Antti --
I really appreciate that photo. It appears to be a twin drum machine with right angle drives to each drum. Do you know how the builders got that power to go around the corner, that is, does it use a conventional automotive-type differential, angle gears, or what? Thanks again, BJ Antti Glad wrote: There are some very nice advantages to a winch (wouldn't think twice about getting a launch even if the weather does not look so great, we had some great fun launching to landing circuit just for the heck of it when it was raining last summer). We've got a package deal in our club, unlimited launches for a reasonable price. It's just very economical (make no mistake though, I do appreciate the convenience of an aerotow as well). Still, a winch launch will teach you how to make the best of the conditions as you don't have much time to find a thermal. We've got a "factory built" winch from Germany a few years back, top of the notch with turbos and whatnot- if you're interested, have a look at http://www.saunalahti.fi/kily/paasivu.htm. Click on "kalusto", the fourth button on the left frame and then "vintturi" on the right frame. Sorry, it's all in Finnish :-) Kind regards, Antti |
Most European winches are hydraulic drives.
"Bob Johnson" wrote in message ... Antti -- I really appreciate that photo. It appears to be a twin drum machine with right angle drives to each drum. Do you know how the builders got that power to go around the corner, that is, does it use a conventional automotive-type differential, angle gears, or what? Thanks again, BJ Antti Glad wrote: There are some very nice advantages to a winch (wouldn't think twice about getting a launch even if the weather does not look so great, we had some great fun launching to landing circuit just for the heck of it when it was raining last summer). We've got a package deal in our club, unlimited launches for a reasonable price. It's just very economical (make no mistake though, I do appreciate the convenience of an aerotow as well). Still, a winch launch will teach you how to make the best of the conditions as you don't have much time to find a thermal. We've got a "factory built" winch from Germany a few years back, top of the notch with turbos and whatnot- if you're interested, have a look at http://www.saunalahti.fi/kily/paasivu.htm. Click on "kalusto", the fourth button on the left frame and then "vintturi" on the right frame. Sorry, it's all in Finnish :-) Kind regards, Antti |
On Fri, 31 Oct 2003 16:10:15 -0600, Bob Johnson
wrote: Antti -- I really appreciate that photo. It appears to be a twin drum machine with right angle drives to each drum. Do you know how the builders got that power to go around the corner, that is, does it use a conventional automotive-type differential, angle gears, or what? Supacats, anyway, have a massive purpose designed gearbox mounted between the twin drums. It is driven via a fluid clutch and drives the two outputs via dog clutches as well as the oscillating pay-on arms. There are three separate brake systems (one on each drum, plus one on the output side of the fluid clutch). The drum brakes have independent hydraulic circuits connected to separate brake levers. The input brake and the output dog clutches are mechanically interconnected on a single lever - it moves sideways to select left, right or no drum and back to apply the brake on the clutch output. In addition there are payout brake levers that apply light pressure to the drum calipers while the cable is being pulled out. The separate throttle connects to the Deutz diesel via a profiled cam that gives a more or less linear power response. By that I mean that more or less equal movements give similar power increments over the whole range. It makes smooth launches a lot easier. Safety: pulling rather than pushing the throttle cuts the motor. Both guillotines are operated simultaneously from an in-cab hydraulic circuit or, if this fails, each can be fired mechanically from outside. A flashing yellow light on top the cap operates when the winch is running and in gear. Nobody touches either cable when its flashing. Climate control: there is a diesel burning heater for winter and the sliding doors open in summer. HTH -- martin@ : Martin Gregorie gregorie : Harlow, UK demon : co : Zappa fan & glider pilot uk : |
Martin --
A very good description, thanks for providing it! As an experiment, we attempted to use the differential that came in the same heavy duty pickup truck that furnished our 454 c.i. engine. This unit was mounted as you would expect between the twin drums and one drum was braked by its respective master cylinder brake lever, leaving the power to be applied to the opposite drum. This arrangement went fine for about an half-dozen launches, when the diff over-heated and eventually gave up the ghost. Thus we learned that the differential feature as we were using it would have to be disabled and a couple of dog clutches would have to be devised in order to turn our winch into a true double-drum unit. BJ Martin Gregorie wrote: On Fri, 31 Oct 2003 16:10:15 -0600, Bob Johnson wrote: Antti -- I really appreciate that photo. It appears to be a twin drum machine with right angle drives to each drum. Do you know how the builders got that power to go around the corner, that is, does it use a conventional automotive-type differential, angle gears, or what? Supacats, anyway, have a massive purpose designed gearbox mounted