OK, I forgot to engage brain before typing..
Your post states 190 litres of ballast, but not the speed that you had left at the end of the pull-up Cheers Kevin At 14:06 18 September 2003, Udo Rumpf wrote: check previous post. Udo When you ran the Sim, how much ballast were you carrying, & what speed did you pull up to in each case? At 02:30 18 September 2003, Udo Rumpf wrote: The sink rate for the fully loaded glider(190 litres) = 1.2m/s for the none ballaste version 1.65m/s Udo |
Kevin,
In case I missed it, booth gliders are allowed to fly / coast to the top without control input for recovery. Udo "Kevin Neave" k wrote in message ... OK, I forgot to engage brain before typing.. Your post states 190 litres of ballast, but not the speed that you had left at the end of the pull-up Cheers Kevin At 14:06 18 September 2003, Udo Rumpf wrote: check previous post. Udo When you ran the Sim, how much ballast were you carrying, & what speed did you pull up to in each case? At 02:30 18 September 2003, Udo Rumpf wrote: The sink rate for the fully loaded glider(190 litres) = 1.2m/s for the none ballaste version 1.65m/s Udo |
Hello Udo
I collected some comments regarding your sims. 1.)In reality, the way you pulled in sim, it would have exceed glider's limitation (too many g's), resulting in two broken wings! 2.)Since we always do a recovery around V=Min Sink, some argue that in this case, it would demonstrate the advantage of the ballasted. Any comments?? Bravo Quebec "Udo Rumpf" a écrit dans le message de ... Kevin, In case I missed it, booth gliders are allowed to fly / coast to the top without control input for recovery. Udo "Kevin Neave" k wrote in message ... OK, I forgot to engage brain before typing.. Your post states 190 litres of ballast, but not the speed that you had left at the end of the pull-up Cheers Kevin At 14:06 18 September 2003, Udo Rumpf wrote: check previous post. Udo When you ran the Sim, how much ballast were you carrying, & what speed did you pull up to in each case? At 02:30 18 September 2003, Udo Rumpf wrote: The sink rate for the fully loaded glider(190 litres) = 1.2m/s for the none ballaste version 1.65m/s Udo |
