Gary,
I suspect you are considering winch launching for your club and I would think the biggest problem would be in getting club members, "Up to Speed" on winch operations. In way of illustrating my point, allow me to tell a little story about a local soaring operation that is no longer in business. This outfit advertised, get your "Aero-Tow Only" restriction, removed from your glider licence. Come to XXX Soaring and we will check you out in about an hour, or so. This outfit had a 2-33 with only a nose tow hook (mistake no. 1) They didn't use radios (mistake no. 2) The flight examiner weighed a good 300 lb. + your average student at 200 lb. = 500 lb's in the 2-33 (mistake no. 3) I was going to take the course, but had to wait for the student in front of me to get his check-out. The signal for "Start the launch" was, level the wings and flash the lights in the car located near the right wing tip. It went something like this: 1. Level the wings & flash the lights------------Glider rolled about 10 feet and stopped. winch operator stalled the winch. 2. Level the wings & flash the lights---------- Cable went, but glider didn't move. In the last attempt, wheel had rolled over cable and caused a reverse release. 3.Level the wings & flash the lights---------------Glider went about 100 feet and stopped. Cable had "Kinked" in previous 2 attempts and then broke at a kink. -------------30 minute delay while Nico-Press & sleves are found and cable is spliced. With 3 attempts and no success, student is having second thoughts and opens canopy and starts to climb out. Instructor tells him, everything will be fine, this time, Get back in here. 4. Level the wings & flash the lights------------ Glider takes off, to the wild applause of all those assembled. Glider only gets 400 feet due to nose tow hook location. Glider makes a 90 right and a 180 left, lands and rolls right up to the starting point. Attempts 5, 6 & 7 come off without a hitch and the Flight Examiner is called out (300 lbs) Level the wings & flash the lights-------------- Glider takes off, but only gets 300 feet, makes a modified 90/180 and plunks it down hard, way down the runway. I took this opportunity to silently disappear and my licence still reads, Aero-Tow Only. JJ Sinclair |
![]() "JJ Sinclair" wrote in message ... Gary, I suspect you are considering winch launching for your club and I would think the biggest problem would be in getting club members, "Up to Speed" on winch operations. In way of illustrating my point, allow me to tell a little story about a local soaring operation that is no longer in business. This outfit advertised, get your "Aero-Tow Only" restriction, removed from your glider licence. Come to XXX Soaring and we will check you out in about an hour, or so. This outfit had a 2-33 with only a nose tow hook (mistake no. 1) They didn't use radios (mistake no. 2) The flight examiner weighed a good 300 lb. + your average student at 200 lb. = 500 lb's in the 2-33 (mistake no. 3) I was going to take the course, but had to wait for the student in front of me to get his check-out. The signal for "Start the launch" was, level the wings and flash the lights in the car located near the right wing tip. It went something like this: 1. Level the wings & flash the lights------------Glider rolled about 10 feet and stopped. winch operator stalled the winch. 2. Level the wings & flash the lights---------- Cable went, but glider didn't move. In the last attempt, wheel had rolled over cable and caused a reverse release. 3.Level the wings & flash the lights---------------Glider went about 100 feet and stopped. Cable had "Kinked" in previous 2 attempts and then broke at a kink. -------------30 minute delay while Nico-Press & sleves are found and cable is spliced. With 3 attempts and no success, student is having second thoughts and opens canopy and starts to climb out. Instructor tells him, everything will be fine, this time, Get back in here. 4. Level the wings & flash the lights------------ Glider takes off, to the wild applause of all those assembled. Glider only gets 400 feet due to nose tow hook location. Glider makes a 90 right and a 180 left, lands and rolls right up to the starting point. Attempts 5, 6 & 7 come off without a hitch and the Flight Examiner is called out (300 lbs) Level the wings & flash the lights-------------- Glider takes off, but only gets 300 feet, makes a modified 90/180 and plunks it down hard, way down the runway. I took this opportunity to silently disappear and my licence still reads, Aero-Tow Only. JJ Sinclair What JJ experienced is, unfortunately, an all too common experience in the USA. A bunch of guys, (it's usually guys) get together and decide to winch launch gliders. ("How hard can it be?" "We can teach ourselves...") They start with poor equipment, a bad site, no experience or training and proceed to scare themselves badly...or worse. They then decide that the problem is winch launch (It doesn't work, low releases, lots of hassles, etc..) and then go back to air tow. I've flown tugs and driven winches - I'll take winches for fun. I've flown lots of air tow and been scared on plenty of occasions. I've flown lots of winch launches and rarely had one go wrong. If anybody wants a winch experienced CFI-G for a week of winch training, email me. I might be available. BTW, How about some of our British and European friends with lots of winch experience jumping in here? Bill Daniels |
Bill Daniels wrote:
