Bruce Hoult wrote:
In article , ojunk (Bob Salvo) wrote: Anyone? Bob Winglets reduce induced drag by effectively making the wingspan longer. Perhaps in the past, but maybe not anymo from page 104 of the Fundamentals of Sailplane Design... "Subsequently, it has been shown that good results may be obtained with relatively small winglets. In contrast to early winglets, which were essentially upward wing extensions, recent winglet designs are optimized to diffuse the vortex rollup at the wingtip, thus reducing its strength. There is also evidence that the velocity field induced by the winglets can improve airfoil aerodynamics in the vicinity of the wing tip by prolonging laminar flow and delaying separation." I've never seen anyone argue convincingly that a half a meter of vertical wingspan does anything that couldn't be done equally well with an extra half meter of normal wingspan. Winglets can improve roll rate, while longer tips tend to reduce it. On the other hand winglets are worse than span in that they don't produce lift in a useful direction, and they are harder to make strong and rigid than ordinary span is. The lift they produced is used to decrease drag, which is a useful result, and the small ones used on the ASW 27, for example, look pretty simple to make. If it wasn't for class rules limiting winspan I don't think anyone would have winglets. Much less likely, for sure. -- ----- Replace "SPAM" with "charter" to email me directly Eric Greenwell Washington State USA |
Eric Greenwell wrote: Winglets reduce induced drag by effectively making the wingspan longer. Perhaps in the past, but maybe not anymo from page 104 of the Fundamentals of Sailplane Design... "Subsequently, it has been shown that good results may be obtained with relatively small winglets. In contrast to early winglets, which were essentially upward wing extensions, recent winglet designs are optimized to diffuse the vortex rollup at the wingtip, thus reducing its strength. There is also evidence that the velocity field induced by the winglets can improve airfoil aerodynamics in the vicinity of the wing tip by prolonging laminar flow and delaying separation." But the question is, would similar-shaped horizontal extensions to the wing have the same effect? What about multiple small span "winglets" off the end of the wing? Birds do that. The modern winglets look a lot like a single tip-feather. -- Bruce |
Bruce Hoult wrote:
But the question is, would similar-shaped horizontal extensions to the wing have the same effect? What about multiple small span "winglets" off the end of the wing? Birds do that. The modern winglets look a lot like a single tip-feather. Take a look at the winglet pages in the book. It doesn't sound like they are doing the same thing they would be doing laying flat. -- ----- Replace "SPAM" with "charter" to email me directly Eric Greenwell Washington State USA |
A Level 1 AOA clarification | Ramapriya | Piloting | 64 | January 9th 05 01:19 AM |
Space Elevator | Big John | Home Built | 111 | July 21st 04 04:31 PM |
max altitude and Mach 1 | Boomer | Military Aviation | 22 | June 1st 04 08:04 PM |
Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 06:42 PM |
P-38 Exhaust | Stephen Harding | Military Aviation | 10 | April 19th 04 07:03 AM |
