On Thu, 16 Oct 2003 08:00:49 -0700, Eric Greenwell
wrote: In article , says... I understand your point about ultrasonic testing. The sound wave would have to go through the outer skin, foam, inner skin, carbon fibre rovings spar cap, bonding paste, shear web of differing compositions. Is the spar cap on the Duo Discus bonded to the inner skin or the outer skin? If it is bonded to the outer skin, it would not have the foam to go through, which should ease the problem considerably. The problem is that the bond in question attaches the top spar to the web. Any problems with this bond will drastically affect the spar strength by allowing the top spar to peel off the web. In the DG-style of assembly with carbon cloth between the spar and the web the bond between the spar and the cloth is equally as critical as that between the web and the cloth. In the model world we prevent spar peel failures by assembling both spars to the web and then wrapping to lot with Kevlar thread or an epozy-wetted woven carbon tube before building the wing round the complete spar. This gives a 30G wing. I accept that this is overkill for full size, but my teeth still itch a bit at the lack of any binding round both the spars except on the protruding stubs at the root. I flat out would not fly a glider with foam between the web and the top spar and would hope that such a structure has never been made or flown. -- martin@ : Martin Gregorie gregorie : Harlow, UK demon : co : Zappa fan & glider pilot uk : |
Eric Greenwell wrote in message ...
I wasn't clear enough. The problem I thought would be eased was the ultrasonic inspection problem. So, is the spar cap attached to the outer wing skin, or is there actually foam between the outer skin and the spar cap? Is the spar cap on the Duo Discus bonded to the inner skin or the outer skin? If it is bonded to the outer skin, it would not have the foam to go through, which should ease the problem considerably. The problem is that the bond in question attaches the top spar to the web. Any problems with this bond will drastically affect the spar strength by allowing the top spar to peel off the web. In the DG-style of assembly with carbon cloth between the spar and the web the bond between the spar and the cloth is equally as critical as that between the web and the cloth. In the model world we prevent spar peel failures by assembling both spars to the web and then wrapping to lot with Kevlar thread or an epozy-wetted woven carbon tube before building the wing round the complete spar. This gives a 30G wing. I accept that this is overkill for full size, but my teeth still itch a bit at the lack of any binding round both the spars except on the protruding stubs at the root. I flat out would not fly a glider with foam between the web and the top spar and would hope that such a structure has never been made or flown. ************************************************** **************************** I don't think anyone said that there is foam between the spar cap and shear web. Foam within the shear web adds a great deal of stiffness, however. The spar cap of German designs is built into one wing skin while the spar web and opposite spar cap is bonded into the other skin. When the two wing halves are mated the one spar cap is glued to the spar web and cap of the other wing half. It's pretty much a blind operation and everything had better well match or there will be a poor or no bond. The Genesis 2 and the LAK-17a both have the spar completely built outside the wing. The spar is totally wrapped in glass fiber insuring it's integrity. It will not debond. Following is a site which has pictures of a Genesis spar. http://www.aviation-salvage.com/airc...enesis%202.htm On the Genesis wing it appears that the spar is bonded to an inner skin which is a foam sandwich with an outer skin. The Genesis spar in the picture had a metal fence post cut through it and it looks like Graphlite rods have been bashed into more of a round shaped bundle. I believe they are spread out into more of an I-shape than the picture would suggest. At least with this design, if the spar is not bonded to the skin there is still a very strong spar. |
Earlier, Eric Greenwell wrote:
...So, is the spar cap attached to the outer wing skin, or is there actually foam between the outer skin and the spar cap? The spar cap is glued to the inner skin, and there is foam between the spar cap and the outer skin. The diagrams in this tech note pretty much show it: http://www.schempp-hirth.com/tmdocs/396-8-489.pdf (Somehow, when I look at those photos, I smell epoxy resin.) The big advantage of that method is that the sandwich skins are more stable, and less prone to mirroring the spar after aging. One of the disadvantages is that the spar is less stiff than it would be if it went from outer skin to outer skin, and didn't have its depth reduced by the sandwich foam. Bob K. |