between the twin drums. It is driven via a fluid clutch and drives the two outputs via dog clutches as well as the oscillating pay-on arms. There are three separate brake systems (one on each drum, plus one on the output side of the fluid clutch). The drum brakes have independent hydraulic circuits connected to separate brake levers. The input brake and the output dog clutches are mechanically interconnected on a single lever - it moves sideways to select left, right or no drum and back to apply the brake on the clutch output. In addition there are payout brake levers that apply light pressure to the drum calipers while the cable is being pulled out. The separate throttle connects to the Deutz diesel via a profiled cam that gives a more or less linear power response. By that I mean that more or less equal movements give similar power increments over the whole range. It makes smooth launches a lot easier. Safety: pulling rather than pushing the throttle cuts the motor. Both guillotines are operated simultaneously from an in-cab hydraulic circuit or, if this fails, each can be fired mechanically from outside. A flashing yellow light on top the cap operates when the winch is running and in gear. Nobody touches either cable when its flashing. Climate control: there is a diesel burning heater for winter and the sliding doors open in summer. HTH -- martin@ : Martin Gregorie gregorie : Harlow, UK demon : co : Zappa fan & glider pilot uk : |
On Tue, 04 Nov 2003 20:30:54 -0600, Bob Johnson
wrote: Martin -- A very good description, thanks for providing it! ...../.... Thus we learned that the differential feature as we were using it would have to be disabled and a couple of dog clutches would have to be devised in order to turn our winch into a true double-drum unit. The Supacat neutral and third brake is a useful design feature. With the lever released and the engine running the gear-box is spun up, so its oil is kept moving (good on a cold day) and the fluid clutch won't overheat. The combined control makes it easy to rotate the dog a little to help it engage. -- martin@ : Martin Gregorie gregorie : Harlow, UK demon : co : Zappa fan & glider pilot uk : |
A winch should never have any doors or windows open while actually
launching. The cab must be fully enclosed, doors and windows shut. The windows must be of laminated glass or similar, with Lexan or something similar on the inside surfaces. Any openings not glazed must be protected with expanded metal sheet, weldmesh or similar. If the cable breaks, and sooner or later it will, it can get inside the winch through any opening with amazing ferocity. One of the Long Mynd amateur winch drivers had the back window slightly open. The cable broke, came in through the window and attacked his clothing. He considered he had a very lucky escape, and has given up driving the winch. At another club one of the most experienced of all winch drivers parked his car directly behind the winch and facing it, what he thought was a safe distance away. This was at a busy club which has done many thousands of winch launches every year for a very long time. The cable broke and flew back, trashing the back of his car and round the car to break one of the front door windows. I saw the car afterwards and asked who had run into him. This sort of thing does not happen very often so it takes people by surprise. It is a completely avoidable risk and is just not worth taking. W.J. (Bill) Dean (U.K.). Remove "ic" to reply. "Martin Gregorie" wrote in message ... snip Climate control: there is a diesel burning heater for winter and the sliding doors open in summer. Martin Gregorie |
Hi Bill --
After my limited experience with it, I can't help but think that synthetic is going to be a lot safer and less nasty to work with during breaks or whenever else it has to be dodged or handled. It's light as a feather, soft as a baby's butt and stores absolutely no energy. BJ "W.J. (Bill) Dean (U.K.)." wrote: A winch should never have any doors or windows open while actually launching. The cab must be fully enclosed, doors and windows shut. The windows must be of laminated glass or similar, with Lexan or something similar on the inside surfaces. Any openings not glazed must be protected with expanded metal sheet, weldmesh or similar. If the cable breaks, and sooner or later it will, it can get inside the winch through any opening with amazing ferocity. One of the Long Mynd amateur winch drivers had the back window slightly open. The cable broke, came in through the window and attacked his clothing. He considered he had a very lucky escape, and has given up driving the winch. At another club one of the most experienced of all winch drivers parked his car directly behind the winch and facing it, what he thought was a safe distance away. This was at a busy club which has done many thousands of winch launches every year for a very long time. The cable broke and flew back, trashing the back of his car and round the car to break one of the front door windows. I saw the car afterwards and asked who had run into him. This sort of thing does not happen very often so it takes people by surprise. It is a completely avoidable risk and is just not worth taking. W.J. (Bill) Dean (U.K.). Remove "ic" to reply. "Martin Gregorie" wrote in message ... snip Climate control: there is a diesel burning heater for winter and the sliding doors open in summer. Martin Gregorie |
Just a few points.
