Flying Technique Question of the Day
Old August 29th 03, 03:54 AM
Jim Vincent
Default Flying Technique Question of the Day
Tailored towards the newbies:
On final, assuming there is a crosswind and you need to forward or side slip,
does it make a difference which wing is held down, and why?
Jim Vincent
CFIG
N483SZ
Old August 29th 03, 04:20 AM
Bob Johnson
OK, I'll bite -- the down wing will result in a turn into the wind,
resulting in a runway heading path down final. Is a crab in the same
situation preffered/unpreffered/dealer's choice?
BJ
Jim Vincent
CFIG
N483SZ
Old August 30th 03, 02:45 AM
Robert Bates
I've always understood that in a stiff crosswind the upwind wing is lowered
in a side-slip in order to 1. help counteract the crosswind, and 2. prevent
a rollover close to the ground.
As for forward slips, regardless of the crosswind, I personally prefer to
lower the wing on the inside of my approach, forcing me to apply rudder
opposite that used on my turn onto final - helping to prevent a spin
condition at low altitude...
-Rob
"Bob Johnson" wrote in message
BJ
slip,
Jim Vincent
CFIG
N483SZ
Old August 30th 03, 08:44 AM
tango4
Forward slip ....
Whasat?
I know what a sideslip is but I've never understood this ( American? ) term.
Can't seem to find it in the BGA instructors manual either.
Ian
Old September 1st 03, 03:01 AM
Nyal Williams
"tango4" wrote in message ...
Forward slip ....
Whasat?
Ian
Don't bother with it; the glider doesn't know the difference. It is a
US mental exercise based on where you are trying to go. A pilot in
the back seat can't tell which one it is until he sees where you end
up.
Old September 1st 03, 04:32 PM
Mike Lindsay
In article , Judy Ruprecht
writes
At 03:24 01 September 2003, Shirley wrote:
One (side slip) is used to adjust for drift in a
crosswind
.. best used on final approach, both the ground track
and the glider's longitudinal axis are aligned on runway
heading. (Useful in a 2-33 with x-winds of 15 kts &
higher - not a swell option on low-wing gliders in
strong crosswinds.)
the other (forward slip) is used to increase the angle
of descent...
.. the ground track is aligned on runway heading,
while the glider's longitudinal axis is decidedly off-kilter.
(Useful in some gliders to further steepen a full-spoiler
approach to a short field or deal with spoiler failure.)
Too much speed and a delayed recovery, however, can
leave you with a glider cum lawn dart.
I see. So the two ideas are aerodynamically the same, but what you call
a sideslip is used for cross wind landings and a forward slip for
steepening the glidepath?
Mike Lindsay
Old September 1st 03, 10:23 PM
Nyal Williams
Mike Lindsay wrote in message ...
writes
crosswind
strong crosswinds.)
of descent...
Yes, they are aerodynamically the same. Judy's description is
dead-on. Both of them will steepen the glide path, but the latter one
is much more dramatic than the former. I admit to writing a bit of a
troll; it annoys me that the one that keeps the fuselage and the
course line the same is called a side slip, and especially so that the
one in which one is travelling sideways is called a forward slip.
I still insist that the airplane doesn't know the difference except
that one is slipping a greater amount, usually, than the other. A
very gentle "forward slip" will feel just like a healthy "side slip"
if you have your eyes closed.-
Old September 2nd 03, 12:52 AM
Fred Mueller
snip
In the US, the term "sidelslip" is shorthand for a forward slip to
landing.
A forward slip can be properly done with the low wing into the wind or
not. A sideslip (forward slip to landing), must obviously be done
with the low wing into the wind or you will be unable to align the
longitudinal axis of the glider with the ground track.
Fred
Old September 2nd 03, 03:24 AM
Duane Eisenbeiss
"JJ Sinclair" wrote in message
Yo, Judy & Shirley,
I hate to admit it, but I don't know the difference between a side slip
and a
forward slip. Please walk me through exactly what I'm doing with the stick
and
rudder on each one and where the nose is pointed. When I have used what I
called a slip, I was turning a left final, just kept the left wing down,
shoved
in a bunch of right rudder. The nose went right and I added a little more
rudder if I wanted to make the ship move to the right or took some rudder
out
if I wanted to move left.
Thanks,
JJ Sinclair
If you were flying such that you could not see the ground how would you know
if you were doing a side slip or a forward slip??
Possible answer: The difference between a side slip and a forward slip is
ground track only.
Duane
"Cleared Straight-In Runway X; Report Y Miles Final" Jim Cummiskey Piloting 86 August 16th 04 06:23 PM
NE Flying Royce Brown Piloting 1 July 8th 04 01:17 AM
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING The Ink Company Aviation Marketplace 0 November 5th 03 12:07 AM
'They want to ban recreational flying...' Thomas J. Paladino Jr. Piloting 28 July 22nd 03 07:20 PM
Got my ticket.... now what (the cross-country question) bdl Piloting 6 July 13th 03 02:06 AM