says... The spar cap is glued to the inner skin, and there is foam between the spar cap and the outer skin. The diagrams in this tech note pretty much show it: http://www.schempp-hirth.com/tmdocs/396-8-489.pdf (Somehow, when I look at those photos, I smell epoxy resin.) The big advantage of that method is that the sandwich skins are more stable, and less prone to mirroring the spar after aging. One of the disadvantages is that the spar is less stiff than it would be if it went from outer skin to outer skin, and didn't have its depth reduced by the sandwich foam. I don't think this is a disadvantage, but is instead an advantage, because the wing isn't so stiff, and the pilot enjoys a smoother ride in turbulence. The disadvantage is it likely takes more material, so the wing is a bit heavier and more expensive. -- !Replace DECIMAL.POINT in my e-mail address with just a . to reply directly Eric Greenwell Richland, WA (USA) |
stable, and less prone to mirroring the spar after aging. One of the disadvantages is that the spar is less stiff than it would be if it went from outer skin to outer skin, and didn't have its depth reduced by the sandwich foam. I don't think this is a disadvantage, but is instead an advantage, because the wing isn't so stiff, and the pilot enjoys a smoother ride in turbulence. The disadvantage is it likely takes more material, so the wing is a bit heavier and more expensive. ************************************************** ******************************** I don't know Eric, that flexibility and smoother ride might be your upper spar cap lifting off of the shear web. There is no law which says the wing has to actually snap. It could be more benign; one wing a little more flexible than the other or air brakes popping open during high speed runs in turbulence. Each 4g pop might add another ..010" to the delamination between those two air bubbles in the bonding paste. The stiffness, or lack thereof, can still be designed into the wing by varying the amount of carbon fibre rovings in the spar cap, or Graphlite rods in the case of the Genesis 2 and LAK 17. I believe the LAK 17 wing has the externally made spar bonded to the outer skin of the wing because the designers wanted an extremely thin profile. The spar is only 3 1/2 inches deep at the wing root of the LAK 17; bonding it to the outer skin of the wing allows the wing to be extremely thin. Unfortunately, some of the earlier 17's had that mirroring and the factory paid to have the wings re-profiled. I believe that happened to some of the earlier ASW 28 gliders, too. Still, the use of Graphlite rods instead of carbon fibre rovings, and externally built spars which are then wrapped in fibreglass cloth and vacuum-bagged is a method which produces stronger, more durable and longer lasting wings. As the current fleet of German gliders gets older I'll wager there will be a lot of speed limiting directives because the "margin of error" isn't what they thought it would be. What kind of spar construction methods do the SparrowHawk, Apis and Russia gliders use? |
In any case you will have a blind bonding applied to one side, be is spar
web to spar cap, or spar cap to wing skin - that's the backdraw of using negative moulds. Now if you produce voids in one case, you might as well produce voids in the other case, no? And, by the way, how much would you allow the price of a glider to increase in case the the manufacturer goes for x-ray or ultrasonic QC? -- Bert Willing ASW20 "TW" "Slingsby" a écrit dans le message de om... Still, the use of Graphlite rods instead of carbon fibre rovings, and externally built spars which are then wrapped in fibreglass cloth and vacuum-bagged is a method which produces stronger, more durable and longer lasting wings. As the current fleet of German gliders gets older I'll wager there will be a lot of speed limiting directives because the "margin of error" isn't what they thought it would be. What kind of spar construction methods do the SparrowHawk, Apis and Russia gliders use? |
Earlier, "Bert Willing"
wrote: In any case you will have a blind bonding applied to one side, be is spar web to spar cap, or spar cap to wing skin - that's the backdraw of using negative moulds. Now if you produce voids in one case, you might as well produce voids in the other case, no?... Well, no, I don't see it that way. The loads between the skin and the spar are far lower than the loads between the shear webs and the spar caps. Also, the stiffening of the spar caps against buckling is absolutely critical to the itegrity of the spar. Voids between the shear web and the spar cap leave the cap much more vulnerable to buckling. Bob K. And, by the way, how much would you allow the price of a glider to increase in case the the manufacturer goes for x-ray or ultrasonic QC? -- Bert Willing ASW20 "TW" "Slingsby" a écrit dans le message de om... Still, the use of Graphlite rods instead of carbon fibre rovings, and externally built spars which are then wrapped in fibreglass cloth and vacuum-bagged is a method which produces stronger, more durable and longer lasting wings. As the current fleet of German gliders gets older I'll wager there will be a lot of speed limiting directives because the "margin of error" isn't what they thought it would be. What kind of spar construction methods do the SparrowHawk, Apis and Russia gliders use? |
"Bert Willing" wrote in message ...
