Ian Strachan wrote in message ...
In article , Andy Durbin writes Ian Strachan wrote in message ... From: Chairman, IGC GNSS Flight Recorder Approval Committee (GFAC) Subject: Date of effect now 1 April 2004 for revised IGC-approval conditions for certain legacy types of GNSS flight recorder. 3. No immediate manufacturer support (out of production and the original manufacturer either no longer exists or is no longer dealing with them). Would you please explain why lack of manufacturer support has any bearing on the security of a flight recorder or the validity of a flight log. In the event of an anomaly in recording or in the IGC file data, advice from the recorder manufacturer has proved vital in the past in explaining to the validating authority what is likely to have happened. Several world records have been saved as a result of manufacturer advice and tests where otherwise they would have been lost. Sometimes the recorder has been returned to the manufacturer for tests so that the anomaly can be explained. In at least one case, after manufacturer tests indicated a line of investigation, further flight tests were carried out by GFAC with that recorder and resulted in several World Records being validated. Without this process it would not have been. You can argue that this should equally apply to badge flights, but world records are particularly important and a line has to be drawn somewhere. Ian, Thanks for the reply. I can certainly understand that using a recorder with no manufacturer support would put the record claim at risk if an anomaly is experienced. I cannot understand that use of an unsupported, but previously approved, recorder should be disallowed. The circumstance in which an unexplained anomaly is observed in the log could be covered in the rules. No explanation then no record. (I am not actively seeking world records but my CAI model 25 is now disallowed and I don't have great confidence that my 302 will survive under this rule) Andy (GY) |
Air Force Print News for April 30, 2004 | Otis Willie | Military Aviation | 0 | May 1st 04 10:20 PM |
Mil Acft Comms Log, Florida - Friday 30 April 2004 | AllanStern | Military Aviation | 0 | May 1st 04 07:12 AM |
Air Force Print News for April 23, 2004 | Otis Willie | Military Aviation | 0 | April 24th 04 10:11 PM |
Air Force Print News for April 19, 2004 | Otis Willie | Military Aviation | 0 | April 21st 04 12:22 AM |
FS 2004 'Shimmer' Effect of Ground Scenery | Mr Zee | Simulators | 3 | August 24th 03 04:40 PM |
