Revised IGC-approvals for some types of legacy recorder
Old November 18th 03, 07:29 AM
Mike Borgelt
On Tue, 18 Nov 2003 05:39:03 GMT, Marc Ramsey wrote:
Bruce Hoult wrote:
And I'll ammend my earlier remarks. In 1994 when I was recommending RSA
to them I never imagined that they'd get to nearly 2004 before it became
an issue. So they may have made the correct commercial decision.
I'd make the simple point that if RSA was required when the first flight
recorder specification was issued in 1995, there were no existing flight
recorder designs which could have been approved.
So what? If RSA had been required at that time there soon would have
been.
RSA (or equivalent
asymmetric algorithm) has been required for "all flights" approval since
1997, I believe...
So it has been perfectly acceptable to fly world records for the last
5 to 6 years without RSA security with loggers approved before 1997.
If lack of RSA security was an issue why weren't legacy loggers given
say 12 months to comply or lose "all flights" approval back in 1997?
Why the change now?
Would someone tell us why this is suddenly an issue?
Which world record flights are suspect?
Isn't it a remarkable coincidence that this action is being taken
right after CAI Model 20 and 25 loggers are no longer in production?
So a would a new design without RSA security would be acceptable for
all but World Records?
If not, why not?
Mike Borgelt
Borgelt Instruments
Old November 18th 03, 08:38 AM
Marc Ramsey
been.
I wasn't involved at the time, but the reason appears fairly obvious to
me, it's called "jump-starting a market" over here.
RSA (or equivalent
1997, I believe...
Yes.
The only alternative available at the time was the Diamond-level
approval. I can imagine the outrage of the early adopters when told
they would need to spend more money to upgrade their already expensive
boxes a couple of years after they bought them. Mike, you know as well
as I do that most of those early designs would need a board swap to be
able to adequately handle RSA and the like.
Why the change now?
The gap between what is needed to be approved now, and what was needed
back then, is just too large. Among other things, it is unfair to those
who are trying to get new designs approved to have to compete against
'grandfathered' designs.
None that I am aware of. Would you prefer to wait until there were some
before an effort is made to shift the flight recorder requirements
toward those currently required for approval?
As far as I know, they are still considered to be "in production".
If not, why not?
The whole point behind adding the all badges/diplomas approval was to
allow more sensible security requirements for flight recorders used to
document flights other than world records. If you have something
specific to propose, you are welcome to contact GFAC for a formal answer.
Marc
Old November 18th 03, 09:10 AM
Bruno Ramseyer
"Paul Remde" wrote in message news:rQgub.32000$Dw6.156983@attbi_s02...
I just find this absurd. I'm very angry about the sudden change.
As Ian mentioned this decision was taken by the IGC Plenum at their
meeting
in March 2003 and was mentioned in the minutes of this meeting so no
question about sudden change.
If I remember correctly, Steve Fossett is using a GPS-NAV (and a 302 I
believe) and currently setting world records in the southern hemisphere.
I think Mr. Fossett is well capable to afford a flight recorder which
is suitable for World Records.
I'm still waiting for a good answer to the question why. Why is the GPS-NAV
suddenly not secure for world records?
Your anger must have blinded you, just read the points mentioned in
Ians mailing which is in perfect English.
This is not acceptable behavior by the IGC.
What exactly do you not find acceptable? Progress? Computing power has
changed considerably since these initial specifications were
introduced. I think pilots going for world records will be happy in
the knowledge that their traces come from FR's with the highest
security available and nobody will be able to manufacture a record by
breaking the security of these older FR's.
Regards
Bruno
IGC-GNSS Committee
Paul Remde
"Marc Ramsey" wrote in message
om...
Paul Remde wrote:
Yes, but doesn't the CAI system work? It is my impression that it is
perfectly secure and has never been compromised. So why suddenly call
it
"insecure".
As of January 1st, the CAI Model 10/20/25 won't be considered
"insecure", they just won't be considered "secure enough" for world
records. You can still use it for badges, 1000K+ diplomas, contests,
etc., just not world records.
What is the plan to get the approval back in place? What must CAI do to
make it meet your new requirements?
Minimally, a firmware upgrade would be required, but it is not clear
that the microcontroller is fast enough to support the needed changes.
The manufacturer(s?) is the only one that can provide an answer...
