One here in NZ had a void of 14-15 inchs long,the engineers here think
the problem has been from making the glue mixture to thin and it has just flowed out of the rear side as there is a ridged edge on the front side to make all the mix go towards the rear. One comment made was they thought that the factory had attempted to push some mix into that void by hand by reaching through the access point but had only been partially successful gary "Duane Eisenbeiss" wrote in message news:rQDhb.533114$Oz4.430152@rwcrnsc54... "Duane Eisenbeiss" wrote in message news:3fRab.527488$uu5.88216@sccrnsc04... Enough time has past such that several DuoDiscus wings must have been inspected. However, there have been no reports as to what was found during the inspection or what, if anything had to be done. All owner should communicate with each other so that we all can have a better handle on what is happening to the fleet. Duane The report for the inspection of ship S/N 217 has been received. The left wing had 1 small void. The right wing had 4 small voids. Has anyone had an inspection that revealed large voids? say larger than 12 inches or 30 cm. Duane |
"goneill" wrote in message ...
One here in NZ had a void of 14-15 inchs long,the engineers here think the problem has been from making the glue mixture to thin and it has just flowed out of the rear side as there is a ridged edge on the front side to make all the mix go towards the rear. One comment made was they thought that the factory had attempted to push some mix into that void by hand by reaching through the access point but had only been partially successful gary ************************************************** ******************************** It would be interesting to know if there is a commonality between all of these discrepancies. Was the bonding paste always too thin or did they mix it according to the clearances of each wing? If the mixture really was too thin causing a void of 14-15 inches long then there are probably many other voids which can't be seen on video. There needs to be an ultrasonic inspection procedure developed which can map the bonding interface. |
![]() "Slingsby" wrote in message It would be interesting to know if there is a commonality between all of these discrepancies. Was the bonding paste always too thin or did they mix it according to the clearances of each wing? If the mixture really was too thin causing a void of 14-15 inches long then there are probably many other voids which can't be seen on video. There needs to be an ultrasonic inspection procedure developed which can map the bonding interface. I have no first hand knowledge. Talked to the owner of a well known, respected composite repair shop who said that cotton threads are added to the epoxy to thicken it and keep it from running. And that apparently they had failed to add enough cotton fiber and this resulted in epoxy running out, creating the voids. -- bumper - ZZ "Dare to be different . . . circle in sink." to reply, the last half is right to left --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.521 / Virus Database: 319 - Release Date: 9/23/2003 |
"John Morgan" wrote in message ...
"Slingsby" wrote in message It would be interesting to know if there is a commonality between all of these discrepancies. Was the bonding paste always too thin or did they mix it according to the clearances of each wing? If the mixture really was too thin causing a void of 14-15 inches long then there are probably many other voids which can't be seen on video. There needs to be an ultrasonic inspection procedure developed which can map the bonding interface. I have no first hand knowledge. Talked to the owner of a well known, respected composite repair shop who said that cotton threads are added to the epoxy to thicken it and keep it from running. And that apparently they had failed to add enough cotton fiber and this resulted in epoxy running out, creating the voids. According to the DG website the bonding paste should be about as thick as cake icing. I suppose too much cotton would also weaken the bond as cotton fibres aren't as strong as epoxy. I still believe that if there are voids which can be seen and can have wires poked into them then there must also be voids which can't be seen and are far to thin to allow wire into them. A .0005 to .008mm thick gap between the spar cap and shear web could not be seen on a video but it would still be an area where there is no bond. Ultrasound would still reflect off of the interface and show a gap. The ultrasonic technique would need to be proven and calibrated on actual wings where voids have been found. Filling the voids immediately makes the chances of developing another inspection method unlikely. |
First of all, it is not the epoxy which bears the load but the cotton
threads. Epoxy is just the matrix, and the rated load of cotton/epoxy is around 7N/mm. Microballons are much heavier and the composite formed of balloons/epoxy doesn't hold the same load as cotton threads/balloons (balloons are spheres so in this case it's the epoxy which finally bears the load). Microballoons are rather used for surface cosmetics. Seperated glass rovings would be ideal - but the beasts don't bend easily into small radii if threaded and a paste made up of them would leave many mm-sized voids. so it just doesn't work. I think that people proposing utrasonic quality checks don't have an exact idea how a wing is constructed. Utrasonic QC basically detects interfaces, and a composite glider wing is made up from interfaces all over the place. I'd say that the error rate in an utrasonic QC would be completely through the roof. I think it would be more easy (and straightforward) to do just a structural load test up to 1.5 times max rated load :-) -- Bert Willing ASW20 "TW" "Martin Gregorie" a écrit dans le message de ... Does anybody on here know what advantage cotton threads would have over, say, microballoons or separated glass rovings? -- martin@ : Martin Gregorie gregorie : Harlow, UK demon : co : Zappa fan & glider pilot uk : |
I think that people proposing utrasonic quality checks don't have an exact idea how a wing is constructed. Utrasonic QC basically detects interfaces, and a composite glider wing is made up from interfaces all over the place. I'd say that the error rate in an utrasonic QC would be completely through the roof. I think it would be more easy (and straightforward) to do just a structural load test up to 1.5 times max rated load :-) Bert Willing ************************************************** ******************************** I understand your point about ultrasonic testing. The sound wave would have to go through the outer skin, foam, inner skin, carbon fibre rovings spar cap, bonding paste, shear web of differing compositions. I guess there could be too many interfaces although I would think that one could find an ultrasonic frequency which didn't reflect off of the interfaces but did reflect off of voids. Or reflects different frequencies and giving a picture. Any idea how composite structures are inspected on large airplanes? I assume x-ray wouldn't be very sensitive on nonmetallic structures. How about neutron radiation? Acoustic emission transducers? Ballistic Recovery Chutes? Also, if the cotton fibres carry the load, is the repair done with an epoxy/cotton mixture? How do they get it into a blind air bubble? |
ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell | Otis Willie | Military Aviation | 0 | March 18th 04 08:40 PM |
Props and Wing Warping... was soaring vs. flaping | Wright1902Glider | Home Built | 0 | September 29th 03 03:40 PM |
Can someone explain wing loading? | Frederick Wilson | Home Built | 4 | September 10th 03 02:33 AM |
An Affordable Homebrue 60 in DS machine | Grant | Soaring | 0 | August 8th 03 03:52 AM |
Wing Extensions | Jay | Home Built | 22 | July 27th 03 12:23 PM |
