Refinishing gelcoat
Old November 2nd 03, 08:39 PM
Mark
I once owned an ultralight aircraft called "American Falcon". Some of
you may recall their adverts on the back of some flying mag , with
Chuck Yaeger's face endorcing the little high wing canard.
It's wing is/was covered in Tedlar. This is a Du-pont product that is
stuck to the top of ribs etc with a foam backed doubled sided tape,
and subsequently heat shrunk. I re-covered the wing myself with the
help of a couple of friends.Any joints are done with a simple 2" wide
lap with an 8 thou' 1" wide polyester double sided tape.
My guess is that with a strip of polyester doubled sided tape along
the trailing edge, top and bottom just ahead of the ailerons etc, a
perimeter of this around the airbrake box, place some more around the
root and tip, this would do a great job.
Tedlar is used as a decorative/protective coating on all those
compound panels you see around windows in 737's etc.
It has a huge shring rate, and would certainly give a wrinkle free
finish if applied correctly. Better still the roll of Tedlar I got (in
white ) was 1.5m wide.
Cheers
Mark
Refinishing radio stack front panels Roger Halstead Home Built 2 September 15th 04 04:20 PM
Carbon Fiber - Achieving Glossy Finish w/o GelCoat RKT Home Built 7 March 8th 04 06:15 AM
Refinishing Your Aircraft (now in Oregon) aerocomposites Home Built 0 September 24th 03 05:29 AM
