Do winglets produce thrust?
Old November 29th 03, 03:47 AM
Eric Greenwell
Bruce Hoult wrote:
ojunk (Bob Salvo) wrote:
Anyone?
Bob
Winglets reduce induced drag by effectively making the wingspan longer.
Perhaps in the past, but maybe not anymo from page 104 of the
Fundamentals of Sailplane Design...
"Subsequently, it has been shown that good results may be obtained with
relatively small winglets. In contrast to early winglets, which were
essentially upward wing extensions, recent winglet designs are optimized
to diffuse the vortex rollup at the wingtip, thus reducing its strength.
There is also evidence that the velocity field induced by the winglets
can improve airfoil aerodynamics in the vicinity of the wing tip by
prolonging laminar flow and delaying separation."
I've never seen anyone argue convincingly that a half a meter of
vertical wingspan does anything that couldn't be done equally well with
an extra half meter of normal wingspan.
Winglets can improve roll rate, while longer tips tend to reduce it.
On the other hand winglets are
worse than span in that they don't produce lift in a useful direction,
and they are harder to make strong and rigid than ordinary span is.
The lift they produced is used to decrease drag, which is a useful
result, and the small ones used on the ASW 27, for example, look pretty
simple to make.
If it wasn't for class rules limiting winspan I don't think anyone would
have winglets.
Much less likely, for sure.
Replace "SPAM" with "charter" to email me directly
Eric Greenwell
Washington State
USA
Old November 29th 03, 07:43 AM
Bruce Hoult
But the question is, would similar-shaped horizontal extensions to the
wing have the same effect? What about multiple small span "winglets"
off the end of the wing? Birds do that. The modern winglets look a lot
like a single tip-feather.
-- Bruce
Old November 29th 03, 04:10 PM
Eric Greenwell
Take a look at the winglet pages in the book. It doesn't sound like they
are doing the same thing they would be doing laying flat.
Eric Greenwell
Washington State
USA
Old November 29th 03, 10:49 AM
Paul Repacholi
Bruce Hoult writes:
longer.
with an extra half meter of normal wingspan. On the other hand
winglets are worse than span in that they don't produce lift in a
useful direction, and they are harder to make strong and rigid than
ordinary span is.
But the spar does not have to deal with the extra lift on a *long*
moment arm. Well not all of it anyway.
would have winglets.
I wonder what class rules the 744 design has in mind
Paul Repacholi 1 Crescent Rd.,
+61 (08) 9257-1001 Kalamunda.
West Australia 6076
comp.os.vms,- The Older, Grumpier Slashdot
Raw, Cooked or Well-done, it's all half baked.
EPIC, The Architecture of the future, always has been, always will be.
Old November 29th 03, 03:32 PM
Bob Kuykendall
It has to fit between established jetways at established airports.
That and the inboard bending moment contstraints mentioned earlier.
Bob K.
Old November 29th 03, 05:17 PM
Bruce Hoult
Bruce Hoult writes:
longer.
ordinary span is.
Hmm ... well a deliberately non-lifting horizontal section at the tip
would reduce induced drag as well.
Terminal gates.
I don't know what excuse bizjets or small turboprops such as the Beech
1900 have. Possibly fashion.
-- Bruce
Old November 29th 03, 05:25 PM
Eric Greenwell
This could be done for one angle of attack, but I don't see how it could
be done for the usual range a glider uses. A winglet has the same angle
of attack, independent of the wing.
Eric Greenwell
Washington State
USA
Old November 29th 03, 05:48 PM
Jack
Date: Sat, 29 Nov 2003 18:49:16 +0800
Bruce Hoult writes:
If it wasn't for class rules limiting wingspan I don't think anyone
Those rules which limit gate space at airport terminals.
Jack
"Heavier-than-air flying machines are impossible."
-- Lord Kelvin, President, Royal Society, 1895
A Level 1 AOA clarification Ramapriya Piloting 64 January 9th 05 01:19 AM
Space Elevator Big John Home Built 111 July 21st 04 04:31 PM
max altitude and Mach 1 Boomer Military Aviation 22 June 1st 04 08:04 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
P-38 Exhaust Stephen Harding Military Aviation 10 April 19th 04 07:03 AM
