Becker AR 4201 or Microair 760 Transceiver
Old September 13th 03, 07:00 PM
Joe Lacour
I'm re-painting some gel coat spots on my LS and was wondering what
everyone is using for the red trim color. The original stuff is Nitro
Cellulose Lacquer. So, I call up the local body shop only to find that
lacquer is on it's way out of major production. Too bad as it's nice
stuff to work with, cheap, light, can be put on thin, and easy to
patch. I've found some by looking on the internet but it only comes in
one color red and gallons.
I'm also re-finishing the elevator and would like to sand the gelcaot
and paint it with lacquer. Won't add weight that way.
The LS also has some red tape to blend the seal on the rudder. Any
idea where to get this red tape?
Joe LaCour
KineOptics
120 Golden Pheasant Dr.
Slidell, LA 70461-3116
985-649-0602
Optical & Mechanical Instrument design/fabrication
http://www.kineoptics.com/
Old September 13th 03, 11:07 PM
Ralph Jones
On 13 Sep 2003 18:00:07 GMT, Joe Lacour
Nitrocellulose lacquer is model airplane dope -- the older nitrate
type. It's comparatively little used today because glow-engine fuels
attack it, but the larger hobby dealers have it -- and if you can't
find nitrate, the newer butyrate dope is usually compatible with it.
Buy a small sample, test it on an out-of-the-way spot, and you should
be able to get a color match with a little mixing.
rj
Old September 15th 03, 05:58 PM
wsburhen
you could also use acrylic laquer, which has huge advantages over over
nitro and no real disadvantage (it can be shot very thin) or a
basecoat/clearcoat
system, while a bit more work, can also be done thin/light and will be
many times more durable than nitrocellulose. Either of these two
systems can be EXACTLY color matched and are locally available
anywhere at an autobody supply store. Try Ditzler Duracryl for acryl
laquer, or Deltron for b/c system, or other types by Sikkens,
Martin-Senor, Glasurit, etc.
