"Peter Seddon" wrote in message news:3fa3cff6I once owned an ultralight aircraft called "American Falcon". Some of you may recall their adverts on the back of some flying mag , with Chuck Yaeger' face endorcing the little high wing canard.
It's wing is/was covered in Tedlar. This is a Du-pont product that is stuck to the top of ribs etc with a foam backed doubled sided tape, and subsequently heat shrunk. i recovered the wing myself with the help of a couple of friends. My guess is that with a strip of polyester doubled sided tape along the trailing edge, top and bottom just ahead of the aielrons etc, a perimeter of this around the airbrake box, place some more around the root and tip, this would do a great job. Tedlar is used as a decorative/protective coating on all those compound panels you see around windows in 737's etc. It has a huge shring rate, and would certainly give a wrinkle free finish if applied correctly. Better still the roll of Tedlar I got (in white ) was 1.5m wide. Cheers Mark ... Ian, I think you are on to something. I read several years ago about an aircraft finishing system that involved an thin film that was heat shrunk onto metal skins covering joints, rivets and all. Bill Daniels Solarfilm has been around for years so the available info on its propeties should be somewere on the net. I can vouch for its strength, I've seen balsa models after a crash that look like a bag of bits, the film virtualy intact. Peter S DLA |
Refinishing radio stack front panels | Roger Halstead | Home Built | 2 | September 15th 04 04:20 PM |
Carbon Fiber - Achieving Glossy Finish w/o GelCoat | RKT | Home Built | 7 | March 8th 04 06:15 AM |
Refinishing Your Aircraft (now in Oregon) | aerocomposites | Home Built | 0 | September 24th 03 05:29 AM |
