Constant speed or constant attitude?
Old August 16th 03, 02:21 AM
Mike Borgelt
On 15 Aug 2003 22:58:24 GMT, John Galloway
What you guys are discussing is the 'Yates effect'
as described by Derek Piggot in 'Understanding Gliding'
Appendix A and also published in Gliding magazine in
1951 by Dr A.H. Yates.
John Galloway
At least someone gets it.
Also mentioned by Doug Haluza in an article in "Soaring" a few years
ago.
As you enter lift the glider accelerates forward due to the lift
vector tilting forward in the flight direction. Entering sink the
reverse effect occurs. This is a short lived effect for sharp edged
gusts with time constants of the order of 0 .15 to 0.5 seconds for
typical glider airspeeds and wing loadings.
It also has interesting effects on TE varios and is one of the reasons
that TE varios seem much quicker or more "nervous"in response than
uncompensated varios connected to static sources. The other is the
sensitivity of the TE vario to horizontal airmass changes"horizontal
gusts".
There is an article on our website about this.
Mike Borgelt
Borgelt Instruments
www.borgeltinstruments.com
Old August 17th 03, 11:04 AM
Robin Birch
I
One day I'll get round to reading that.
gusts".
Mike,
That is the clearest reason for it happening that I have ever seen.
When you sketch out the lift and drag vectors and then see what happens
when extra lift is added and removed it's obvious.
Thanks
Robin
Mike Borgelt
Borgelt Instruments
Robin Birch
Old August 17th 03, 04:16 PM
Martin Gregorie
On Sun, 17 Aug 2003 11:04:23 +0100, Robin Birch
I
gusts".
Mike,
Agreed. I must try to consciously use constant attitude cruise. I'm
slowly approaching that way of flying in any case, but still have the
habit of clicking on 10 knots if the vario groans.... and am probably
going too fast as a result.
martin@ : Martin Gregorie
gregorie : Harlow, UK
demon :
co : Zappa fan & glider pilot
uk :
PA28: Difference in constant speed prop vs fixed pitch Nathan Young Owning 25 October 10th 04 04:41 AM
Constant speed props GE Piloting 68 July 3rd 04 04:08 AM
Why do constant speed power setting charts limit RPM? Ben Jackson Piloting 6 April 16th 04 03:41 AM
Practicing SFLs with a constant speed prop - how? Ed Piloting 22 April 16th 04 02:42 AM
Constant Speed Prop vs Variable Engine Timing Jay Home Built 44 March 3rd 04 10:08 PM
