![]() "Adrian Jansen" wrote in message ... You might want to consider the implications of WAAS. I have no direct experience, but the principle is that you take an external signal and use it to 'correct' the GPS location to another place - hopefully more accurate. But what is to stop you sending bogus 'corrections' and making the GPS think its somewhere else entirely ? The WAAS signals are much easier to generate than the original GPS satellite signals. Sounds an easy way to cheat to me. -- Regards, I do not believe it is at all easy to fake GPS WAAS and GPS is already acceptable for position. But it is very easy to fake a barograph. Ivan |
In article , Ivan Kahn
writes snip I do not believe it is at all easy to fake GPS WAAS and GPS is already acceptable for position. But it is very easy to fake a barograph. A drum-type baro, yes, it has unfortunately been done and some cases have been publicised in the public domain. Not easy if it is an electronic pressure sensor embedded in a secure GNSS flight recorder. You have to fake both the pressure and GNSS-altitude traces and make them similar. Now that is less that straightforward, I think. Yes, you could probably fake one, or the other. But both together is not easy. How many people have access to a GPS simulator and a pressure chamber? And the ability to co-ordinate the two into a plausible IGC flight data file that still passes the security checks? Also, the faked fixes would have to agree with the weather of the day, thermal/wave conditions, winds with height, etc. All of which can be checked against other flights done on that date and in the same area. Finally, on flights to be validated an OO has to observe the recorder in the glider and the time and place of takeoff and landing. How do you fake this beforehand? Yes, I suppose that anything is possible but I suggest that the "height of the fence" that IGC has put up against cheating or malpractice with GNSS flight recorders, is suitably high. Make it too high and we would not fly because there would be too many checks to do first! -- Ian Strachan |
WAAS and Garmin 430/530 | DoodyButch | Owning | 23 | October 13th 03 04:06 AM |
Updated IGC approval documents for Cambridge GNSS flight recorders | Ian Strachan | Soaring | 0 | August 27th 03 05:28 PM |
Terminology of New WAAS, VNAV, LPV approach types | Tarver Engineering | Instrument Flight Rules | 2 | August 5th 03 03:50 AM |
WAAS | Big John | Piloting | 8 | July 22nd 03 01:06 PM |
Garmin Behind the Curve on WAAS GPS VNAV Approaches | Richard Kaplan | Instrument Flight Rules | 24 | July 18th 03 01:43 PM |
