I like all these points and I suspect that because of the short time
required in a winch launch, and the faster acceleration, and the fact that you are in a position to land on the runway that you are using at all times, the winch launch would be safer, but I still see no statistics! Come on folks, someone surly has crunched the numbers. Training is crucial in both, but what I'm looking for is numbers, I have plenty of opinions myself. Boggs "Bill Daniels" wrote in message k.net... "Gary Boggs" wrote in message ... Someone must have already compared the safety of these tow launch methods. What do the statistics show is the safer method of launch? Aero tow seems to involve more inherent dangers to me. For one thing, there is just more time for things to go wrong. What could be more dangerous than to tie tow airplanes together and try to fly? Gary Boggs I have done a whole lot of both and, given a choice, I'll take winch launch. Yes, things happen fast on a winch launch but then the launch is over in 30-40 seconds so the risk exposure is short - with air tow, you are at risk a least ten times as long. Air tow in turbulent air is fatiguing - you will never get tired in a 35 second winch launch. If you don't like the way a winch launch is going, release and land. You can do that with a winch launch because you should always be in a position to land back on the runway - I can't say that is always true with air tow. Air tow is formation flying - involving two extremely mis-matched aircraft - with a rope tying them together. This requires highly developed flying skills to do safely. We teach this to pre-solo students. (I wonder how we get away with it.) Winch launch can easily be taught to pre-solo pilots since it is a simple, repetitive task. Air tow has two aircraft at risk and at least two pilots - winch launch has only one aircraft at risk. Winch launch accelerates the glider far faster than air tow so dropping a wing due to insufficient aileron control is unlikely. (Of course, you can still drop a wing due to incompetence with unhappy results.) In both cases, the training of the pilots and launch crews have a lot to due with overall safety. There is ample opportunity for either to come to a bad end. With equally good training, I think winch launch is safer. But, lets face it - winch launch LOOKS scary to a pilot trained that a steep nose-up attitude near the ground is dangerous. It isn't dangerous but it sure looks that way. Bill Daniels |
![]() "Gary Boggs" wrote in message ... I like all these points and I suspect that because of the short time required in a winch launch, and the faster acceleration, and the fact that you are in a position to land on the runway that you are using at all times, the winch launch would be safer, but I still see no statistics! Come on folks, someone surly has crunched the numbers. Training is crucial in both, but what I'm looking for is numbers, I have plenty of opinions myself. Boggs OK, the BGA accident database is available on the web. The database is searchable for flights that began with a winch launch. Note, however, that most of the accidents in this section do not relate directly to winch launch. I think that there were only three or four accidents over a ten year period that actually happened during the winch launch. The rest were accidents that happened later in a flight that began with a winch launch. It seems to me that if winch launch accident data is hard to come by, that in itself is good news. If accidents happened frequently, there would be lots of hard data. Bill Daniels |
A good place for statistics is:
http://www.esgc.co.uk/BGAdata.htm Search and study the reports. There is much written between the lines. If you look at the number of accidents where the launch was originally a winch launch you will find that a lot of accidents occur soon after the launch is completed and are attributed to other factors but which would really not have happened if they had aerotowed. (Rigging errors not found in the speed of the launch, not watching airspeed and spinning after the launch because of distraction with the high workload of the winch and not dealing with the angle of attack in the launch properly and so on). It is not possible to give clear cut statistics without a significant degree of human interpretation and you will really need to make your own mind up. I am certain winching is a lot more dangerous. There are more things that can go wrong and if they can go wrong, they will given time. "Gary Boggs" wrote in message ... I like all these points and I suspect that because of the short time required in a winch launch, and the faster acceleration, and the fact that you are in a position to land on the runway that you are using at all times, the winch launch would be safer, but I still see no statistics! Come on folks, someone surly has crunched the numbers. Training is crucial in both, but what I'm looking for is numbers, I have plenty of opinions myself. Boggs |
![]() "John Mason" wrote in message ... A good place for statistics is: http://www.esgc.co.uk/BGAdata.htm Search and study the reports. There is much written between the lines. If you look at the number of accidents where the launch was originally a winch launch you will find that a lot of accidents occur soon after the launch is completed and are attributed to other factors but which would really not have happened if they had aerotowed. (Rigging errors not found in the speed of the launch, not watching airspeed and spinning after the launch because of distraction with the high workload of the winch and not dealing with the angle of attack in the launch properly and so on). It is not possible to give clear cut statistics without a significant degree of human interpretation and you will really need to make your own mind up. I am certain winching is a lot more dangerous. There are more things that can go wrong and if they can go wrong, they will given time. John, the only way to see the data in the way you suggest is with a prejudiced eye. If a pilot can't fly a glider under stress or rig it properly, he's just an accident looking for a place to happen. It doesn't matter how the glider is launched. Bill Daniels |
On Mon, 27 Oct 2003 09:16:58 +0000 (UTC), "John Mason"
wrote: ....snippage... (Rigging errors not found in the speed of the launch, not watching airspeed and spinning after the launch because of distraction with the high workload of the winch and not dealing with the angle of attack in the launch properly and so on). ....snippage... None of these points are unique to winching. - I've seen many more comments on r.a.s about failed aero tows due to rigging errors than I've heard about for winching. To me this says more about the safety culture (or lack of it) at different sites than anything to do with the launch method. - incorrect airspeed and stall/spin after release is just as possible at the end of an aero tow if you overcook the climbing turn. - AOA mis-management will be *much* more serious during an aero tow on a CG hook than during a winch launch provided the appropriate weak link is used. Think tug upset. I launch both ways though I'll admit to many more winch than aero-tow starts. I see very little difference in pilot stress levels or workload between the launch methods in good conditions, but the overall stress from an aero tow is larger, simply because you're on tow for 5 minutes or more compared with the 30 seconds to get to the top of the cable. If I'm flying something as sluggish in roll as a G.103A in turbulent, windy conditions then winching has a much lower work load than aero-tow. This is my opinion entirely: I'm not speaking for anybody else or trying to put words in their mouth. -- martin@ : Martin Gregorie gregorie : Harlow, UK demon : co : Zappa fan & glider pilot uk : |
Hei,
John Mason wrote: (Rigging errors not found in the speed of the launch, Whit?? Do forgive my clearly insufficient knowledge of the English language, but what exactly does "rigging errors not found in the speed of the launch" mean? And how would those have been found and corrected if the launch subsequent to rigging had been by areotow rather than by winch? I mean: The fact that an aerotow takes longer time to complete does not give you any more time _prior_ to launch, does it? Christian 8-) |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
spaceship one | Pianome | Home Built | 169 | June 30th 04 05:47 AM |
The Internet public meeting on National Air Tour Standards begins Feb. 23 at 9 a.m. | Larry Dighera | Piloting | 0 | February 22nd 04 03:58 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
using winch instead of aerotow | goneill | Soaring | 5 | August 27th 03 02:46 PM |
