Colin wrote:
Many years ago a highly respected aerobatic pilot in UK (still working today) wrote an article in our Pilot magazine on this subject. He reminded us that three things were required: 1. A rapid 180 degree change of heading. 2. Minimum loss of height. 3. Normal airspeed at the end of the manoever. Controversially, he maintained that a highly banked slipping turn satisfies all three criteria. The rate of decent is very high during the turn, but the duration is so short that it results in less height loss than either of the two alternatives (eg:slow and gentle or fast and furious), and the airspeed is normal throughout. Just don't forget to keep loads of top rudder on. - Colin I don't see why the turn should be a slipping one, you certainly will loose more height in a slipping turn than in a normal one. And height loss is what make the turn possible or not. |
Robert Ehrlich wrote:
Colin wrote: Many years ago a highly respected aerobatic pilot in UK (still working today) wrote an article in our Pilot magazine on this subject. He reminded us that three things were required: 1. A rapid 180 degree change of heading. 2. Minimum loss of height. 3. Normal airspeed at the end of the manoever. Controversially, he maintained that a highly banked slipping turn satisfies all three criteria. The rate of decent is very high during the turn, but the duration is so short that it results in less height loss than either of the two alternatives (eg:slow and gentle or fast and furious), and the airspeed is normal throughout. Just don't forget to keep loads of top rudder on. - Colin I don't see why the turn should be a slipping one, you certainly will loose more height in a slipping turn than in a normal one. And height loss is what make the turn possible or not. 1. A slipping turn can be made at a high bank angle and low airspeed. 2. Rate of turn is dependent on angle of bank and airspeed, such that the highest rate of turn is achieved with a high bank angle and a low airspeed. Brian illustrated this by inviting us to compare the rate of turn achieved by a C150 and a jet fighter at the same angle of bank. It has to be a slipping turn or we would stall, so the maximum bank which can be used is dependent on the amount of top rudder available. - Colin |
![]() Colin wrote: I don't see why the turn should be a slipping one, you certainly will loose more height in a slipping turn than in a normal one. And height loss is what make the turn possible or not. 1. A slipping turn can be made at a high bank angle and low airspeed. I don't understand this: at any given bank angle, how can you achieve a lower airspeed when you are slipping? Doesn't that require more elevator power? How would a slipping turn enable that? |
On Thu, 06 Nov 2003 00:02:30 +0000, Colin wrote:
1. A slipping turn can be made at a high bank angle and low airspeed. I believe in (and teach) a few basic principles when flying close to the ground. - Stall/spin accidents kill more pilots than any other single cause. - Stalls occur when you fly too slowly. - Spins occur when you stall and the glider is not "co-ordinated" ie either slipping or skidding. Therefore if you are flying close to the ground, keep the airspeed comfortably above stalling speed. And if you can't do that, keep the aircraft co-ordinated. (When instructing, close to the ground, if the student can't maintain a steady airspeed, I take over control at the first sign of loss of co-ordination). Using a low airspeed slipping turn to turn 180 deg when less than 200 ft above the ground sounds like the advice that a legendary grandmother is once said to have given "now son, be careful when you go flying, don't fly to high and don't fly too fast!" Maybe some aerobatic super pilot can prove me wrong, but if you have to resort to these measures to get back to the field then I think you would probably be better off taking your chances going in straight ahead. Ian (I have seen gliders “land” in some unusual places and get away with relatively minor damage and no injuries. Provided the glider is flown in a controlled manner to the point of touch down, and the landing is done with lowest possible energy - full flaps, into wind, air brakes closed - damage is often minor. On the other hand I have seen two crashes where the glider went in wing tip first and cartwheeled. Both were right-offs with serious injuries.) |
Ian Forbes wrote:
On Thu, 06 Nov 2003 00:02:30 +0000, Colin wrote: - Spins occur when you stall and the glider is not "co-ordinated" ie either slipping or skidding. I used to think this, but I soon discovered our club Blanik would happily spin from a coordinated turn by using a shallow bank and simply reducing the airspeed. Since then, I've done this with other gliders. A coordinated turn doesn't prevent the inner wing from flying at a higher angle of attack than the outer wing, which is why it stalls first, and a spin can begin. I haven't experimented with it enough to be certain, but I suspect a slipping turn would reduce the tendency for the inner wing to stall first. |
