Drag Chute Deployed ?
Old August 27th 03, 03:18 PM
JJ Sinclair
Default Drag Chute Deployed ?
NTSB is reporting a fatal accident where a Salto was seen with drag chute
deployed on July 19, 2003. Anyone have more details on this accident?
http://www.ntsb.gov/NTSB/Month.asp
JJ Sinclair
Old August 27th 03, 03:42 PM
Al
Also how about this nonfatal..
http://www.ntsb.gov/NTSB/brief.asp?e...15X01341&key=1
Al
"JJ Sinclair" wrote in message
JJ Sinclair
Old August 28th 03, 02:52 AM
Shawn Curry
Al
My info is second hand, so I won't comment on the details. I will say
that the terrain around the reservoir is steep, rocky, and heavily
wooded. Storms in this area build and intensify very fast. Most of us
have had our run-ins with them. Unfortunately, bad outcome for a nice
glider, but good choice for the pilot IMHO.
I'm glad he's O.K. Nice guy and a good instructor.
Shawn
Old August 27th 03, 09:40 PM
JJ Sinclair
Todd wrote..There's no
indication that I know of that the drag chute played any
part.
I would say the drag chute did play a part in this accident. The question I
would ask is; Did the pilot deploy the chute and if so, why? Or did the chute
deploy without the pilot knowing it? Trying to select an off-field landing spot
with an uncommanded drag chute deployed could have given the pilot a
distraction that he didn't need at a critical time.
JJ Sinclair
Old August 28th 03, 07:26 PM
MikeYankee
I was not at Wurtsboro that day but have flown there almost 20 years and knew
the pilot in question. He was conscientious but lacked cross-country
experience. He was attempting to fly "local" triangles between Wurtsboro,
Monticello and Ellenville -- only a 35-mile course, but fully two-thirds over
unlandable terrain.
One of the difficulties in flying at Wurtsboro is that in the NW quadrant,
where conditions are often best, one has to go about 10 miles (over rising
terrain) before a decent choice of fields opens up.
In my estimation, his sad mistake was likely to recognize, far too late, that
he was low and needed a place to land. The terrain beneath him was ~800 ft
higher than Wurtsboro's field elevation, and with very poor field selection.
Actually there are a couple of so-so fields within reach, but they may not have
been obvious or even visible from his [presumed] low height.
Improving XC experience, situational awareness and possibly local knowledge are
the keys to preventing similar accidents. I don't think the drag chute was
causative, but that's just my opinion.
Mike Yankee
(Address is munged to thwart spammers.
To reply, delete everything after "com".)
Old August 28th 03, 09:49 PM
JJ Sinclair
Thanks for your thoughts on this accident, Mike. It is always tragic when life
is lost because of inexperience. I guess the lesson that we can learn from this
is; If there is nothing but trees below you, then *put it in the trees* and
don't try to avoid them. I do think it is important for us to analyze our
accidents in a forum like RAS, because if we don't do it, nobody will. Please
tell us what you think caused an accident and what could have prevented it.
That's the only way to get the word out and possibly prevent a similar
accident.
JJ Sinclair
Old August 28th 03, 10:53 PM
W.J. \(Bill\) Dean \(U.K.\).
I was present (with a great many other glider pilots) last year at a
competition when an ASW27 crashed into trees final gliding to the airfield.
There was not quite enough energy, and he hit the top of a tall tree on the
boundary, broke through this to finish in a small tree a few yards further
on. The fuselage finished just clear of the ground with the wings badly
damaged. The pilot was I think completely uninjured, certainly he walked
away. It would have been much worse but for that small tree.
This year at that airfield they set the finish line so as to avoid finishing
over the trees.
W.J. (Bill) Dean (U.K.).
Remove "ic" to reply.
when life is lost because of inexperience.
I guess the lesson that we can learn from this is; If there is nothing but
trees below you, then *put it in the trees* and don't try to avoid them.
I do think it is important for us to analyze our accidents in a forum like
RAS, because if we don't do it, nobody will. Please tell us what you
think caused an accident and what could have prevented it. That's the
only way to get the word out and possibly prevent a similar accident.
JJ Sinclair.
Old August 28th 03, 11:40 PM
RamyYanetz
Please
accident.
JJ Sinclair
I don't know if the glider in question had a flight recorder, but many do, and
many mysterious accidents could have been fully analyzed if flight recorder
manufactures would have build them in a way that the memory can survive a
crash.
Unfortunately in most cases the flight log is lost simply as a result of the
memory battery comming loose. I heard of quiet a few such cases.
A recent mysterious accident during a contest could have been potentially
resolved if the flight log was available.
Any comments from flight recorder manufactures?
Ramy (TG)
Old September 2nd 03, 01:52 PM
Chris
trees*
May be a coincidence but we had two crashes this season, both
into the trees and both pilots survived with virtually no injury.
One had a cut on his head from the canopy and the other one just
bruises. The gliders, a Pegase and a DG-300 were totally damaged.
So obviously crashing into trees can give you an *edge* in such a
situation.
Christian
max altitude and Mach 1 Boomer Military Aviation 22 June 1st 04 08:04 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
Lower Drag: Rounded or Sharp? Jay Home Built 9 May 10th 04 10:30 PM
Angle of climb at Vx and glide angle when "overweight": five questions Koopas Ly Piloting 16 November 29th 03 10:01 PM
Forward CG Experience Jay Honeck Piloting 41 November 19th 03 02:54 PM
