Contest Numbers/Letters
Old September 30th 03, 12:47 AM
Ken Kochanski
Default Contest Numbers/Letters
I can remember how enjoyable it was to paint my wing numbers on my first 15
ship. It was kind of a right of passage.
Taking them off and repainting again was not so much fun ... for as we all
know, the letters have to be right side up when you viewed from the ground
as you approach the gate i.e. the top of letter should be along leading
edge. At least I didn't have letters on both wings as Gleb did in The
Sunship Game. :-))
Since we don't need 2- 3 foot letters for ground viewing, how about allowing
6" letters behind the gear doors for thermal/gaggle identification. (BTW,
I have actually been in thermals so crowded, I could not see the wing
numbers of the glider above and just outside me ... because his fuse was in
the way. I could see his gear doors ... and hinge rivets ...real fine,
though.)
KK
Ken Kochanski
Old September 30th 03, 01:19 AM
Ray Lovinggood
ID's behind the gear doors would be beneficial for
the fiberglass furball situations, but I would definitely
keep the BIG LETTERS under the wing.
Since I gave up on trying to make the time match with
suitable weather for painting my numbers, I 'cheaped
out' and went for the 'simple' stick-on vinyls. Boy,
did I screw those up. Boy, are there a lot of corners
on the letter 'W' and those corners makes it hard for
one with ten thumbs and no guidance!
My ID is 'W8'.
For unknown reason, I started with the 'W' on the left
side of the fin. So, the 'W' was placed with much
cussing due to wrinkles (isn't that what the 'W' stands
for?). Next came the '8' which went on the left side
of the rudder.
That disaster completed, I moved to the right side.
Hmm, I started with the 'W' on the fin on the left
side, I'll start with the 'W' on the fin on the right.
For a moment there, I was thinking of being 'W8' for
those to my port side and '8W' for those on my starboard...
Is there a book yet entitled 'Gliders and Gliding for
Idiots'???
Ray Lovinggood
Carrboro, North Carolina, USA
LS-1d 'W8'
be along leading
as Gleb did in The
Sunship Game. :-))
how about allowing
6' letters behind the gear doors for thermal/gaggle
not see the wing
though.)
KK
Ken Kochanski
Old October 1st 03, 11:32 PM
Ray Lovinggood
I learned about the soapy water method after I applied
the letters to the tail. :-(
However, when I did the wing, I had not only soapy
water, but also an extra pair of hands. Those big
letters went on a lot easier and without wrinkles due
to both.
Ray
for?).
Did you use water with soap on the adhesive side of
letters, or try the dreaded 'dry' method?
Todd Pattist - 'WH' Ventus C
(Remove DONTSPAMME from address to email reply.)
Old October 5th 03, 05:58 AM
Steve Bralla
In article , Todd Pattist
writes:
I applied one side dry too, then learned the soapy wet
method. Fortunately, I started on the trailer's fin :-)
Todd Pattist - "WH" Ventus C
I'll be putting contest numbers on my new to me glider. I've done it before,
but what is the "soapy water method?
Thanks,
Steve
Old October 5th 03, 07:08 AM
John Morgan
"Steve Bralla" wrote in message
writes:
before,
Thanks,
Steve
Add a few drops of liquid hand dishwashing detergent to a spray bottle full
of water. Spray solution onto surface before applying decal. This will allow
decal to be precisely positioned and moved on the surface as necessary.
Squeegee out all moisture from under decal. You can use a plastic squeegee
for this or even a damp rag. Once you have all the bumps and bubbles out,
leave it alone for a few hours and the sticker will be on there.
bumper - ZZ
"Dare to be different . . . circle in sink."
to reply, the last half is right to left
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.521 / Virus Database: 319 - Release Date: 9/23/2003
Announcing WINNER of "Can you help Identify this airport" contest! Video Guy Piloting 8 January 13th 04 04:50 AM
Region 6 South Contest (USA) BMacLean Soaring 0 September 1st 03 08:37 PM
Beaverstate 03 contest results. DSowder Aerobatics 0 August 28th 03 12:56 AM
US Contest Rules Committee Election Ken Sorenson Soaring 4 August 9th 03 07:06 PM
2003 Air Sailing Contest pre-report synopsis Jim Price Soaring 0 July 10th 03 10:19 PM