Eric,
Point of interest: did you let the spin fully develop after the coordinated turning stall? There is an aerodynamic tipping point -- that is the self-righting tendency of the tail that would typically favor a spiral over a spin assuming that the only deflected control surface was the elevator. Of course a wing drops when in a turning stall, but without aileron deflection generating drag my guess would be that designed yaw stability would prevent spin development. There is a significant difference in the assymetric drag profile with and without aileron deflection. Remember that most modern aircraft begin their stall at the root. That means less torque and less disposition to overpower yaw stability and enter a spin. Slapping an aileron down to pick up the low wing adds significat drag at the tip. Add some rudder (cross-controls), and now you have a greater disposition to get the aircraft spinning rather than spiralling. I'll give this a try over the weekend -- that is, making no recovery to a coordinated turning stall to see how it develops. My Ventus spins happily if aggrevated. It should prove a good test bed. Eric Greenwell wrote in message ... Ian Forbes wrote: On Thu, 06 Nov 2003 00:02:30 +0000, Colin wrote: - Spins occur when you stall and the glider is not "co-ordinated" ie either slipping or skidding. I used to think this, but I soon discovered our club Blanik would happily spin from a coordinated turn by using a shallow bank and simply reducing the airspeed. Since then, I've done this with other gliders. A coordinated turn doesn't prevent the inner wing from flying at a higher angle of attack than the outer wing, which is why it stalls first, and a spin can begin. I haven't experimented with it enough to be certain, but I suspect a slipping turn would reduce the tendency for the inner wing to stall first. |
Most pilots instinctively recover long before they can
tell the difference between a stall -- recovery -- spiral dive scenario and a stall -- spin. This often causes confusion about which is which. I personally intentionally tried a spin entry once in a glass glider and got a surprise and made an immediate spin recovery. It seems the airspeed indicator rotates all the way around, so 80 knots indicated is the same as 20 knots indicated. Imagine my surprise when the glider stalls, the nose drops, and the ASI wobbles and then indicates ??? I tried it a few more times and by god could never tell the difference, so I was too scared to do anything but recover immediately (release the cross-controlled inputs). Whichever it was, the glider sure picked up speed like lightning when nose down. I still wonder if this killed the Nimbus4DM pilots in Reno. Imagine looking at the ASI and not knowing if you should be doing a spin recovery or a spiral recovery (two very different things). |
You've just described a cross-control stall. I think Eric's point was
that the additional drag at the wingtip wasn't necessary to initiate auto rotation. The control inputs you've described are counter intuitive. Is this a peculiarity of the Blanik? I only have a couple of flights in them. Typically, shallow banked turns like to roll level, especially if there is any tendency to slip (dihedral). In most of the models I've flown, overbanking doesn't become noticeable until you reach 30+ degrees. Bruce Hoult wrote in message ... In article , (Chris OCallaghan) wrote: Point of interest: did you let the spin fully develop after the coordinated turning stall? There is an aerodynamic tipping point -- that is the self-righting tendency of the tail that would typically favor a spiral over a spin assuming that the only deflected control surface was the elevator. Of course a wing drops when in a turning stall, but without aileron deflection generating drag my guess would be that designed yaw stability would prevent spin development. Even with the string in the middle, the elevator will *not* be the only deflected control surface. The Blanik makes this very obvious. As you slow down in a shallow turn (10 degrees, say) you need more and more out of turn aileron in order to prevent the turn from steepening, and you need more and more into turn rudder to keep the string in the middle. Both controls can get a significant way towards their limits in what seems like a perfectly normal turn. When the inner wing eventually stalls everything is perfectly set up for a rapid departure and spin. -- Bruce |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
spaceship one | Pianome | Home Built | 169 | June 30th 04 05:47 AM |
The Internet public meeting on National Air Tour Standards begins Feb. 23 at 9 a.m. | Larry Dighera | Piloting | 0 | February 22nd 04 03:58 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
using winch instead of aerotow | goneill | Soaring | 5 | August 27th 03 02:46 PM |
