-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1 Jerry, What kind of o-ring is used? Evan Jerry J. Wass wrote: Have you tried an AN fitting in the hole--if it's recessed for an "O" ring then use an AN union + O-ring---may have to cut off the flare if it won't go all the way in. (they make special fittings like this,(esp. for hydraulic pumps) but I never have one when I need it Evan Carew wrote: Do I need to get those special (straight thread) fittings for my fuel pump or are the regular NPT AN fittings good enough. Thanks, Evan -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.0.6 (GNU/Linux) Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org iD8DBQFBXISjoo/Prlj9GScRAqNpAJwLIry6ED+eP4TRflgDeq2o3h6SUwCbBaxk +FsKvIX0rKapAIRfPAbXW0I= =dgDN -----END PGP SIGNATURE----- |
Evan Carew wrote...
What kind of o-ring is used? *sigh* http://www.aircraftspruce.com/catalo...ycfuelpump.php See bottom of page. http://www.wicksaircraft.com/catalog...641/index.html http://www.vansaircraft.com/cgi-bin/catalog.cgi and search for 'fuel pump fittings' http://www.chiefaircraft.com/cgi-bin...search-air.cgi and search for 'fuel pump hardware' I'm sure there are more. Dave 'fitting end' Hyde |
Hash: SHA1 Dave, Yeah, I've been to those exact pages, & will note for the record that none of those pages mention an o-ring for sale, however, the pictures do indicate that the parts come with said o-ring. If not, like I said, I would like to know the particulars for when I go a calling the very well informed A&S sales people (tongue firmly in cheek here). Dave Hyde wrote: Evan Carew wrote... What kind of o-ring is used? *sigh* http://www.aircraftspruce.com/catalo...ycfuelpump.php See bottom of page. http://www.wicksaircraft.com/catalog...641/index.html http://www.vansaircraft.com/cgi-bin/catalog.cgi and search for 'fuel pump fittings' http://www.chiefaircraft.com/cgi-bin...search-air.cgi and search for 'fuel pump hardware' I'm sure there are more. Dave 'fitting end' Hyde -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.0.6 (GNU/Linux) Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org iD8DBQFBXKsVoo/Prlj9GScRAlCvAJ40LHhVymVfWBkeVKvuMQj6MR+lZwCeIvWH NO3X2HgPDpRUHvbERMrFXBk= =pk1D -----END PGP SIGNATURE----- |
Evan Carew wrote...
Yeah, I've been to those exact pages, & will note for the record that none of those pages mention an o-ring for sale... You might note that none of the fittings pictured are simple 37 deg flare to NPT fittings - there's a wider bearing surface for the O-ring/NPT end. The Lycoming standard solution does _not_ appear to be to stuff an O-ring over an NPT fitting, cut down or otherwise. Dave 'field mod' Hyde |
"Dave Hyde" wrote in message ...
Evan Carew wrote... Yeah, I've been to those exact pages, & will note for the record that none of those pages mention an o-ring for sale... You might note that none of the fittings pictured are simple 37 deg flare to NPT fittings - there's a wider bearing surface for the O-ring/NPT end. The Lycoming standard solution does _not_ appear to be to stuff an O-ring over an NPT fitting, cut down or otherwise. Dave 'field mod' Hyde ************************************************** ***************************** That fuel punp fitting must have a nut to clamp down on the "O" ring. This compresses the "O"ring and locks the fitting in place. Bob Olds RV-4 A&P , EAA Tech. Counselor Charleston,Arkansas ************************************************** ***************************** |
On Thu, 30 Sep 2004 20:55:48 -0400, Evan Carew
wrote: Dave, Yeah, I've been to those exact pages, & will note for the record that none of those pages mention an o-ring for sale, however, the pictures do indicate that the parts come with said o-ring. If not, like I said, I would like to know the particulars for when I go a calling the very well informed A&S sales people (tongue firmly in cheek here). OK, a hydraulic guy here ... don't know if oyu are after rubber type or size. These are what are normally called "SAE" fittings and use (usually) a 90 durometer nitirle material. It looks like they are SAE #6 (thread is 3/8-24), but just for grins, size thrd ID section -4 7/16-20 .351 .072 -5 1/2-20 .414 .072 -6 9/16-20 .468 .078 -8 3/4-16 .644 .087 These do not appear to be in the AS568A dash number series but are available at any fluid power fitting source. George |
