What is poly paint? What are the
pros and cons of poly paint compared to gel coat? Hi Miguel, There are two "Poly" paints used on sailplanes, Polyeurathane and Acrylic Urathane. I just repainted my Genesis 2 with Acrylic Urathane and found it very easy to work with. Preped the non-damaged areas by contouring with 60 grit, followed by 220 and then paint with 3 medium coats. Wet sandad with 600wet and 800wet, then wool buffer and liquid rubbing compound. The Genesis 2 and LAK -17 are painted with Acrylic Urathane by the manufacturer. The only down-side that I am aware of, is the softer paint (urathane) may blister more quickly, if left too long in a wet trailer JJ Sinclair |
JJ Sinclair wrote:
The Genesis 2 and LAK -17 are painted with Acrylic Urathane by the manufacturer. The only down-side that I am aware of, is the softer paint (urathane) may blister more quickly, if left too long in a wet trailer JJ Sinclair Actually the choice of paint is an option (at least on the LAK-17). Ours is painted in painted with polyurethane. For $400 more we could have had it painted in acrylic urethane, but we couldn't find anyone who would say flat out it was worth the extra money. They also give you the option of the ugly (but apparently bulletproof) epoxy paint that was standard on the earlier LAKs... Marc |
option of the ugly (but apparently bulletproof) epoxy paint that was I would stay away from the epoxy paint because it yellows very rapidly and one ends up with a ship the color of urine. BTW, I have the color of the Acrylic Urathane used on the Genesis 2. It is; Toyota 040/HP JJ Sinclair |
Paint Stripper? | PETER H. OUELLETTE | Home Built | 9 | November 30th 04 06:12 PM |
One coat paint for aluminum? | [email protected] | Home Built | 10 | September 17th 04 07:01 AM |
Good Paint Remover? | Marco Leon | Owning | 2 | June 22nd 04 07:58 PM |
Radar Absorbing Paint | robert arndt | Military Aviation | 2 | December 2nd 03 05:09 PM |
Choice of Paint for use over Copper foil Antennas | Charlie Precourt | Home Built | 1 | December 2nd 03 02:51 AM |
