Revised IGC-approvals for some types of legacy recorder
Old November 20th 03, 12:00 PM
Marc Ramsey
Mike Borgelt wrote:
I believe that was calculated before SA was turned off. As I pointed
out above I doubt very much that any cockpit static can be better
than 50 to 100 feet.Static ports on gliders are sometimes pretty
terrible too so may not be any better. Try a good side slip and see
what happens also.
Add in the other error sources and you are worse than GPS altitude at
any altitude much above 1000 feet AGL.
It isn't a question of accuracy, it's a question of what is being
measured. Some believe we should continue to measure pressure altitude,
simply because that's what we've always done. I think it safe to say
that is now recognized by the IGC that once you get into the tropopause,
the magnitude of the error goes up rapidly. The current world altitude
records can't really be said to measure altitude, they simply measure
record low pressures.
Then again neither the original reasoning nor the persuasion seems to
have seen the light of day.
Frankly, GFAC is pretty much like every other committee I've been
involved with. Decisions aren't necessarily made by reason or
persuasion, they often are made by something approximating the consensus
when everyone gets tired of discussing it. After a few years, it's
often difficult to figure out exactly why a particular decision was made.
Keep in mind, there is no secretary, no meeting notes. Just a few
people spread out over a couple of time zones, many of whom have never
met any of the others face to face. 95% of the communication that goes
on is over email, and there's is no central archive. Perhaps if there
was a more sizable budget and actual salaries, we could communicate to
all with the level of detail and consistency you seem to be expecting.
But, for the moment you are stuck with a bunch of volunteers, some of
whom have been putting up with this sort of grief for 10 years now.
Do you realise that the original requirement drove some serious system
architecture considerations for manufacturers? As I said the GFAC were
originally adamant about no static connections - what changed their
minds?
Yes I do realize that. Just as I'm sure you realize that the concept of
flight recorders was very new in 1995, and that there has been a steep
learning curve for all involved. You also realize that the makeup of
GFAC now is quite different than it was in 1995. And, of course you are
fully aware that people can change their attitudes about issues over time.
How does anyone trust the rules when they may change next week?
The rules don't change every week. Rule changes are proposed at the IGC
meeting each March. Those rule changes that are accepted at the meeting
go into effect the following October. The manufacturers of approved
flight recorders (and those who have notified us that they intend to
submit a recorder for approval) are nearly always given advanced
notification (nobody is perfect, except you apparently) of proposed
changes, and asked for their input.
Nothing I've seen written here convinces me that anyone on GFAC has a
clue.
Well, at least we don't sit around badmouthing you on r.a.s.
Marc
Old November 20th 03, 11:23 PM
Mike Borgelt
Marc,
I suggest you seriously research the history of what happened in 1995
to 1997. The IGC had rules in place for loggers which GFAC blatently
defied when it came to approval. The rules were then changed quite
outside the system you talk about. It is a matter of public record. I
suggest you contact Robert Danewid and EW Avionics privately and
publish your apology here later.
Mike Borgelt
Old November 21st 03, 12:36 AM
Marc Ramsey
Mike,
I am quite willing to discuss technical issues with respect to the
current flight recorder specifications. I am also willing to discuss
what might be done to improve the specifications in the future. All I
know of what went on in the '95 to '97 time frame is what was discussed
in r.a.s. at the time. I have no interest in rehashing it now.
Marc
Old November 21st 03, 05:02 PM
Ian Strachan
In article , Mike Borgelt
writes
snip
I do not wish to get into further argument with Mike Borgelt but I must
point out that the interpretation above is his own. It is certainly not
mine or that of GFAC or IGC since they oversee GFAC and review the GFAC
annual report to IGC at each plenary.
He refers, I think, to the process that resulted in the "IGC Badges up
to and including Diamonds" level that was applied to the EW series of
recorders that do not have their own GPS but must be connected by cable
to one of the Garmin range of GPS receivers. And would have probably
applied to the Borgelt Joey recorder had he submitted an IGC version for
IGC-approval.
Mike, I do not want to get involved in a slanging match or indeed to
reply further. But for those who are new to this, I really had to
comment on your statement above in case people thought that it was the
only interpretation of early events in the IGC-approval process. I do
not doubt that it is yours, but it may not be other's.
The dates of all IGC-approvals including historic ones is on the
gliding/gnss web site and the history up to the issue of the EW
IGC-approval is:
16 Jan 96 - Cambridge Models 10, 20 and 22, initial issue
31 May 96 - Peschges VP8, initial issue
12 Aug 96 - Filser LX20, initial issue
10 Nov 96 - Zander GP940, initial issue
20 Mar 97 - Print Technik GR1000, initial issue
25 Mar 97 - Filser LX20 Version 2 Approval, with the addition of motor
glider engine recording
19 Apr 97 - EW "EWFR A & B" for badge flights up to and including
Diamonds, when connected by cable to one of a list of approved GPS
units, listed in the IGC-approval document.
etc., for more details see:
http://www.fai.org/gliding/gnss/igc_approved_frs.pdf
Ian Strachan
Chairman, IGC GNSS Flight Recorder Approval Committee (GFAC)
Bentworth Hall West
Bentworth
Alton, Hampshire GU34 5LA
ENGLAND
Tel: +44 1420 564 195
Fax: +44 1420 563 140