Hash: SHA1 George, I had a feeling they were SAE threads as a common SAE tap set I have lying around fit the threads. Thanks also for the info on the o-rings. Sometimes its difficult to get the kind of detailed info you need to talk to a salesperson who doesn't know their product line. Its good to see that there are at least a few people who can help out on this subject from this news group. Evan GeorgeB wrote: On Thu, 30 Sep 2004 20:55:48 -0400, Evan Carew wrote: Dave, Yeah, I've been to those exact pages, & will note for the record that none of those pages mention an o-ring for sale, however, the pictures do indicate that the parts come with said o-ring. If not, like I said, I would like to know the particulars for when I go a calling the very well informed A&S sales people (tongue firmly in cheek here). OK, a hydraulic guy here ... don't know if oyu are after rubber type or size. These are what are normally called "SAE" fittings and use (usually) a 90 durometer nitirle material. It looks like they are SAE #6 (thread is 3/8-24), but just for grins, size thrd ID section -4 7/16-20 .351 .072 -5 1/2-20 .414 .072 -6 9/16-20 .468 .078 -8 3/4-16 .644 .087 These do not appear to be in the AS568A dash number series but are available at any fluid power fitting source. George -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.0.6 (GNU/Linux) Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org iD8DBQFBXXtboo/Prlj9GScRAkEcAJ91ZV8XGs4RgShULSJ+pysJpQOIxwCfRBFe AEj/M3I8ZdzCrN5mOQDUrN4= =fNwY -----END PGP SIGNATURE----- |
All the fittings are he
http://www.parker.com/tfd/cat/pdffiles/C-Triple-Lok.pdf Packings, seals and materials are he http://www.parker.com/o-ring/Literature/00-5700.pdf I work for Parker, so I am biased somewhat.... "Evan Carew" wrote in message ... -----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1 George, I had a feeling they were SAE threads as a common SAE tap set I have lying around fit the threads. Thanks also for the info on the o-rings. Sometimes its difficult to get the kind of detailed info you need to talk to a salesperson who doesn't know their product line. Its good to see that there are at least a few people who can help out on this subject from this news group. Evan GeorgeB wrote: On Thu, 30 Sep 2004 20:55:48 -0400, Evan Carew wrote: Dave, Yeah, I've been to those exact pages, & will note for the record that none of those pages mention an o-ring for sale, however, the pictures do indicate that the parts come with said o-ring. If not, like I said, I would like to know the particulars for when I go a calling the very well informed A&S sales people (tongue firmly in cheek here). OK, a hydraulic guy here ... don't know if oyu are after rubber type or size. These are what are normally called "SAE" fittings and use (usually) a 90 durometer nitirle material. It looks like they are SAE #6 (thread is 3/8-24), but just for grins, size thrd ID section -4 7/16-20 .351 .072 -5 1/2-20 .414 .072 -6 9/16-20 .468 .078 -8 3/4-16 .644 .087 These do not appear to be in the AS568A dash number series but are available at any fluid power fitting source. George -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.0.6 (GNU/Linux) Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org iD8DBQFBXXtboo/Prlj9GScRAkEcAJ91ZV8XGs4RgShULSJ+pysJpQOIxwCfRBFe AEj/M3I8ZdzCrN5mOQDUrN4= =fNwY -----END PGP SIGNATURE----- |
On Sat, 02 Oct 2004 01:20:11 GMT, "Blueskies" wrote:
All the fittings are he http://www.parker.com/tfd/cat/pdffiles/C-Triple-Lok.pdf Packings, seals and materials are he http://www.parker.com/o-ring/Literature/00-5700.pdf I work for Parker, so I am biased somewhat.... I worked for a Parker distributor and got the dims from that catalog. You folks are GREAT. I've since found that the SAE o-rings are to 568-9xx series where xx is the 2 digit dash number (nominal tube OD in 1/16" units). I listed the ones for the dimensions I gave below with the eimensions. I had a feeling they were SAE threads as a common SAE tap set I have lying around fit the threads. Thanks also for the info on the o-rings. Sometimes its difficult to get the kind of detailed info you need to talk to a salesperson who doesn't know their product line. Its good to see that there are at least a few people who can help out on this subject from this news group. Yeah, I've been to those exact pages, & will note for the record that none of those pages mention an o-ring for sale, however, the pictures do indicate that the parts come with said o-ring. If not, like I said, I would like to know the particulars for when I go a calling the very well informed A&S sales people (tongue firmly in cheek here). These are what are normally called "SAE" fittings and use (usually) a 90 durometer nitirle material. It looks like they are SAE #6 (thread is 3/8-24), but just for grins, size thrd ID section -4 7/16-20 .351 .072 568-904 -5 1/2-20 .414 .072 568-905 -6 9/16-20 .468 .078 568-906 -8 3/4-16 .644 .087 568-908 |
spaceship one | Pianome | Home Built | 169 | June 30th 04 05:47 AM |
Anybody need a fuel transfer pump? | Roy Smith | Home Built | 1 | January 5th 04 05:53 PM |
Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 02:57 AM |
Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 07:09 PM |
Christen Fuel Pump troubleshooting | ShawnD2112 | Aerobatics | 4 | August 17th 03 12:08 PM |
