SZD-55 Wheel Brake Adjustment
Old August 3rd 03, 05:05 PM
WDM
Default SZD-55 Wheel Brake Adjustment
Need input on wheel brake adjustment for an SZD-55. The wheel brake is
strong, but comes on too soon when opening spoilers. I would like to delay
the brake activation some. The cable adjuster at the wheel is already backed
all the way out. Do I increase the disk spacing from pads on the wheel
assembly by adjustment at the hub first then adjust cable? Any help would be
greatly appreciated.
Thanks in advance, Wells Morse
**remove "55" from email return address**
Old August 4th 03, 04:43 AM
Larry Goddard
I'm pretty sure you need to go the other way with it.... If it is a standard
cable type affair.
Regards,
Larry
"01" USA
Old January 20th 11, 09:25 AM
IVO IVO is offline
Junior Member
First recorded activity by AviationBanter: Jan 2011
Send a message via Skype™ to IVO
hy,
I have the same problem with brake on my szd-55-1.
When I pull the air brake to half position, the weel brake too much.
Is possibile modificate the system or something?
My be replace with disc brake TOST?
By
Ivo from croatia
Piper 6.00x6 Nose Wheel and Fork? mikem General Aviation 5 March 5th 04 11:34 PM
Piper 6.00x6 Nose Wheel and Fork? mikem Restoration 5 March 5th 04 11:34 PM
Building the Po' Boy Bending Brake Veeduber Home Built 14 March 1st 04 06:15 PM
VW-1 C-121J landing with unlocked nose wheel Mel Davidow LT USNR Ret Military Aviation 1 January 19th 04 05:22 AM
The Little Wheel in Back Veeduber Home Built 6 September 8th 03 10:29 AM
