I can tell you we do not monitor 121.5 at Continental on domestic flights as
a rule. If center asks we will but that's about it. "Nolaminar" wrote in message ... Just got latest information, and now learn that 121.5 is monitored by airliners.. Disregard first transmission. GA |
I don't ever recall listening on what the military folks called "guard
channel", maybe once center made a request. |
From my experience, I can say that all commercial flights do not monitor 121.5,
but enough of them do that a downed or stranded aircraft would have a good chance of contacting one. By the way, did the FAA lift the requirement for monitoring 121.5? If they did, I don't recall seeing it. Even now, on 121.5, I still hear ATC calling aircraft with whom they've lost communications and to warn aircraft about possible airspace incursions . Mark |
I should also mention that I've heard ATC warn aircraft that if they did not
change course, they would be shot down. Mark |
Mark, I'm checking with a FT. Worth FSS specialist on the published
requirement. I'm also going through the SFAR's to find the guidelines. I do know that AC(advisory circular) 99-1C addressed just exactly what happened to us post 9-11, with regard to procedures. We are required to "guard" an ATC or FSS frequency. It does not state specifically 121.5, but that would be the natural choice. We were thirty minutes out of EWR, when we were turned away that morning. We chose Parkersburg West VA. as our get out of the sky point. Three days later when we were let back in the system, one of the requirements was to monitor 121.5. We received this from the NBAA (national business aircraft association). I was led to believe early in my career that if you have a #2 radio then it should be on 121.5, and you should monitor it, in case we do something stupid like, accidently turn down the volume on our #1 radio,or miss a frequency change. Then ATC can contact you on 121.5 which is always standing "guard". This is also where we would hear the glider pilot making a distress call, or asking for a relay back to "Hobbs Air" or whatever. If we aren't monitoring then we miss a chance to assist a fellow pilot in trouble. Switch places with the guy in trouble. Wouldn't you want him to be monitoring 121.5, while sipping on his coffee, in his air conditioned jet. I can't believe, oh yes I can, that there are crews out there not monitoring, especially with the on going threat of a missle up the hind quarters, if we do something wrong. I'd hate to go on the chief pilots carpet, after being intercepted by an F-16, and tell him that I didn't know I was suppose to be monitoring 121.5, which is where ATC was trying to give me a simple frequency change. Ouch!! (MKEENE221) wrote in message ... From my experience, I can say that all commercial flights do not monitor 121.5, but enough of them do that a downed or stranded aircraft would have a good chance of contacting one. By the way, did the FAA lift the requirement for monitoring 121.5? If they did, I don't recall seeing it. Even now, on 121.5, I still hear ATC calling aircraft with whom they've lost communications and to warn aircraft about possible airspace incursions . Mark |
monitoring Thanks for checking Mick. It's difficult to monitor at all times. In the terminal area or even on a busy center frequency, listening to two conversations causes too much confusion and must be turned off. Oh and can't forget the times when it wakes me up from my nap at 390. That's really annoying! :) Mark |
but enough of them do that a downed or stranded aircraft would have a good chance of contacting one. By the way, did the FAA lift the requirement for monitoring 121.5? If they did, I don't recall seeing it. Even now, on 121.5, I still hear ATC calling aircraft with whom they've lost communications and to warn aircraft about possible airspace incursions . Mark As far as I know this NOTAM is still in effect: !FDC 1/0329 (and FDC 1/0330 Int'l version) FDC U.S. NATIONAL AIRSPACE SYSTEM INTERCEPT PROCEDURES. UNTIL FURTHER NOTICE ALL AIRCRAFT OPERATING IN THE U.S. NATIONAL AIRSPACE, IF CAPABLE, WILL MAINTAIN A LISTENING WATCH ON VHF GUARD 121.5 OR UHF 243.0. IT IS INCUMBENT ON ALL AVIATORS TO KNOW AND UNDERSTAND THEIR RESPONSIBILITIES IF INTERCEPTED. REVIEW "AERONAUTICAL INFORMATION MANUAL" SECTION 6, 5-6-2 FOR INTERCEPT PROCEDURES. AIM section 6-2-5 says, in part: d. Inflight Monitoring and Reporting. 1. Pilots are encouraged to monitor 121.5 MHz and/or 243.0 MHz while inflight to assist in identifying possible emergency ELT transmissions. On receiving a signal, report the following information to the nearest air traffic facility: (a) Your position at the time the signal was first heard. (b) Your position at the time the signal was last heard. (c) Your position at maximum signal strength. (d) Your flight altitudes and frequency on which the emergency signal was heard: 121.5 MHz or 243.0 MHz. If possible, positions should be given relative to a navigation aid. If the aircraft has homing equipment, provide the bearing to the emergency signal with each reported position. Despite the NOTAM and the AIM encouragement, I'd suspect airliners don't monitor 121.5 at all times, because the Captain and FO are using all available radios for needed traffic (meaning they are NOT "capable" of monitoring 121.5 as well), and the NOTAM's purpose is "just in case the airliner is intercepted." |
At Delta, we are REQUIRED to monitor 121.5. The company made this policy
following 9/11. Chris Fleming, 'L9' wrote in message ... I can tell you we do not monitor 121.5 at Continental on domestic flights as a rule. If center asks we will but that's about it. |
"C.Fleming" wrote in message ...
At Delta, we are REQUIRED to monitor 121.5. The company made this policy following 9/11. Chris Fleming, 'L9' Chris, How many vhf coms are standard fit on Delta airplanes? Don't you have one on ATC and the other on company if only 2 are installed? Andy (GY) |
Laser beams being aimed at airliners? | Corky Scott | Piloting | 101 | January 22nd 05 08:55 AM |
PIREPS / airliners | [email protected] | Piloting | 10 | January 21st 05 11:15 PM |
2 civilian airliners down south of Moscow | Pete | Military Aviation | 64 | September 11th 04 04:16 PM |
121.5 MHz ELT's (was Breitling Watch) | EDR | Piloting | 1 | August 21st 03 05:41 AM |
This explains the lambswool seat covers in Airliners | StellaStar | Piloting | 1 | July 10th 03 04:17 PM |
