I have just been to a presentation on the Perlan project which at it second
stage goal of 100,000ft height is about mars ground level air pressure. The aircraft would have 29-30 metre wings (ETA size) and be designed to fly in the range of 0.6-0.7 mach .The convergence into "coffin corner" occurs at 108,000ft . The l/d of the design at sealevel would be 50:1 and at the altitude would drop to 25:1 (source, Nasa supercomputer flight simulations) The designer of the ETA has been asked to provide some data on large span composite wing structures at the reynolds numbers required for this project gary "C.Fleming" wrote in message ... Said another way, the air is so thin on Mars, you might as well be trying to soar on the moon. It doesn't matter that the gravity is less; without air, you're going to have a 0:1 glide ratio! Chris "puffnfresh" wrote in message ... Given the lesser density of air on Mars what would be the glide ratio of a PW-5 starting at an altitude of say 5000 feet? (lesser gravity, too) Is it worth book a trip in next few years? |
Soaring Society of America National Convention, Feb 10-12 Ontario,CA | Jim Skydell | Home Built | 1 | January 31st 05 04:33 AM |
Martin Mars wreckage found | John Szalay | Naval Aviation | 12 | December 16th 04 11:40 PM |
Advanced Soaring Seminar - Eastern PA | B Lacovara | Home Built | 0 | February 9th 04 01:55 AM |
Advanced Soaring Seminar - Eastern PA | B Lacovara | Piloting | 0 | February 9th 04 01:54 AM |
