Microair vs Becker
Old August 30th 03, 09:45 PM
Ian McPhee
Default Microair vs Becker
99% Microair are perfect but yes there have been problems with earlier
sr nos. There are several service notes from Microair that address
some of these problems. I will admit Microair are sensitive to its
antenna even problems with just some frequencies in the middle to
upper part of freq. ALSO some microphones (silver Icom Booms) make
you think you have a a fault in xmitter of antenna - it is like the
radio is directional. Your fault is your BOOM MIC trust me.
The microair is a little down on output power compared to Becker etc
but set up properly power is really not relivant. Microair have
excellent receives at all times. I should mention there will be a new
Aussie radio called X-com which will use buttons and is more power and
inbuilt vox-intercom. If Microair owners think they have a mic
problem please contact me and I will help out. I would have to say
Becker and Dittel are excellent radios be they expensive.
Ian McPhee
Box 657 Byron Bay NSW 2481 Australia
Tel +61 2 66 847642
VHF Becker AR4201 Philippe Home Built 2 July 9th 04 08:30 PM
Becker AR 4201 or Microair 760 Transceiver Steve B Soaring 23 September 15th 03 06:32 PM
FS: Becker ATC-4401-175 Transponder, EA-401A ARC Servoed Encoding Alt Juan E Jimenez Home Built 0 August 6th 03 04:21 AM
FS: Becker ATC-4401-175 Transponder, EA-401A ARC Servoed Encoding Alt Juan E Jimenez Owning 0 August 6th 03 04:21 AM
FS: Becker ATC-4401-175 and SigmaTek ARC EA-401A Servoed Encoding Alt Juan E Jimenez Aviation Marketplace 0 August 4th 03 08:48 PM
