliders often have small elevators with limited up authority. For example the Blanik L-23, IS28 b2 Lark and, as another poster pointed out the Puchacz, can be stalled from a steep bank easily. For this reason, they make good trainers since the student must learn to be constantly aware of pre-stall buffet. However, the point the Derek was making is that it is more difficult, but not impossible, to stall in a steep turn. I've had this discussion with pilots who feared steep banks. I suggest that thermalling is steep banks is easier in that the glider is more difficult to stall and fewer corrections are needed to stay in the thermal since the turn diameter is smaller. Bill Daniels |
On Tue, 29 Jul 2003 08:05:21 -0600, "Bill Daniels"
wrote: "Dave Martin" wrote in message ... The danger here is that we are talking theory where we may start to confuse pilots. It is harder to stall with 60 degrees of bank. Gliders like the K13, by design run out of elevator in straight and level flight. They are difficult when flown with heavy pilots to develop more than a mushing stall in sraight and level flight. Put light -- bottom weigh pilots in and they become a different glider. The Puchacz on the other hand has plenty of rear elevator even when banked, quite steeply. There can be some dangerous assumptions that gliders will not spin. The pilot must know the limitations and characteristics of the glider he/she is flying. This can only be achieved by carefully experimenting with different configurations and different flight situations. Gliders with reputations that they will not spin, can catch pilots out who load them wrongly, fly them badly or worse combine both. Dave Martin You make a good point. Some gliders are very resistant to stalls and others will stall readily - especially with light pilots. It seems that trainers made in Eastern Europe come equipped with large, effective elevators that can stall the wing in any attitude. On the other hand, many German single place glass gliders often have small elevators with limited up authority. For example the Blanik L-23, IS28 b2 Lark and, as another poster pointed out the Puchacz, can be stalled from a steep bank easily. For this reason, they make good trainers since the student must learn to be constantly aware of pre-stall buffet. However, the point the Derek was making is that it is more difficult, but not impossible, to stall in a steep turn. I've had this discussion with pilots who feared steep banks. I suggest that thermalling is steep banks is easier in that the glider is more difficult to stall and fewer corrections are needed to stay in the thermal since the turn diameter is smaller. Bill Daniels This is an extremely important caution. Gliders do not all have the same behavior. Along this line, I have been cautioned that in a turn, the inside wing, even in a coordinated turn, is flying at a higher angle of attack than the outside wing. The degree of difference would vary with the bank angle. Thus, some gliders may not only stall in a steep turn, they can flick into a spin "out the bottom" in the blink of an eye. This may not be the case with many (most?) "modern" ships, but none-the-less is worth keeping in mind I guess. |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Procedure Turn | Bravo8500 | Instrument Flight Rules | 65 | April 22nd 04 03:27 AM |
Calculating vertical time and distance in a stall turn (US Hammerhead) | Dave | Aerobatics | 3 | November 20th 03 10:48 AM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
