"Guy Byars" wrote in message ...
If you want to move into high performance single seaters, your options will be somewhat restricted, but you'll manage to find something. Its typical for Euro gliders to come out of the factory with a max cockpit load of 242 lbs (110 kg.), but that often gets reduced when extra equipment is installed. Most high performance gliders have provision to store ballast in the tail. This could increase the minimum cockpit weight. You will have to reduce the water ballast accordingly to stay below gross weight. I will assume you meant "maximum" cockpit weight. Isn't water ballast a different issue from fuselage weight? In other words, it may be perfectly ok, structurally, to add 300 lbs of water in the wings but that same 300 lbs added to the fuselage (with pilot) would not be ok. The issue is the structural limits of attachment of the fuse to the wings, I believe. Perhaps I simply misread your message and this is not what you were implying. But I add this comment just to make the issue clear to the original poster. Water in the wings does not stress the attachment of the fuse. -Doug |
What's minimum safe O2 level? | PaulH | Piloting | 29 | November 9th 04 07:35 PM |
Angle of climb at Vx and glide angle when "overweight": five questions | Koopas Ly | Piloting | 16 | November 29th 03 10:01 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
Where are the CFIG's? | Michael | Soaring | 10 | August 19th 03 12:23 AM |
