Flying a 2-33
Old October 5th 03, 03:08 AM
Fred Blair
Default Flying a 2-33
I will be flying a 2-33 next week. I have only flown Blaniks, Larks and my
Libelle.
What are the important speeds for the 2-33?
Does it have any unusual characteristics?
Thanks,
Fred
Old October 5th 03, 06:01 AM
BTIZ
send me an email I'll send you a acrobat.pdf file.. 1.6meg
all speeds are mph
best L/d solo, 45, dual 50
min sink, solo, 36, dual 45
Max aero tow, 98
Max airbrake operation 98
max auto/winch tow 69
stall solo 31 dual 34
after flying the Blanik you'll think it's a truck...
BT
"Fred Blair" wrote in message
my
Libelle.
Thanks,
Fred
Old October 5th 03, 05:24 PM
Mike Stramba
"Fred Blair" wrote in message ...
Why? Did you lose a bet ? g.
Libelle.
Vne 98 mph , best L/D ~45 mph , min sink ~ 40 mph
- 23:1 ... at best g.
- It doesn't stall or spin More like "mush" and "lazy wing drop".
- On tow you won't be able to trim off the forward pressure
- Aileron / stick movement at slow speeds is limited by your legs !
Think "long" control throw !
Mike
Thanks,
Fred
Old October 5th 03, 06:03 PM
BTIZ
and after flying the LS-4.. the Grob 103 is a truck and the 2-33 is a d-9
Cat..
LOL
"Judy Ruprecht" wrote in message
... and after flying your trusty 301, you'll think
the 2-33 is a d-9 Cat...
Old October 5th 03, 06:04 PM
BTIZ
Mike
very true..
Old October 5th 03, 06:36 PM
Waduino
To add to the other numbers already quoted... Vs around 31mph
my
Libelle.
Thanks,
Fred
Old October 5th 03, 09:22 PM
Mark James Boyd
In article 4aYfb.8917$La.749@fed1read02,
very true..
Before we re-covered it and pulled many pounds of dried mud out
of the tail, our 2-33 was much more tail heavy than the
many years old official weight and balance. I suspect our
case was not unique.
I now always put 20 pounds in the ballast holder up front if
the front seat passenger weighs less than 200 pounds. This has
really helped reduce the need for forward stick pressure when
flying from the back. It also makes the glider more stable
and a bit difficult to stall. Finally, it eliminated the
annoying tendency I had as a student of starting tow with
full elevator and then once tugged a little, having the tail
bang down and not have enough forward authority to get
the nose back down for a while. This takeoff porpise was
not a personal favorite.
I had considered it would be easy to do an amateur W&B check
by just using the wheel as a lever, and balancing a front
occupant(in the seat) with some weights/water on the tail.
Since I know what I weigh, if I measured to the horiz stab
and the wheel, and did a little algebra, I could find the
right amount of water to put in jugs to balance it based on
the official W&B. If I did this and it was still tail or
nose heavy, I'd know the W&B was off.
Having had problems myself, and having Mary Campbell's
(Soar Hawaii) story of a near fatal spin in a glider
with a twenty year old W&B, I am apt to check the accuracy
of W&B in any new aircraft I fly. I wouldn't suggest formally
doing this, however. My 172 gained over 100 pounds by my
A&Ps calculations, and a local rental cessna 150 became a
one-seater this way.
Mark Boyd
Old October 6th 03, 01:12 AM
Nolaminar
The 2-33 will spin. I have had it demonstrated and I was able to show that it
can indeed be spun.
GA
Old October 6th 03, 01:48 AM
DGRTEK
This is almost a troll !!
Fred,
Don't listen to all the bashing. Go have a great flight. Every glider has it's
pro's and cons. Don't expect it to be a high performing glider, just enjoy
what it can do.
Douglas
Old October 6th 03, 09:58 PM
Jack
in article 8R0gb.8934$La.3583@fed1read02, BTIZ at
wrote on 2003/10/05 17:23:
#20pounds in the ballast box?? that is way to much for OUR 2-33 with a 200#
pilot....
But how much mud is in your tail?
Jack
Routine Aviation Career Guy Alcala Military Aviation 0 September 26th 04 12:33 AM
World War II Flying 'Ace' Salutes Racial Progress, By Gerry J. Gilmore Otis Willie Military Aviation 2 February 22nd 04 03:33 AM
Flying is Life - The Rest is Just Details Michael Piloting 55 February 7th 04 03:17 PM
Wm Buckley on John Kerry Big John Piloting 22 February 7th 04 02:19 AM
Announcing THE book on airshow flying Dudley Henriques Piloting 11 January 9th 04 07:33 PM