The sort of incidents I described are very rare, which is why people are sometimes not ready for them and may be caught. It would take many years of operation with synthetic before one could be sure that it could never behave as wire occasionally does. It is not just energy stored in the wire due to elasticity, it is also the energy due to its weight and speed. Synthetic may have less weight, but it still has some. Will winches be designed only for synthetic cable, and never used with wire? Even if the intention is to use synthetic, the winch should be designed so that wire can be used, and winch drivers should be trained for this. W.J. (Bill) Dean (U.K.). Remove "ic" to reply. "Bob Johnson" wrote in message ... Hi Bill -- After my limited experience with it, I can't help but think that synthetic is going to be a lot safer and less nasty to work with during breaks or whenever else it has to be dodged or handled. It's light as a feather, soft as a baby's butt and stores absolutely no energy. BJ "W.J. (Bill) Dean (U.K.)." wrote: A winch should never have any doors or windows open while actually launching. The cab must be fully enclosed, doors and windows shut. The windows must be of laminated glass or similar, with Lexan or something similar on the inside surfaces. Any openings not glazed must be protected with expanded metal sheet, weldmesh or similar. If the cable breaks, and sooner or later it will, it can get inside the winch through any opening with amazing ferocity. One of the Long Mynd amateur winch drivers had the back window slightly open. The cable broke, came in through the window and attacked his clothing. He considered he had a very lucky escape, and has given up driving the winch. At another club one of the most experienced of all winch drivers parked his car directly behind the winch and facing it, what he thought was a safe distance away. This was at a busy club which has done many thousands of winch launches every year for a very long time. The cable broke and flew back, trashing the back of his car and round the car to break one of the front door windows. I saw the car afterwards and asked who had run into him. This sort of thing does not happen very often so it takes people by surprise. It is a completely avoidable risk and is just not worth taking. W.J. (Bill) Dean (U.K.). Remove "ic" to reply. "Martin Gregorie" wrote in message ... snip Climate control: there is a diesel burning heater for winter and the sliding doors open in summer. Martin Gregorie |
Ask arround the sailing community about how much one can be hurt by a
flailing synthetic rope - it might not be as bad as wire in some ways but because it is infinately more flexible it can be just as bad. "Bob Johnson" wrote in message ... Hi Bill -- After my limited experience with it, I can't help but think that synthetic is going to be a lot safer and less nasty to work with during breaks or whenever else it has to be dodged or handled. It's light as a feather, soft as a baby's butt and stores absolutely no energy. BJ "W.J. (Bill) Dean (U.K.)." wrote: A winch should never have any doors or windows open while actually launching. The cab must be fully enclosed, doors and windows shut. The windows must be of laminated glass or similar, with Lexan or something similar on the inside surfaces. Any openings not glazed must be protected with expanded metal sheet, weldmesh or similar. If the cable breaks, and sooner or later it will, it can get inside the winch through any opening with amazing ferocity. One of the Long Mynd amateur winch drivers had the back window slightly open. The cable broke, came in through the window and attacked his clothing. He considered he had a very lucky escape, and has given up driving the winch. At another club one of the most experienced of all winch drivers parked his car directly behind the winch and facing it, what he thought was a safe distance away. This was at a busy club which has done many thousands of winch launches every year for a very long time. The cable broke and flew back, trashing the back of his car and round the car to break one of the front door windows. I saw the car afterwards and asked who had run into him. This sort of thing does not happen very often so it takes people by surprise. It is a completely avoidable risk and is just not worth taking. W.J. (Bill) Dean (U.K.). Remove "ic" to reply. "Martin Gregorie" wrote in message ... snip Climate control: there is a diesel burning heater for winter and the sliding doors open in summer. Martin Gregorie |
Stephen is right - IF you get tangled in it while it is under tension,
Spectra cut right through you like any strong line. Since you need a strong line, there's no getting away from that. The real danger from winch line is ballistic impact and there steel is far more dangerous. The commercial shipping and barge industries have almost completely switched from wire rope to Spectra on the safety issue alone. Steel stretches,storing energy like a spring - that energy is released in a springback when it breaks. Steel cable used to result in a hundred or so deck hand deaths a year. Spectra has eliminated those deaths. Spectra creeps under load and creeps back a little when it breaks - no real danger there. Spectra does not eliminate the danger posed by line termination hardware like carabiners and weak links. Those can hit the winch cab with the energy of a pistol bullet. A good strong, armored cab is still a necessity. (A heater and air conditioner would be nice too.) Bob is right in that Spectra is sweet to work with. Bare hands are fine - no gloves needed to protect your hands from "fish hooks" that are common with stranded steel cable. It's not black and white, but steel is far more dangerous than spectra and that alone makes it worth the switch. Bill Daniels "Stephen Haley" wrote in message ... Ask arround the sailing community about how much one can be hurt by a flailing synthetic rope - it might not be as bad as wire in some ways but because it is infinately more flexible it can be just as bad. "Bob Johnson" wrote in message ... Hi Bill -- After my limited experience with it, I can't help but think that synthetic is going to be a lot safer and less nasty to work with during breaks or whenever else it has to be dodged or handled. It's light as a feather, soft as a baby's butt and stores absolutely no energy. BJ |
Safety of winch launch vrs. aero tow? | Gary Boggs | Soaring | 172 | November 13th 03 06:59 PM |
Tost internal Winch | HL Falbaum | Soaring | 3 | September 24th 03 02:31 PM |
using winch instead of aerotow | goneill | Soaring | 5 | August 27th 03 02:46 PM |
Winch cable | Bill Daniels | Soaring | 5 | August 24th 03 11:13 PM |
Using Plasma Rope For Winch Tows | Craig Freeman | Soaring | 56 | August 24th 03 10:55 PM |
