Which Transponder?
Hi All
I am contemplating getting a transponder for our LS3a. It seems the choice is between either a 175W or 250W Becker "ATC 4401" unit or the Microair "T2000". Has anybody had first hand experience with any of the above? What were your experiences, which unit would you recommend? Which altitude encoder did you use? What batteries do you use and how long do they last in flight? Where did you mount the antenae? Have you had any operational or reliability problems while flying? The alternative might be to get hold of an old Terra unit. However these seem virtually unobtainable, not very reliable and very difficult/expensive to repair if/when they fail. Thanks Ian |
Filser is currently developing a mode S unit. Depending on how their
schedule matches yours, you might have a look at it. Stefan |
"Ivan Kahn" wrote...
Before you invest in a transponder, call the facility with radar coverage in your area and find out if they routinely "supress" VFR codes during the times you fly. When the screen gets busy some facilities supress VFR codes, and so a transponder would in fact be a waste of money. A transponder will trigger ACAS/TCAS, whether or not the controllers happen to be paying attention to it... Marc |
I doubt that they would suppress 1200 within the approach control area
around a class B airspace (ModeC Veil) BT "Ivan Kahn" wrote in message news:lgw6b.378053$o%2.170703@sccrnsc02... Before you invest in a transponder, call the facility with radar coverage in your area and find out if they routinely "supress" VFR codes during the times you fly. When the screen gets busy some facilities supress VFR codes, and so a transponder would in fact be a waste of money. Ivan |
"Ian Forbes" wrote in message news Hi All I am contemplating getting a transponder for our LS3a. It seems the choice is between either a 175W or 250W Becker "ATC 4401" unit or the Microair "T2000". I have the 175 watt Becker with ACK A30 encoder in my 26E. No clue how long the ship's 18 AH avionics battery would power it as there's solar panels on the engine bay doors helping out. If I turned off WinPilot I could probably sell power to the utility. In any case, I suspect it'll last way longer than me. AFAIK the 250 watt Becker is only recommended if you spend a lot of time in the upper flight levels. Antenna is mounted on the belly just aft of the gear door. The thinking is to get the antenna as far as possible, within reason, away from the pilot's body. No sense testing the long term effects of high frequency radiation. For the reasons you mentioned, the Terra isn't worth considering unless dirt cheap. Even then, may not work long enough to justify cutting a rectangular hole in the panel to mount it - - considering that you'll have a tough time putting any other piece of gear in the non-standard hole. -- bumper "Dare to be different . . . circle in sink." to reply, the last half is right to left --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.514 / Virus Database: 312 - Release Date: 8/29/2003 |
I think marc's statement concerning ACAS/TCAS is one of the best
reasons to fly with a transponder, along with facilitating the extended use of some wave windows. I fly along/in mountainous areas that have alot of bizjet/heavy aircraft decending over them and although I haven't had any close calls, I've seen traffic come out of nearby clouds (not on airways) going fast enough that I'm happy I had something to let them know where I am before there is any visual contact! I used to have a Terra, but it wouldn't fit in the panel(it was hung off the side-in the way of egress) and parts aren't available. I got a microaire and it's been easy to use, has worked great, and didn't cost two arms and a leg. Will |
Class B airspace is used where there is heavy traffic, which is when VFR
codes are typically suppressed. My advice is only to make a phone call before laying down your cash. On the other hand, Marc does make a good point which is "A transponder will trigger ACAS/TCAS, whether or not the controllers happen to be paying attention to it..." Ivan "BTIZ" wrote in message news:kwy6b.46455$Qy4.20716@fed1read05... I doubt that they would suppress 1200 within the approach control area around a class B airspace (ModeC Veil) BT "Ivan Kahn" wrote in message news:lgw6b.378053$o%2.170703@sccrnsc02... Before you invest in a transponder, call the facility with radar coverage in your area and find out if they routinely "supress" VFR codes during the times you fly. When the screen gets busy some facilities supress VFR codes, and so a transponder would in fact be a waste of money. Ivan |
I am not so sure if a transponder makes sense, if not in a powered
sailplane. I was told, that only with a transponder I could cross a 20km whide controlled airspace - ok - get a transponder in and test fly it. Same situation asking permission to cross the same area. ATC: do you have a transponder ... yes the usual switch on procedure followed and then the permit to cross the airspace ending with - keep flight level at xxxxxx ft my answer: glider CH cannot keep flight level ATC: withdraws permit to cross airspace (too much work to shuffle traffic vertically as well!!!!!!!!!!!!!!!) ok then - rip the transponder out. - Transponders for gliders are just battery flattening - we should have a receiver telling us, where the big birds are comming from Chris "Ian Forbes" wrote in message news Hi All I am contemplating getting a transponder for our LS3a. It seems the choice is between either a 175W or 250W Becker "ATC 4401" unit or the Microair "T2000". Has anybody had first hand experience with any of the above? What were your experiences, which unit would you recommend? Which altitude encoder did you use? What batteries do you use and how long do they last in flight? Where did you mount the antenae? Have you had any operational or reliability problems while flying? The alternative might be to get hold of an old Terra unit. However these seem virtually unobtainable, not very reliable and very difficult/expensive to repair if/when they fail. Thanks Ian |
Similar Threads | ||||
VHF & Transponder antenna | Steve | Home Built | 1 | December 6th 04 04:29 PM |
Operation without a transponder | flyer | Piloting | 11 | September 14th 04 08:48 AM |
Transponder test after static system opened? | Jack I | Owning | 6 | March 14th 04 03:09 PM |
Fixing the Transponder with Duct Tape and Aluminum Foil | Ron Wanttaja | Home Built | 45 | March 14th 04 12:18 AM |
transponder codes | Guy Elden Jr. | Piloting | 1 | December 2nd 03 05:21 PM |
