Tow Rope Freindly Fences
Old August 31st 03, 07:53 PM
John Spargo
Default Tow Rope Freindly Fences
Tow rope friendly fences
We have a fence at the end of our runway that keeps our neighbors (Riding
School) horses out of the airfield. Occasionally the tow plane pilot snags
the fence with the rope, which winds round at least one, and sometimes more
strands of barbed wire- resulting in a broken rope and fence and a nervous
pilot.
After some discussion at the club the following fence has been mooted -
Wire strands supporting small aperture mesh sized to exclude the passage of
the ring on the end of the rope. (Chicken wire) tightly tensioned with a
split plastic pipe over the top - the whole aligned at 45 degrees. The idea
being that the plastic pipe will prevent the fence damaging the rope while
it is passing over it, and the mesh will prevent the rope from turning round
any strand.
Anyone solved a similar problem ? If so please let us have details
John Spargo
Cape Gliding Club
Old August 31st 03, 07:54 PM
Robert Danewid
Buy a tow rope winch! Good for the safety.
Robert
pilot.
any strand.
John Spargo
Cape Gliding Club
Old August 31st 03, 08:06 PM
F.L. Whiteley
We have been known to have the tow pilots tie the broken weak link around
their necks.
Old August 31st 03, 08:50 PM
David Starer
John,
Robert's suggestion of a winch is the best solution assuming you don't have
certification problems and the tug is physically capable of having one
fitted.
Failing that, how about putting a prominant marker about one and a half
ropes' length into the runway and having your tow pilots land beyond that?
That should allow enough length to allow for the rope to dangle and still
clear the fence.
I think your fence design underestimates the effect of a pair of metal rings
travelling at 60-70 knots. I've seen chunks of hedges ripped out by tow
ropes and I doubt if any wire fence (however well designed) would withstand
repeated attacks by the tow rope, let alone the lethal effect on any horses
that may be nearby. Avoiding hitting the fence altogether could be a much
better way of keeping good relations with your neigh-bours ('scuse the pun -
couldn't resist it!).
David Starer
"John Spargo" wrote in message
more
pilot.
of
idea
round
any strand.
John Spargo
Cape Gliding Club
Old August 31st 03, 09:44 PM
BTIZ
fly higher approaches.. estimate a touch down point and descent rate to that
point that clears the rope over the fence.. and do not land early..
hate to be a horse along that fence.. checking out the new gizmo.. when the
rope comes along..
BT
more
pilot.
of
idea
round
any strand.
John Spargo
Cape Gliding Club
Old September 1st 03, 12:45 AM
ken ward
didn't they have a similar problem at the Vacaville glider operation?
wasn't it called the 'Nut Tree rope trick'?
Ken
pilot.
any strand.
John Spargo
Cape Gliding Club
Old September 1st 03, 04:17 PM
Mike Lindsay
In article , John Spargo
writes
pilot.
any strand.
John Spargo
Cape Gliding Club
At two sites I know of the SOP is for the tuggies to overfly the
downwind end of the field, drop the rope near the launch point, do a
smart 180 and land.
Mike Lindsay
Old September 1st 03, 08:55 PM
Ivan Kahn
You really need to avoid hitting them to begin with. Consider building an
approach slope indicator, you can construct one out of plywood and some
paint. See the AIM 2-1-2 (e)
Ivan
Old September 2nd 03, 04:17 AM
BTIZ
most ropes are 200ft or so.. so even 100yrds farther down should clear the
fence..
BT
"Tom Seim" wrote in message
om...
Correct me if I'm wrong (as if you won't!), but you can avoid the
whole problem by having the tow pilots land a little farther down the
runway (a couple of hundred yards will do). Hasn't this ocurred to you
before?
11 on a Rope Peter Seddon Rotorcraft 0 May 27th 04 11:33 AM
Donuts on a rope Big John Piloting 4 May 2nd 04 04:53 AM
Using Plasma Rope For Winch Tows Craig Freeman Soaring 56 August 24th 03 10:55 PM