Marc
Old November 18th 03, 02:36 PM
Ian Strachan
In article gJfub.230766$Fm2.231960@attbi_s04, Paul Remde
writes
snip
That is up to the manufacturer, of course.
Cambridge already makes the 302 series that use the DSA public/private
key system that is assessed as equivalent in security strength to the
original Rivest, Shamir and Adleman (RSA) system. The 302 is therefore,
together with many other types of recorder, IGC-approved for "all
flights" including of course world records.
What must CAI do to
If they think it worthwhile, offer an "RSA or equivalent" upgrade for
their legacy recorder designs. The requirements are not new but go back
to 1997, see below.
For new recorder designs, "RSA or equivalent" level of security has been
in the Technical Specification for IGC-approved GNSS Flight Recorders
for many years. Here is an extract from the first edition of the IGC
Specification, effective 1 October 1997: "FRs approved for world record
flights must have an asymmetric algorithm (such as RSA) or have a system
providing equivalent security".
What we are talking about here is an adjustment to the "Grandfather
rights" provisions for recorder designs that were IGC-approved a long
time ago and do not comply with the current IGC Specification.
Incidentally, you may recall that one of the non-RSA security systems
for a GNSS recorder was successfully hacked by the Wedekinds in Germany.
This was all in the public domain and was extensively publicised at the
time. This was done as an exercise rather than for malpractice, but
shows what can be done. The manufacturer concerned immediately changed
to an RSA-based system without any prompting from IGC. The non-RSA
recorder concerned is on the list recently announced, together with
recorders with similar types of security.
It was felt that we should be even-handed to all recorder designs rather
than just adjust the IGC-approval for the Wedekind-hacked design and
leave the rest. That is what has been done, perhaps a bit late, but
first we had to get the IGC Plenary to agree to the new "all IGC badges
and distance diploma" level first, to have somewhere to put legacy
recorders that had lower levels of security without affecting the vast
majority of owners and pilots. As it is, only world record aspirants
will be affected and there are plenty of other recorder designs that are
available for this type of flight.
Ian Strachan
Chairman IGC GFA Committee
Old November 18th 03, 08:49 PM
Robert Danewid
I agree with Paul.
So, all the world records that have been set with a CAI mod 10/20/25 may
perhaps not be secure enough???? The reason for increasing the security
should, if you using rational arguments, be a result of attempts to
cheat. I wonder which records that can be....
Of course all this is pure nonsense. Is this the way IGC is using its
resources to increase world wide gliding membership?
Yes, the decision was taken at the IGC plenary meeting, but lots of
delegates did not understand what was really happening as the
presentation was, if I may you use the word, very clever. I did not
realize at the meeting that the result was to degrade existant recorders.
Robert
perfectly secure and has never been compromised. So why suddenly call it
"insecure".
Paul Remde
"Bruce Hoult" wrote in message
"tango4" wrote:
After going to all of the time designing the hardware security along
came
the idea of public key cryptography so the IGC spec was 'upgraded' to
incorporate this additional security layer. The Cambridges and others
got
caught between the two specs.
Public key cryptography was well known in 1994 when the Cambridge 10's
were used at the NZ pre-worlds, and in fact I *told* them at the time
that they should be using something like RSA instead of something
home-grown.
Oh well.
-- Bruce
Old November 18th 03, 09:29 PM
Bob Kuykendall
I'm betting that more than 75% of the questions being asked on this
thread can be answered "Because of Moore's Law."
Of course, I'm not betting much...
Bob K.
Old November 18th 03, 09:41 PM
Denis Flament
Ian Strachan wrote:
At the last IGC Plenary meeting earlier in 2003, a new approval level for
GNSS flight recorders was agreed. This was for "all IGC badge and
distance diploma flights" and was in addition to the existing levels for
"all
flights" and "badge flights up to and including Diamonds". The latter is
used for types of recorder units that do not have their own GPS receiver
but rely on a separate GPS unit connected to the recorder by cable.
Let's admit that this third level was necessary... Now the problem is
that most people refer to "IGC approved" loggers, not mentionning
whether it is for "all IGC badge and distance diploma flights" or
"all flights" or "badge flights up to and including Diamonds" ... in
fact most glider pilots ignore that there are different level of IGC
approval !
May I suggest that there be somewhat shorter names such as "approved
level 1, 2 or 3" or "class A, B or C" ? Things would be clearer this way.