BTW, How about some of our British and European friends with lots of winch experience jumping in here? I can't speak for others, but I read this thread, shaked my head and simply didn't feel like commenting. Seldom I have seen a discussion which showed so clearly plain ignorance. In a word: If done correctly, winch launching is safe, cheap and fun. It is certainly much (much!) cheaper than aero-tow. It is certainly much more fun. And it's easier, too. The only dangerous moment for the pilot is at the very beginning of the pull. It is very very very important not to pull too early or too briskly. Stalling the glider at this altitude is lethal. Once established in the climb, make sure you have always enough speed to pull over if the rope breaks. Everything else is very easy and very safe. There *are* rope breaks, but they are very much a non-event. Either you have enough room to land straight, or you have enough altitude to do a 180 or a short circuit. Winch launching has much more safety issues for the ground crew and spectators than for the pilot. Be sure to have an experienced person show you safe procedures. Of course, an experienced winch driver helps a lot, too. At our club, a new winch driver must do 50 launches under supervision befor he's allowed to winch alone. We never had a winch accident in 40 years. Stefan |
![]() "Stefan" wrote in message ... Bill Daniels wrote: BTW, How about some of our British and European friends with lots of winch experience jumping in here? I can't speak for others, but I read this thread, shaked my head and simply didn't feel like commenting. Seldom I have seen a discussion which showed so clearly plain ignorance. In a word: If done correctly, winch launching is safe, cheap and fun. It is certainly much (much!) cheaper than aero-tow. It is certainly much more fun. And it's easier, too. The only dangerous moment for the pilot is at the very beginning of the pull. It is very very very important not to pull too early or too briskly. Stalling the glider at this altitude is lethal. Once established in the climb, make sure you have always enough speed to pull over if the rope breaks. Everything else is very easy and very safe. There *are* rope breaks, but they are very much a non-event. Either you have enough room to land straight, or you have enough altitude to do a 180 or a short circuit. Winch launching has much more safety issues for the ground crew and spectators than for the pilot. Be sure to have an experienced person show you safe procedures. Of course, an experienced winch driver helps a lot, too. At our club, a new winch driver must do 50 launches under supervision befor he's allowed to winch alone. We never had a winch accident in 40 years. Stefan Thanks, Stefan, we need to hear more of this sort of thing. Bill Daniels |
Bill Daniels wrote:
BTW, How about some of our British and European friends with lots of winch experience jumping in here? I can't speak for others, but I read this thread, shaked my head and simply didn't feel like commenting. Seldom I have seen a discussion which showed so clearly plain ignorance. In a word: If done correctly, winch launching is safe, cheap and fun. It is certainly much (much!) cheaper than aero-tow. It is certainly much more fun. And it's easier, too. The only dangerous moment for the pilot is at the very beginning of the pull. It is very very very important not to pull too early or too briskly. Stalling the glider at this altitude is lethal. Once established in the climb, make sure you have always enough speed to push over if the rope breaks. Everything else is very easy and very safe. There *are* rope breaks, but they are very much a non-event. Either you have enough room to land straight, or you have enough altitude to do a 180 or a short circuit. Winch launching has much more safety issues for the ground crew and spectators than for the pilot. Be sure to have an experienced person show you safe procedures. Of course, an experienced winch driver helps a lot, too. At our club, a new winch driver must do 50 launches under supervision befor he's allowed to winch alone. We never had a winch accident in 40 years. Stefan |
![]() "Stefan" wrote in message ... Bill Daniels wrote: BTW, How about some of our British and European friends with lots of winch experience jumping in here? SNIP Winch launching has much more safety issues for the ground crew and spectators than for the pilot. Be sure to have an experienced person show you safe procedures. Of course, an experienced winch driver helps a lot, too. At our club, a new winch driver must do 50 launches under supervision befor he's allowed to winch alone. We never had a winch accident in 40 years. Stefan We do 40, 20 as observer/helper, and 20 supervised, but our winch is a simple single-drummed affair. Frank Whiteley |
![]() "F.L. Whiteley" wrote in message ... "Stefan" wrote in message ... Bill Daniels wrote: BTW, How about some of our British and European friends with lots of winch experience jumping in here? SNIP Winch launching has much more safety issues for the ground crew and spectators than for the pilot. Be sure to have an experienced person show you safe procedures. Of course, an experienced winch driver helps a lot, too. At our club, a new winch driver must do 50 launches under supervision befor he's allowed to winch alone. We never had a winch accident in 40 years. Stefan We do 40, 20 as observer/helper, and 20 supervised, but our winch is a simple single-drummed affair. Frank Whiteley Let me amend this to say a minimum of 40. To that end, you may have driven a winch hundreds or thousands of times and still not have seen it all, and hopefully, never will. Frank Whiteley |
In Germany, the requirement is 100 supervised launches on at least 10
different days. -- Bert Willing ASW20 "TW" "F.L. Whiteley" a écrit dans le message de ... Let me amend this to say a minimum of 40. To that end, you may have driven a winch hundreds or thousands of times and still not have seen it all, and hopefully, never will. Frank Whiteley |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
spaceship one | Pianome | Home Built | 169 | June 30th 04 05:47 AM |
The Internet public meeting on National Air Tour Standards begins Feb. 23 at 9 a.m. | Larry Dighera | Piloting | 0 | February 22nd 04 03:58 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
using winch instead of aerotow | goneill | Soaring | 5 | August 27th 03 02:46 PM |
