Hi GR,
It's winter, what else you got to do. Start refinishing the sucker. All the urethane must be removed and any lose, cracked or pealing gel-coat, also. Get an air supply and an air-board (2.5 X 18) Jump on her with 40 grit, when your new air-board is completely worn out, you should be about ready to prime and then contour, by hand with 60 grit on a 2.5 X 18 board. Tidy up the 60 grit scratches with some 120 free hand work (those scratches give the paint *tooth*) Now your ready to shoot acrylic urathane. Give her 3 medium to wet coats and then contour with 600 wet followad by 800 wet. Now jump on her with your wool buffer and liquid buffing compound. Buff out at least twice. Put your numbers back on, stick-on are easiest, then wax, after the paint is at least a month old. By now it should be spring. Take your nice little cutie out and let all the other guys drool. JJ Sinclair |
other guys drool. JJ Sinclair I am leaning towards just sanding and flying it UGLY for the first season. I can always paint or redo the finish properly NEXT winter. Or maybe do it progressivley: One wing this year, do the other one next year. It will look a bit odd with one beautiful wing and one ... not so good. Or do just the elevator and see how it goes, so you can judge the amount of time better! |
molding plexiglas websites? | [email protected] | Owning | 44 | February 17th 05 09:33 PM |
Glass Cockpit in Older Planes | Charles Talleyrand | Owning | 2 | May 20th 04 01:20 AM |
C182 Glass Panel | Scott Schluer | Piloting | 15 | February 27th 04 03:52 PM |
2 glass HUD question | Jim Yanik | Military Aviation | 0 | January 30th 04 02:22 AM |
Discus Wing question | John Galloway | Soaring | 6 | August 23rd 03 07:52 AM |