Now, what about World Championships ??? Are they less important that
world records ??? I don't think so. One could say that it is more
difficult to cheat in a Championship than for records, that's right, but
it is not impossible (and it already happened !), and the stake is
higher too.
You (GFAC) didn't say anything about which approval level would be
appropriate for World Championships, did you ? If I read the rules for
these Championships, it says (Annex A 5.4.a) : "All GNSS FR’s approved
by the IGC up to two months prior to the Opening Day shall be accepted."
Does it mean that all loggers SHALL be accepted, whatever their approval
level ???
Same question for national records or Championships, what type of
approved loggers would you recommand ? I understand that for these type
of performances NACs may have their own rules, and allow
non-IGC-approved loggers (which is not even permitted for a mere 50 km
silver D badge, but this is another debate...), but I think that IGC
should emit at least a recommendation.
Denis
Private replies: remove "moncourrielest" from my e-mail address
Pour me répondre utiliser l'adresse courriel figurant après
moncourrielest" dans mon adresse courriel...
Old November 18th 03, 10:40 PM
Tim Newport-Peace
X-no-archive: yes
In article , Denis Flament moncourrieles
writes
"all
approval !
That may well happen, but the initial announcement need to be clear
about the intention.
It was suggested:
A: All Purposes including World Records.
B: Badges and Diplomas
D: Badges up to Diamond
Or did D stand for Diplomas?
higher too.
level ???
I don't think it is within GFAC's remit to say what should or should not
be used for World Championships. That is for the Annex A team to decide
upon.
Again, not within GFAC's remit to decide. It is up to the NAC and
Competition Organisers concerned. No doubt GFAC will advise when and if
requested, but to proffer a recommendation unasked might not be welcome.
On the necessity of the action of downgrading the approvals, waiting for
proof that the security has been broken is rather "Closing the Stable
Door after the Horse has Bolted". Prevention is better than cure.
In 1994 the security level of the time was judged to be sufficient,
bearing in mind the power of the PCs available at the time.
In 2004 ten years will have passed and the Power of PCs has made serious
advances, or if you prefer, the security of the early Recorders has been
seriously degraded.
Tim Newport-Peace
"Indecision is the Key to Flexibility."
Old November 19th 03, 03:10 AM
Mike Borgelt
And it has been since the RSA security requirements were introduced in
1997. Why is it suddenly so unfair now after 6 years ?
Marc
I think you need to read the r.a.s. archives before making statements
like this. All of the above was done by myself and others when the F.R
proposals were first mooted but all were ignored
You are either ignorant of what really happened or being deliberately
obtuse. I suggest you do a google search for r.a.s. for IGC flight
recorders.
You had better privately ask Mr Strachan about the meeting at Lasham
at which reasons were invented not to approve loggers which met the
rules as written and approved by the IGC at the time. Ask him who most
of the participants had business associations with either before, at
the time or subsequently. Also ask where the principal of that
business was at the time.
The history of F.R.s on the FAI site is inaccurate as it omits these
details and others.
How about a straight answer in public to - is it the intention of GFAC
to approve new designs for "all but World records category"?
I'm sure GFAC have a policy, it may just not be the written down
official one based on past history.
p.s.
"jump starting the market" in that way as you put it would most
likely contravene the Trade Practices Act (1974) in Australia and land
you with a large fine. Ask the freight companies who were fined after
the ACCC(Australian Consumer and Competition Commission) used an
electronic barograph to prove that goods being sent by "airfreight"
were in fact going by truck between Brisbane- Sydney- Melbourne.
Mike Borgelt
Borgelt Instruments
Old November 19th 03, 04:24 AM
Marc Ramsey
A) There is now a better (for the pilots) option than a downgrade to
Diamond-level approval, and B) the process was only approved by the IGC
this year.
recorders.
As you well know, I was not a member of GFAC at that time. Anything I
state about then (or now, for that matter) is simply my opinion. If you
want the official word, you know how to contact Ian.
Obviously yes, since there is a new design (THEMI) that is approved in
this category.
There is no written policy at this moment, as the category is less than
a year old, and it's not clear whether any other manufacturers will make
use of it. The whole point is to keep it fairly flexible, so those who
can't or won't go for all flights approval have another category to work
with.
I have no idea what you are talking about.
Marc