In any case you will have a blind bonding applied to one side, be is spar web to spar cap, or spar cap to wing skin - that's the backdraw of using negative moulds. Now if you produce voids in one case, you might as well produce voids in the other case, no? And, by the way, how much would you allow the price of a glider to increase in case the the manufacturer goes for x-ray or ultrasonic QC? -- Bert Willing ************************************************** ******************************* "During operation the bonding areas carry high loads, but after closing the wing they become inaccessible forever. Therefore these "blind bonds", as they are called, must be carefully prepared and executed with great precision. To achieve this, we developed a simple but very reliable procedu Small strips of play dough ("Plastilin") are applied to all areas where the upper and lower wing halves will get in contact. These are special areas on the leading and trailing edge, the spars and ribs. Adhesive tape protects the bonding surfaces from grease contamination by the play dough. When the the upper and lower molds are put together, the play dough is compressed and reflects a very accurate image of the bonding gap. A similar technique is used for the spars: A series of cloth pins are inserted into the foam of the shear web. These pins are then pushed in when the molds are closed, providing an accurate meassure of the bonding gap. After re-seperating the molds, our quality controller inspects the visualized thicknes of the bonding gap, which has to stay within very tight tollerances to guarantee a long-term reliable bonding. Before permanently closing the wing, the quality controller checks all elements which will become inaccessible. Each individual nut of the control linkage is verified, secured, marked and signed off on a detailed checklist. "Mumpe" call our workers the glue to close the wing. It is a mixture of epoxy resin and cotton flakes, which gives it a consistency like cookie dough. After all bonding areas have been thoroughly cleaned and roughed, the mumpe is applied with a squeeze bag, similar as for icing cake. The thickness of the mumpe layer reflects exactly the gap height as previously meassured with the play dough or cloth pins, plus additional two millimeters. The long experience of our workers shows in the "artwork" of optimally trapezoid-shaped mumpe layers they create with squeeze bag and wooden spates. The right area, exact thickness and correct processing of the bonding layer is crucial for long-term reliability. Any attempt to save weight or cost here would compromize relaibility and safety. The lower wing half is put onto the upper half, adjusted exactly to the guide pins, and then compressed with many vise clamps. Both halves must fit exactly in all places, or the profile will not be correct. The force of the vise clamps squeezes the excess epoxy mixture out between the wing halves. The glued wing is tempered overnight at 35 degrees Celsius. The next morning the wing is taken out of the mould, using the crane and usually with a loud crack. In the sanding room the excess epoxy is removed. After the moulds have been cleaned and waxed, the whole process starts over again." The above is copied from the DG website. The process requires a great deal of skill, experience, attention to detail and craftsmanship. It's not a matter of how much I will allow the price to increase. The more important consideration for the manufacturer is whether I will ever consider pruchasing or flying in a German designed and built glider. I realize that Shemp Hirth is having the problem and the broken wings are limited to Czech. manufactured SH gliders. Nevertheless the process of blindly assembling the spar while also blindly assembling the wing is a process which requires a great deal of faith that it is done correctly. |
ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell | Otis Willie | Military Aviation | 0 | March 18th 04 08:40 PM |
Props and Wing Warping... was soaring vs. flaping | Wright1902Glider | Home Built | 0 | September 29th 03 03:40 PM |
Can someone explain wing loading? | Frederick Wilson | Home Built | 4 | September 10th 03 02:33 AM |
An Affordable Homebrue 60 in DS machine | Grant | Soaring | 0 | August 8th 03 03:52 AM |
Wing Extensions | Jay | Home Built | 22 | July 27th 03 12:23 PM |
